okay here's a new thread - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-29-2001, 12:02 PM   #1 (permalink)
R O
Member # 5921
Post okay here's a new thread
I've got a 76scoutxlc that is currently undergoing rust repair.It's got 304,t19wide,d20,3.54's open,I've also have spares,345,d20,f/r axles also 3.54.I have pretty good idea what I'm going to do with it but the more ideas I can get the better the truck will be.
I will be using the truck for some daily driving and say around #4 trails.Mostly I'll be using it for camping.I will start with 33's and mabey go for 35's later.As for total cost,somewere in the mid-range,for example I'm going to use a ford RC dana44 cut down for scout axles and hubs.How about some input from the modified guys on what they would do??? <IMG SRC="smilies/tongue.gif" border="0">
R O is offline   Reply With Quote
Old 08-29-2001, 12:11 PM   #2 (permalink)
Member # 226
Post
Heres what I would do, for a camping/moderate wheeling Scout II.
SOA with stock springs
4.10 gears, welded rear, lockright front.
Good cage
Winch
Ben W is offline   Reply With Quote
Old 08-29-2001, 12:11 PM   #3 (permalink)
Member # 4001
Post
Ford axle- Wrong side diff. Also, doesn't a 76 come with a D44 already? If anything, I would swap the Ford knuckles and everything out onto your Scout. This gives you 5 on 5.5 with better hubs and true D44 axle outers.
Dysfunctional Rockcrawlers
Scout Dude is offline   Reply With Quote
Old 08-29-2001, 12:16 PM   #4 (permalink)
Member # 4306
Post
Fiberglass inserts with SSII doors and mirrors. Soft top, SSII grille. Paint it fire orange.
Bedline the tub, front to rear, and seal up the underside really well. 33 gallon tank so you can get where you want to go and back without carrying gas cans.
Get the offroad package for the carb.
Don't worry. It'll fit.
http://www.ihssii.org
HooperSSII is offline   Reply With Quote
Old 08-29-2001, 12:22 PM   #5 (permalink)
Member # 4306
Post
Ooops. Forgot. Go straight to MT's, don't get AT's. MT's behave and wear well enough on the street as daily driver tread that there is no need to sacrifice the traction the MT's give, by getting AT's.
Old 08-29-2001, 12:23 PM   #6 (permalink)
R O
Member # 5921
Post
cage and winch for sure.
If I do soa I'll have cut and turn anyway,might as well go high pinion ford and switch the diff to fit scout.yes it's d44 already but what's better about ford outers?(insert ignorence here)I was thinking that since I have one set of spare axles already and can get more, I'd use scout stuff.By stock springs you mean xlc springs right?What about reverse the u-bolts and sawzall versus soa?
Old 08-29-2001, 12:32 PM   #7 (permalink)
Member # 4001
Post
Originally posted by R O:
<STRONG>cage and winch for sure.
If I do soa I'll have cut and turn anyway,might as well go high pinion ford and switch the diff to fit scout.yes it's d44 already but what's better about ford outers?(insert ignorence here)I was thinking that since I have one set of spare axles already and can get more, I'd use scout stuff.By stock springs you mean xlc springs right?What about reverse the u-bolts and sawzall versus soa?</STRONG>
You can do a spring over on the Scout axle. It would be easier. Scouts have different knuckle & hub design than the most ohters. They use 8 bolt knuckles which are rare. 8 bolt flat tops are even more rare. They also use D30 outer shafts with external bolt on hubs. Ford, Jeep & Chevy use 6 bolt knuckles and flat tops are readily available. If you go spring over, I am fairly certain that you need to go cross over steering.
Old 08-29-2001, 12:34 PM   #8 (permalink)
R O
Member # 5921
Post
about the 3.54s,I know with 33,s I'll lose some low gearing but 65mph with 31's sucks,do you think the low first gear will make up enough to avoid 4.10's.Since I've already got spares and I weld them, if they grenade who cares
Old 08-29-2001, 12:35 PM   #9 (permalink)
Member # 4001
Post
<STRONG>...(insert ignorence here)...</STRONG>
Stick around, this will be corrected soon enough (hopefully)...
