Member # 5982
Today's topic front SOA problems and issues using what axle:
Joe <IMG SRC="smilies/smokin.gif" border="0"> [ 10-16-2001: Message edited by: jdjanda ]
Was that a comment meant to hurt? RU Dysfuncational http://thisdysfunctional.org/forum |
Member # 5982
Member # 4001
The best thing that I did on my Six-Foe is put a Jeep Wagoneer axle under the front. I don't have the zero caster/pinion angle thing.
Also: 1) already has flat-top knuckles 2) Has small bearing spindles to convert to ford rotors 3) internally splined hubs I used Rubicon Express anti-wrap perches because they are taller than most. This allowed me to weld the tube side on. The other side, I ground the perch way down inside until it was level with the other one. I then had a certified welder buzz the cast side on. Used extended braided brake lines for a wagoneer on the front. Used stock bottom shock mount; fabbed my upper one. Now I run 9012's up front. And a huge square tube d-shaft with 6" of stuff and 13" of droop...no cv. The one item left is my steering. I have to switch out my steering box. Until then, I don't know if I will be going hi-steer or cross-over. Did I forget anything?
Dysfunctional Rockcrawlers |
#4 (permalink) | |
Member # 14
#5 (permalink) | |
Member # 14
Am I stupid....what is the difference between Hy-Steer and Cross-over??? |
#6 (permalink) | |
Member # 4001
Cross-over= Drag link mounted to high arm. Tie rod in stock location.
#7 (permalink) | |
Member # 4506
Actually, no. Or atleast not how *I* have come to know it: Cross-over: Stock Scout. Draglink CROSSES OVER from the steering box to the OPPOSITE side of the truck steering knuckle. Different from IH p/u and Cliffhanger's Blazer, which had "fore-and-aft" steering. "High-steer" would be specifically bringing the DRAG LINK above the springs. To my knowledge, there is not much termination difference if you bring them both up or just the draglink. Atleast that’s How I've heard it defined and have come to understand the two terms.
I wheel a mean jackstand
Member # 4506
Chev d44, narrowed to fit Scout II shafts (3.25 long side, 3.5" short, but I'll double check that) 8º shim welded to perches (for "proper" CV alignment), rotate knuckles (since that are already off) for 6º of caster or so.
Knuckles: GM flat-tops, both sides (looks better). For right now, GM backing plates and calipers, Scout II D30 spindles (drum), Scout II D44 hub and rotors. Chevy 2wd pu brake lines (nice and long and cheap). Ben's arms (both drives and passenger) allowed me the use of the stock tie-rod and drag link, although the draglink is a DOM unit from Gryphin Racing. Shaft, for now will be a stock Scout II shaft, no CV. If I get excessive vibs, then maybe a CV, but I'll save the $$ for now for the shaft with the RC housing I'm working on. Or atleast that’s the plan when I get the weekend to do it all in (ggrrrrrr, what happened to all my time!!!)
#9 (permalink) | ||||||
Member # 4758
Mines a little different. My front is not SOA, it's SUA with a shackle flip, but the way it's done, it's actually taller than some of the SOA's I've seen. So I've dealt with many of the same issues.
<STRONG> Quote:
<STRONG> Quote:
<STRONG> Quote:
<STRONG> Quote:
<STRONG> Quote:
[ 10-17-2001: Message edited by: Monster-Z ] |
"Little Devil"
Pre-RS. 74 Chevy 1/2T .5" wall uncut D44. TriCounty arm, Gryphin Racing draglink for High-steer/quick-ratio. No twist. Plenty of caster stock. 2wd '74 Chevy brake lines. Mounts relocated to bump stop brackets. Old shock mounts buzzed off (and run over, sidewalling one of my tires.. d'oh). New square-tubing "hoops" welded together for 14" travel shocks to slightly modified stock Chevy lower mounts. Housing - ground the spring perches to fit the U-bolts against the narrower 2" springs. Driveline - STOCK! from a D30 SII. Never pulled apart, only bottomed it when the front suspension failed. Misc problems? It flexed too well. <IMG SRC="smilies/biggrin.gif" border="0"> Springs turned into an "S" from too much right foot. Now, post RS, I have XLC front springs, no-lift RS, a Tom Wood's non-CV front driveshaft, too much caster, too low of a pinion, but otherwise the same. Problem now is the pitman arm acts as a bump stop some times. Gotta cut the RS "towers" off and lengthen. Plan for my trail rig? HP'44, grind/weld a new perch in, Chevy flat-tops, Gryphin Racing long-steering arms, GRT tie-rod/draglink. Try to set the caster when I retube the HP center section. 2wd Chevy hoses again, Chevy calipers, F250/K20 hubs/rotors. Uncut. RS or no RS.. not sure yet, but w/o the RS, I may not need a new front driveshaft, thanks to the HP.
