#26 (permalink) | ||
Did you want a pic of my current suspension? Quote:
[FONT="Comic Sans MS"][SIZE="5"][COLOR="Blue"]NotQuiteRight Wheelers[/SIZE][/COLOR] [B][SIZE="2"]CROMO BUGGY LY6/LS3-TH400-Atlas 3.0-Rockwells-44" TSL's-Bilstein Coilovers-4Link F&R-PSC full hydro-Ouverson pinion brakes[/FONT][/SIZE][/B] [FONT="Comic Sans MS"][SIZE="5"][COLOR="Blue"]MY BUILD[/COLOR][/SIZE][/FONT] [SIZE="2"][URL="http://pirate4x4.com/forum/showthread.php?t=973676"]http://pirate4x4.com/forum/showthread.php?t=973676[/URL][/SIZE] Last edited by BLK Scout 800; 11-08-2009 at 02:28 PM. |
#28 (permalink) | |
Member # 69678
78 SII very healthy 327,th-350,np205,35''boggers 71 800B LT-1,400,203/205,FF14,d-60,42'' rockers on beadlocks To my great friend rob,RIP buddy we'll never forget you. |
#29 (permalink) |
I don't have much on this laptop, I'll have to dig out close up shots on my old computer. Here is another angle of what 52's will do, but that's all I got for now. At this point I'm on 38" TSL SX's and dana 44's BTW. Leafs work well for the money, but coilovers should be on your list if you want big flex with a smooth ride.
[FONT="Comic Sans MS"][SIZE="5"][COLOR="Blue"]NotQuiteRight Wheelers[/SIZE][/COLOR] [B][SIZE="2"]CROMO BUGGY LY6/LS3-TH400-Atlas 3.0-Rockwells-44" TSL's-Bilstein Coilovers-4Link F&R-PSC full hydro-Ouverson pinion brakes[/FONT][/SIZE][/B] [FONT="Comic Sans MS"][SIZE="5"][COLOR="Blue"]MY BUILD[/COLOR][/SIZE][/FONT] [SIZE="2"][URL="http://pirate4x4.com/forum/showthread.php?t=973676"]http://pirate4x4.com/forum/showthread.php?t=973676[/URL][/SIZE] Last edited by BLK Scout 800; 11-08-2009 at 08:09 PM. |
#30 (permalink) | |
[FONT="Comic Sans MS"][SIZE="5"][COLOR="Blue"]NotQuiteRight Wheelers[/SIZE][/COLOR] [B][SIZE="2"]CROMO BUGGY LY6/LS3-TH400-Atlas 3.0-Rockwells-44" TSL's-Bilstein Coilovers-4Link F&R-PSC full hydro-Ouverson pinion brakes[/FONT][/SIZE][/B] [FONT="Comic Sans MS"][SIZE="5"][COLOR="Blue"]MY BUILD[/COLOR][/SIZE][/FONT] [SIZE="2"][URL="http://pirate4x4.com/forum/showthread.php?t=973676"]http://pirate4x4.com/forum/showthread.php?t=973676[/URL][/SIZE] |
#31 (permalink) |
Member # 125140
Its been a while, so here's an update. Finally got my second set of steering u-joints from speedway (took about 2 weeks). I got a 4" K&N Air filter. I also had to replace the water pump twice. First one had a crack in it and i didn't find it until I started it up. Bought a new Performer intake, along with a Phenolic Carburetor Spacer and installed them. Today My cousin and my friend came over and we started the install of the power steering. We mounted the box to the frame, mounted the ps pump, installed the steering column, installed the steering u-joints, and made a Z bar. The Z bar isn't finished but it is close. The power steering box also needs a few more welds on it. Should have the power steering working very soon.
![]() Here are some Pictures This is the new filter and old intake ![]() New Intake Installled ![]() New Phenolic Carburetor Spacer Installed ![]() Power Steering Box Mounted ![]() ![]() Steering Column Installed ![]() ![]() ![]() The New Z bar ![]() More to come.... |
#37 (permalink) | |
![]() I'd do the mount different but hey, who knows - might work.. I wouldn't touch a Z bar but he doesn't want to dump money into a temp crappy axle so hey, it gets it going.. I wouldn't touch a carb but that's just me, once again a choice. What else ya got?