Old 08-29-2001, 12:37 PM   #10 (permalink)
Member # 4001
Post
<STRONG>about the 3.54s,I know with 33,s I'll lose some low gearing but 65mph with 31's sucks,do you think the low first gear will make up enough to avoid 4.10's.Since I've already got spares and I weld them, if they grenade who cares</STRONG>
I'm still a little new on which gears are the best. I have 4.10's on mine & I run 36's. I would like to go lower though...but it works great on the freeway.
Old 08-29-2001, 12:40 PM   #11 (permalink)
Member # 226
Post
Yep, by stock springs I meant the xlc's you have on it already.
The RC44 sounds like a good plan, not required, but it would be a nice upgrade for not too much more work. The Ford outers are considered stronger because they use internal hubs instead of the bolt-on external style Scouts use. You would still use Scout inner axles, but you would have to use Ford stub (outer) axles if you used the Ford outers. The Ford outers would also make it easier to do highsteer.
SUA with u-bolt flip & major sawzall action? I guess, if thats what you want, but I doubt you could fit 33's very well with out at least 2.5" lift springs, or add-a-leafs. I prefer SOA, it works well, rides nice, and doesn't cost too much if you can do it yourself.
Old 08-29-2001, 12:44 PM   #12 (permalink)
Member # 226
Post
Sure you can use them, and change it later if you want. I ran 3.07's with 33's & an auto for a year, it sucked on and off-road, but I still got around. <IMG SRC="smilies/smile.gif" border="0"> With a T19, it wouldn't be nearly as bad.
Old 08-29-2001, 12:47 PM   #13 (permalink)
Member # 4001
Post
Hey 61Scout...What gears are you running now? You run 36's also right?
Old 08-29-2001, 12:53 PM   #14 (permalink)
Member # 226
Post
Originally posted by Scout Dude:
<STRONG>Hey 61Scout...What gears are you running now? You run 36's also right?</STRONG>
4.10's w/ 36" TSL's. Not bad with the 472, but I'd still like to go lower, maybe 4.56 or 4.88.
Old 08-29-2001, 01:00 PM   #15 (permalink)
R O
Member # 5921
Post
Okay then,I can get a rc44 fron an f250 for about $100, reverse and shorten the tubes, new mounts for the soa and use the ford ends.I've seen high steer on some scouts but I'm not really familiar with it how about some pics or writeups.
Hooper,I'll run without doors and top most of the year anyway,get a softop made at a marine shop.
Does anybody run LPG,I've got a system(425) and am considering using it on the 345 When it gets rebuilt
Old 08-29-2001, 01:01 PM   #16 (permalink)
Member # 4001
Post
Originally posted by 61Scout:
<STRONG>4.10's w/ 36" TSL's. Not bad with the 472, but I'd still like to go lower, maybe 4.56 or 4.88.</STRONG>
Yeah, I was think about 4.56's. Apparently, 4.88's have a smaller pinion. I also have an overdrive unit that bolts to my Dana 20 x-case, I think that this will help cure my freeway problems. What tranny are you running? Auto?
Old 08-29-2001, 01:39 PM   #17 (permalink)
Member # 226
Post
<STRONG>What tranny are you running? Auto?</STRONG>
Yep, TH400 auto.
Old 08-29-2001, 01:40 PM   #18 (permalink)
Member # 4001
Post
<STRONG>Okay then,I can get a rc44 fron an f250 for about $100, reverse and shorten the tubes, new mounts for the soa and use the ford ends.I've seen high steer on some scouts but I'm not really familiar with it how about some pics or writeups.
