Member # 14
This ideas pro's & con's haven't all crossed my mind yet, but I thought I'd pass it by you guys while the idea is still fresh and seems like a sweet idea. <IMG SRC="smilies/wink.gif" border="0">
I love the ride my coil sprung suspension on my blazer gave me nice and comfy, obsorbed all of the bumps I hated feeling with my factory leaf spring set-up. So I was reading through one of my newer wheeling mags and say a great idea. Using one or two (thin) leafs SOA to locate the axle (side-to-side and front-to-back) and use coils to support the wieght. At first I was thinking well then you're still limited to the droop and compression of the leafs, but not so, a sigle or double thin leaf set-up would flex super good compared to a stock med-thickness 4-5 leaf set-up. Especially if you used long Ford F150 springs. I also thought that if you throw in a revolver shackle (if necessary) You'd have a pretty sweet set-up, the biggest advantage being the softer ride of coil springs. Now I'm thinking what about axle wrap...well just make and axle wrap-bar. I already have TWO pretty long (15" inches of solid steel professionally added to them and re-threaded) ford radius arms I could apply as a traction bar. So what do you guys think. |
Member # 5982
Sounds like a good experiment. You'll need two bars for traction, plus most likely a track bar to locate the axle. At that point you might as well add the fourth bar and go with 4 link rear, with double shackles. The other problem will be locating the coils in the rear. Scouts are heavy the more you angle the coils inward the higher the spring rate needs to be. You could bring the coils up through the bed and attach to a bar tied to the cage.
Joe <IMG SRC="smilies/smokin.gif" border="0">
Was that a comment meant to hurt? RU Dysfuncational http://thisdysfunctional.org/forum |
Member # 4001
Rockslut was saying that he saw that somewhere. I don't know if it was on TV, on this board, or in a mag, but it was an Austrailian pic. Seems like it would work great but it also seems redundant.
Dysfunctional Rockcrawlers |
#4 (permalink) | |
Member # 14
<STRONG>The other problem will be locating the coils in the rear. Scouts are heavy the more you angle the coils inward the higher the spring rate needs to be.</STRONG>[/QUOTE] I'm not talking coilovers, I'm talking Coil Springs like on a bronco. Plus I already have a set that I think would work, My Blazer wasn't much heavier than my scout. <STRONG>You could bring the coils up through the bed and attach to a bar tied to the cage. Joe <IMG SRC="smilies/smokin.gif" border="0"></STRONG>[/QUOTE] I think you lost me or I lost you somewhere...... <IMG SRC="smilies/confused.gif" border="0"> |
#5 (permalink) | |
Member # 14
Like I said the primary objective for me is a nice soft ride |
#6 (permalink) | |
Member # 4001
I understand why...but you can get a soft ride from leaf springs. You just have to have a lot of thin leaves.
Member # 2243
I think that using coils and one or two leafs is a cool idea, If you use longer springs for the rear, you could use your rears on the front.
I would really like to see how it turns out if you go for it. I can see how the ride would be soft, but I can also see how you would need to carry spare main leafs when wheeling.
"After all is said and done, a hell of a lot more is said than done." Clark Olmstead |
#9 (permalink) | |
Member # 14
#10 (permalink) | |
Member # 4001
#11 (permalink) | |
Member # 2243
I believe if your going to 4wheel with this set up your springs would be more prone to break or bend since they would not have the support of the missing leaves. This occasionally happens even with a complete spring pack. That's why I like the military wrap design. Let's face it, springs do break and it's a good idea to carry a spare main leaf if possible. Actually, the only springs I've personally seen break or bend are stock IH Scout and Travelall, Chevy Superlift, stock Wrangler and stock FJ40 springs. But then again, I guess it depends on what kind of 4wheeling you'll be doing too.
#12 (permalink) | |
Member # 226
By the time a person built a traction bar, custom spring hangars, coil buckets, and a panhard bar, they may have well just built a 4-link or a radius arm/panhard bar setup. Hell you are already 1/2 way there with the HD extended radius arms you already have! Why fool around with a mickey mouse leaf spring setup to locate the axle when you can have a strong setup you don't have to worry about? |
#13 (permalink) |
Member # 5021
The way he wants to do it you only need the coil buckets and traction bar. Very simple but the single or double main leaf would be scary if the traction bar ever broke or was inefective. 2 traction bars would probably be a safer idea.
#14 (permalink) | |
Member # 5946
You have your top leaf, which is basically just locating your axle and then you have your coil spring providing your suspension. I seen the picture also, it was from the Australian Adventure or something like that. I believe that if you used an arched leaf SUA you wouldn't need much of a traction bar, and the coils would keep your top leaf from going flat. Only my opinion but I think something like this would work.
I.R.B.S.T.M. |
#15 (permalink) | |
Member # 226
#17 (permalink) | |
Member # 226
#18 (permalink) | |
Member # 5946
hmmm?........ What is this Mickey Mouse Suspension System you speak of......... DISNEY OFF-ROAD?
I.R.B.S.T.M. |
#19 (permalink) |
Member # 226
1. What advantage would the coil & leaf combination have over a properly built convetional leaf spring setup?
2. What advantage would it have over a 4-link/coil setup? 3. What advantage would it have over a radius arm/coil setup? I don't see it having an advantage over any of these other proven setups. |
#20 (permalink) | |
Member # 14
Plus I just thought the idea looked cool. |
#21 (permalink) | |
Member # 14
What is the military wrap design???? |
#22 (permalink) | |
I agree. I don't see many advantages. I *have* thought somewhat about a similar setup though.. in my case, I'd leave the full leaf packs in place as-is and add coil-overs and reservoir shocks. Mostly for the progressive and additional spring rate to soak up landings better. of course, I'd rather just do a 4-link front/rear and be done with it. Most rule books won't allow "secondary" suspensions.. which is another problem of running leaves + coil-overs.
-Tom KE7VUX |
#23 (permalink) | |
Member # 14
It just seems like a no brainer as in easier than a 4-link where you have to worry about rear axle steer and pinion angle varying while traveling over rocks.....blah blah blah...It's not that I couldn't do it or don't want to, but I like simple easy to fix set-ups. Plus if my coil spring ever gave up the ghost I could use a factory leaf spring pack temorarily. Anyway....I'm done for this one.... |
#25 (permalink) |
Member # 4758
I actually have a similar suspension to what we're talking about already in the works. It's not quite the same, but close.
I'm using Alcan springs (they were given to me) on a rear SOA, and I love the flex and ride. However, with a load of gear, and on steep climbs, the rear suspension has a tendency to bottom out. I came across a set of cool little coil spring overloads off the rear of some foreign truck with a utility box on it at the junk yard. What I'm doing is locating these just outside the frame and they will contact the top of the spring plate. I'm locating them so they just make contact at static ride height, but are not in contact when the suspension droops. Basically, this is my version of a progressive bump stop. I think it's a great combination; load carrying ability but still good flex off road. |
