Member # 2145
Alright the transmission and transfer case are installed. I still have to bolt in the front driveshaft and put a bearing and return spring on the clutch linkage...they should be here tomorrow. I'm pretty pumped about this T19. Its a close box so while I dont have the crawler gear for wheelin, it should be fun on the street; and not too bad offroad. Just thought I'd share my joy!
'79 Scout II 345 w/ Projection, 3.73,Lockright in rear, 4" Triangle springs, 32x11.50 BFG M/T's. '99 Chevy Z71 5.3 |
Member # 5982
I'm headed that route shortly. Auto to T98 swap (6.4:1 Granny). I'm gathering parts, just need the dam flywheel, and bell used parts. New I need a pilot bearing and pressure plate. I have everything else. Did you run into any problems you wern't ready for?
Joe
Was that a comment meant to hurt? RU Dysfuncational http://thisdysfunctional.org/forum |
Member # 3563
Joe, was it you that was asking me about the bellhousing ans flywheel? If that's holding up your swap let me know and I'll dig through my junk pile. I think I have 2 of everything.
Travis
Amatuer driver on open course, try this at home. |
Member # 2145
Joe, the only thing I've run into was I didnt disconnect as many wires as I should have to pull the dash when I put the pedals in. SO now I have to reconnect some wires so my CD player and auxiliary lights work.
Member # 4001
With everyone else jumping onto the Auto Tranny bandwagon...why are you guys switching?
I personally like the solid hook-up of a manual. Even without oil, I'm still getting home <IMG SRC="smilies/smile.gif" border="0">
Dysfunctional Rockcrawlers |
#6 (permalink) | |
Member # 5378
DangerRangerRacing.com -- Want to help a "Little guy" race at King of the Hammers? |
#7 (permalink) | |
Member # 4001
Member # 2145
The reason I'm switching is because my 727 was slipping from 2-3. I decided if I was going to have to pull it, then I may as well put a 4 speed back in. I drove a four speed (close ratio) Scout about a month ago and it was awesome. It just feels like the automatic sucks more power up than the manual.
#9 (permalink) | |
Member # 4001
#10 (permalink) | |
Member # 5982
Joe
#11 (permalink) | |
Member # 5982
Joe
#12 (permalink) |
Member # 4327
I'm doing the swap...as soon as I can afford the parts... for two reasons.
1. My auto is smoked also...3rd gear, nuetral and sometimes reverse is all that is working. 2. Bought a rebuilt Transfer case with the Bronco gears (2.46:1) and you cant get an Auto bullgear for it. I'm really bummed, had a line on a free scout with T19 and all the parts/linkage I needed for the swap....Guy's wife wanted it out of the yard.. I was already to go pick it up, but he just told me the bank still has the title on it...damn
Pain is temporary, bones heal, chicks dig scars and glory is forever. "Your a daisey if ya do" |
#13 (permalink) |
Member # 4001
Do you need the title?
#14 (permalink) | |
Member # 5982
Joe
#15 (permalink) |
Member # 4327
he still owes $1300 on the loan, used scout as collateral...I'm gonna see if he'll sell just the tranny...
#16 (permalink) |
Member # 2145
Ok guys, I drove the Scout for the first time last night. It will really scream with the 4 speed! I felt a big difference between it and the 727. I guess the fuel injection helps too. Now if I can just get my gauge lights to work again and my driver side speakers to work <IMG SRC="smilies/rolleyes.gif" border="0">
#17 (permalink) | |
Member # 4001
#18 (permalink) | |
Member # 5982
Details on the fuel injection setup please. I've driven Josh C's 75 with 304/stick and it has a lot more pop then my 345/727. Part of the reason I'm dumping the auto. Joe
#19 (permalink) |
Member # 2145
Joe, I have the 2 bbl 670 cfm Holley Projection kit. It has the closed loop with oxygen sensor. It was pretty easy to set up. Just run new fuel line, with a return line and hook all the sensors to the wiring harness. Right now it sits on a spreadbore manifold, but I have a machined 2bbl manifold getting powdercoated right now. I'm going to put it on when I get a cam and some head work done.
#20 (permalink) |
Member # 4327
I wonder if your one speaker sounds better than my actual operating 8-track through the stock speaker in the dash.
Nothin like a little Gorden Lightfoot or Cream playing .... <IMG SRC="smilies/biggrin.gif" border="0">
#21 (permalink) |
Member # 2145
Actually I have two on that side <IMG SRC="smilies/glasses.gif" border="0">