-Tom KE7VUX |
#11 (permalink) | |
Member # 4001
Either way...When I get my Steering box finished. I will try to put my whole system above the springs. If it won't fit, then just the draglink will go above.
#12 (permalink) | |
Member # 4306
Don't worry. It'll fit. http://www.ihssii.org |
#13 (permalink) | |
Member # 4306
Bwaaahhhaaaaaa. Uh huh. I'll believe it when I see it!!! <IMG SRC="smilies/biggrin.gif" border="0">
#14 (permalink) |
Member # 4506
you will carfully note "hooptie", I stated WHEN I GET A WEEKEND FREE.
This sucks, I haven't had a complete FREE weekend in about 6 months........ I wish people would stop getting married... course husky games don't help any <IMG SRC="smilies/biggrin.gif" border="0"> <IMG SRC="smilies/biggrin.gif" border="0">
#15 (permalink) |
Member # 4306
GM Axle
Narrowed, turned to 12 degrees Shimmed perches 7 degrees for pumpkin tilt for a final 5 degrees of caster Recessed Ubolt plates to capture the springs Extended brake lines Z-Link for now. Z under steering arm. Steering arm drilled and D&C insert tapped in Redrilled center pin hole in driver perch to align driver springs. Lowered bottom shock mounts to be level with middle of axle tube. Raised upper shock mounts to be 4 inches above top of frame rail. No change to driveline. No CV joint [ 10-17-2001: Message edited by: Hooper ]
#16 (permalink) | |
Member # 4306
I remember someone giving me a hard time about spending time with significant other, rather than wheeling every weekend. Hmmm, whom might that have been????
#17 (permalink) | |
Member # 5946
Rebuilt with several pounds of 1/2" plate reinforcement. CASTER: less than zero, hit the ditches if you see me on the highway in this thing. BRAKE LINES: got the extensions, then ended up replacing the lines. So I now have new extensions and new stock lines. SHOCKS: built new lower mounts on axle tubes. Will put shock towers up top when I get longer shocks. HOUSING: modified a new pad, moved the little block from the passenger side to the driver side to level it out. Yes I know <IMG SRC="smilies/rolleyes.gif" border="0"> DRIVELINE: no CV thus the negative caster in the front, gonna turn them knuckles one of these years.
I.R.B.S.T.M. |
#18 (permalink) | |
Member # 7340
Can ya fill me in on this one HOUSING: modified a new pad, moved the little block from the passenger side to the driver side to level it out. Yes I know <IMG SRC="smilies/rolleyes.gif" border="0">
[COLOR=BLACK] You picked a fine time to leave me loose wheel [/COLOR] |
#19 (permalink) |
Member # 14
I thought that little pad was only necessary when using a stock axle "sprung under" There are no LEFT of RIGHT springs, so if you do a SOA and get the axle spring perchs the same height there should be no need for the "PAD"
#20 (permalink) | |
You *should* swap the pads to the driver's side with an SOA to give the Scout the correct tilt and make it sit level. Or you could just build your perches accordingly. I think Hayraker was talking about his front "lift block" and the "I know" was.. he knows it's a "no no" technically speakin'.
-Tom KE7VUX |
#22 (permalink) | |
Member # 5946
I.R.B.S.T.M. |
#23 (permalink) |
Member # 6690
Steering: Hi-steer, Z-link, welded arm
No idea pf what will be used? Caster: twist, no twist Twist it up. The knuckles are loose and waiting for the truck to be put together. Brake lines: new extended lines, extensions, bend the hard-lines New extended lines will be used, unless I find some used ones... Shocks: extend the brackets, new mounts new mounts Housing: grind a flat, build up a new pad Ground off and working on new pad. Drive line: CV, no CV Who needs a driveline? I got a bare naked frame. maybe someday I will have a driveline. Plan to use custom made driveline in front. CV for rear. Misc. problems TIME!!!!!! I need more time to work on the truck.... Ritch
Fire Good |