This Space for rent! |
#38 (permalink) |
Member # 125140
Yes, it is all temporary until i put my new 44 installed. I would have liked to mount the box closer to the frame, but i wanted to be able to remove the bolts easily if it needs to be removed for any reason, and i didn't want long bolts going through the frame to hold it. It already has gussets and will be plenty strong when it is finished. If you have any suggestions on ways to improve it, please let me know!
I would like to go EFI, but i would rather put the money that would cost into something else for now. In the future... who knows. Last edited by JERM83; 12-07-2009 at 04:48 PM. |
#40 (permalink) | |
TITUS
Member # 93509
I would get that steering box as close to the frame as possible. Decrease the leverage it will have to break things. I angled my box so I could sleeve 3 of the 4 bolt holes through the frame with one mounted directly on top. ![]() ![]() I cut the stock exterior column mount from a donor Chevy truck and grafted it onto the scouts firewall as well as use the stock Scout mount by drilling a hole in the top of the column housing. You will need to cut some of the bell from the bottom of the Chevy column to get it to sit in right. The Chevy column housing is just a tad bigger than the Scout's so it will still clamp together with some longer bolts. ![]() ![]() Those were the only two gripes I had and as Brandon stated, you would be surprised at what a steering box can do to a poorly made mount especially when you start adding bigger tires. Last edited by IDScout; 12-07-2009 at 08:25 PM. |
#41 (permalink) | |
Member # 125140
We are going to build a steering column support under the dash, and another near the end in the engine compartment. I do like your mount under the dash. Last edited by JERM83; 12-07-2009 at 10:24 PM. |
#42 (permalink) |
Member # 125140
Today we finished up the Z bar, and got the scout driving. I still have a few things to finish up before i can drive it more, but it went up and down the street again for the first time in months! I still need to have a little more welding done to support the box more.
#45 (permalink) |
Member # 69678
x2,almost spit my morning coffee out when i saw it.i like the build also,but that z bar should be on "there i fixed it"
#46 (permalink) | ||
Tactical Turtleneck
#47 (permalink) | ||
Addicted to Gear Oil
Member # 56050
"It's only temporary... unless it works!"-Red Green I know that Z-bar is temporary, until you can get the axle swap and go hi-steer, but please for the love of god, don't drive that anywhere near a bus load of nuns. The tie rod looks like it's seen better days, too. Other that that, it's looking better. Engine crossmember looks like standard hot rod style from Speedway, etc. I sleeved my PS box through the frame, too. I found a few more pics: ![]() ![]() ![]() After I took this pic, vvvv I also welded large washers over the sleeves to help spread the load over more of the frame. ![]() I chopped up the stock steering column bracket, added and extra piece of angle that ties into the pedal assembly and the firewall. On the engine side, it has a clamp at the fire wall and another u-bolt along the inner fender to clear the exhaust.
1965 Scout 80 7.3PSD/ZF/203/205 D60F/14BFF Member: 4 Jackstand Wheeler's Association Quote:
David H. Petraeus for President 2016Last edited by guidolyons; 12-28-2009 at 07:16 AM. |
#48 (permalink) |
lets go Squatchen
Member # 14561
not sure what is scarier, the hilift jack stands or the steering links.
Want to know how I lost 25lbs in 9 weeks? Try INSANITYŽ. www.beachbodycoach.com/petermhope I love it when a plan comes together Colorado Springs, CO Based FFL-07/SOT |
#49 (permalink) | |
Member # 115887
Steering link = Killing a bus load of autistic school children. On second thought, the link may be fine for moving around your yard and checking some things. The Hi lift as a means of support, just plain wrong.
God hates a coward. Nolite esse canis praecisae |
#50 (permalink) |
Member # 125140
All of the parts are new on the Z bar. The other supports are not finished because I do not have a welder, and it gets welded as i can find people to weld for me. Any driving will be limited to streets only. I personally dont like Z bars, (even this one) but like i said before its all temporary until i put my 44 in. I just got offered a 12 bolt or a 9" for free for the rear last night also.