Does anybody run LPG,I've got a system(425) and am considering using it on the 345 When it gets rebuilt</STRONG>
Okay, if you are set on the Ford front go for it. However, it is already sprung over. All you need to do is shorten it. I would cut it down to your scout's width like you mentioned. It make getting replacment axles that much easier. Definitly go with the Ford outers. As for LPG, I would run it if you have access to LPG up there. It is a great system and is easy to maintain. Also, the combustion is cleaner so your engine does not have as much carbon build up. The only draw back is that there is less BTU's in LPG than gasoline--> translation, less horse power.
Old 08-29-2001, 01:42 PM   #19 (permalink)
Member # 226
Post
</STRONG>
One problem, the F250 axle is going to be 8-lug.
Heres some pictures of my highsteer, and my brother Jays. Scout II highsteer would be slightly different because of the long ass pitman arm they use.
highsteer pictures
Old 08-29-2001, 01:47 PM   #20 (permalink)
Member # 2071
Post
Who goes 65mph on 31s? I only go that slow in my pickup with the trailer on the back..
I run "Tigger" at 65-75mph. With 4.09s and 33s, and occasionally with 31s.
It's only 3000rpm give or take..
Also keep in mind wind resistance. My Scout (4" lift, soft-top, 33s) will get 15+mpg at 65mph, but 10mpg at 75mph.
-Tom
KE7VUX
tsm1mt is offline   Reply With Quote
Old 08-29-2001, 01:50 PM   #21 (permalink)
Member # 2071
Post
<STRONG>They also use D30 outer shafts with external bolt on hubs.
</STRONG>
I've never heard 'em called Dana 30 stubs before! Just because that's all J**p ever used the 27sp stubs on..
74-80 SII D44s use the 297 U-joints - even with the 27sp stubs.
-Tom
KE7VUX
Old 08-29-2001, 01:53 PM   #22 (permalink)
Member # 2071
Post
The F*rd axle will have the pumpkin on the driver's (wrong) side, so he'll have to retube it to get a right-drop.
Either that, or convert to a left-drop t'case.
-Tom
KE7VUX
Old 08-29-2001, 02:00 PM   #23 (permalink)
Member # 5982
Post
If you keep the gears, add a drop in locker to the front $200.00, don't ask me how to setup it up I fawk'd up mine. Leave the trac-don't-lock in the rear, better on street manners with all the rain you have there. Add a Tera 3:1 kit, ~$800.00. Now you have a grand into the drive train and a 70:1 crawl. Add 4" front springs ~$300.00, SOA the rear ~$100.00. 32" radial TSL's (~$800.00) fit on my Scout zero rub with 4" SkyJackers, new body mounts and 1" pucks. The TSL's are a little noisy but, 33's should fit with little to no rub. Add a cage, or rear bar if you leave the top on $250 - $500. Sell the Ford axle to offset some costs. You'll have a great low maintenance trail rig for under $2,500.00 US. That should more then get you started, and a fairly capable rig. Add $1,500 for winch, Hi-lift, recovery accessories, and other trail stuff. Nice rig for $4,000.00. Of course according to the other guys I may be full of shit. <IMG SRC="smilies/biggrin.gif" border="0">
Joe <IMG SRC="smilies/smokin.gif" border="0">
Was that a comment meant to hurt?
RU Dysfuncational http://thisdysfunctional.org/forum
jdjanda is offline   Reply With Quote
Old 08-29-2001, 02:03 PM   #24 (permalink)
Hayraker's Avatar
Member # 5946
Post
I am still running 3.54's, planning on going to 4.56 as soon as possible, however I can get around "ok" with the 727 pulled down in L1 and in low range and with the skinny pedal on the floor.
I.R.B.S.T.M.
Hayraker is offline   Reply With Quote
Old 08-29-2001, 02:04 PM   #25 (permalink)
Member # 4001
Post
Originally posted by tsm1mt:
<STRONG>The F*rd axle will have the pumpkin on the driver's (wrong) side, so he'll have to retube it to get a right-drop.
Either that, or convert to a left-drop t'case.</STRONG>
Yeah, he already mentioned having it re-tubed...
