I saw somewhere that they sell caster correctors for IN Scout Dana44's. Are these things worth the $40 +/- ?? Is there an easier/cheaper ($40 is pretty cheap if it works) way of fixing the 0 caster situation that Scout Dana44's provide?
Now before everyone goes and flames me for putting Scout axles in my Jeep YJ, remember that I got them from a junk yard and remember what would have happened to them if I hadn't have put them to SOME good use. <IMG SRC="smilies/roxy.gif" border="0">
90 YJ with 305 TPI Chevy/ SM465/ Dana20, SOA on Scout Dana44's on 36x12.50 SX's with a Lock Right in the rear visit [url]www.carolinarockshop.com [/url] today, tell em Mangler sent ya! |
Member # 5378
Every body puts em under Heeps. No offense taken. For 40 bucks, they are better than nothin! I havn't used them, but I hear they work ok. --Josh
DangerRangerRacing.com -- Want to help a "Little guy" race at King of the Hammers? |
Member # 226
Whats an IN Scout? We talk about IH's here. <IMG SRC="smilies/rolleyes.gif" border="0"> Also, whats an SM265? Is that like an SM465, but only a 2 speed instead of 4? <IMG SRC="smilies/laughing.gif" border="0">
[ 10-03-2001: Message edited by: BenW ] |
#4 (permalink) | |
Figures... I thought everyone would be up in arms about me "butchering" a Scout to build up my Jeep, and instead, everyone bitches about my typing skills... LOL <IMG SRC="smilies/rolleyes.gif" border="0"> <IMG SRC="smilies/biggrin.gif" border="0">
#6 (permalink) | |
Nope, they don't have to use them to make them work... they just need them to make them durable... <IMG SRC="smilies/biggrin.gif" border="0">
Member # 4306
Caster shims work fine. They sandwich between the perch and springs. Biggest problem is that the thicker shims are fat enough that the top of the center pin does not seat deeply into the perch. You will need to get some spacers to raise the center pin head above the shim. also, the hole in the shim is always quite large, and allows slop. I drilled mine out just enough to fit a series of flat washers in there. Those served as my spacers, as well as keeping the shim centered and in place. The shims will try to walk around on you, no matter how tight you clamp the ubolts. You might think about drilling a second small hole through the shim and into the perch, and putting another rod in that one, ground off smooth with the face of the shim. That will keep the shim from rotating around the center pin, as it likes to do.
Remember, though, putting shims in rotates your pinion downward, closer ot the rocks, and exposes your yokes. It also gives you uneven ujoint angles, although 2 to 4 degrees is not bad. You *might* still get some vibration. Better off to cut and turn the knuckle to give you caster, but that is also a lot of work. Patrick
Don't worry. It'll fit. http://www.ihssii.org |
Member # 5982
Maggie, you gotta to watch it here in IH land. A lot of people have wonder onto this board by mistake and never heard from again. Rumor is they wind up in a secure location repairing rust on the Scout tubs. Most of the IH guys cut on turn their axles, but for a heep might be a quick fix, the correctors can only correct up to ?3? degrees. So if you pointed your pumpkin up at the T-case, and wonder why the heep is all over the road, they ain't going to help.
Joe <IMG SRC="smilies/smokin.gif" border="0">
Was that a comment meant to hurt? RU Dysfuncational http://thisdysfunctional.org/forum |
#9 (permalink) | |
Member # 226
IH/Rover Moderator
NAPA them for about 18.00
Whats up with Hooper that is two days in row he got lost. You ok man? [ 10-03-2001: Message edited by: Old Scout ]
I like beer. On occasion, I will even drink beer to celebrate a major event such as the fall of communism or the fact that the refrigerator is still working." BUY MY BOAT http://www.pirate4x4.com/forum/misc-...e-history.html |
#11 (permalink) | |
I did have to put shims in the front because I put the perches on at the wrong angles (OOPS - found that out AFTER I had everything all welded up and I was too lazy to break out the grinder) http://www.cafes.net/epp/CasterCorrectors.htm These are what I'm talking about in case anyone is wondering. I've also heard that you can just get tapered washers instead, but nobody can seem to give me a part number or anything to ask for at NAPA, and my local NAPA SUCKS. If you don't come in there with a part number in hand, they look at you like a lost puppy dog. Thanks in advance! Matt
#12 (permalink) | |
Member # 4306
Lost again in shim land. Caster correctors are not going to do much. I tried 2 degree shims, didn't notice any difference at all. I suppose 3 degrees might help a little, but you gotta get up around 4 before it is noticeable. At least, that was how mine were. And, when I was fighting my caster problems 4 years ago, none of you were around to help me out, so I had to go with shims. Now, when folks talk about correcting caster, I automatically get lost in my past frustrations! Still, it was an excellent discourse on shims!!! <IMG SRC="smilies/biggrin.gif" border="0">
#13 (permalink) |
Member # 4214
I just had my pinion angle changed 9 degrees and the caster 6degrees positive. Pressed out the tubes and did what they do. Cost was not too bad but time it took them sucked ballsack.
" You may be a cunning linguist but i'm a master debator " |
#14 (permalink) | |
OK... I'm gonna sound like a newbie here for a brief second... when you say "positive caster", the top of the knuckles is further back than the bottom of the knuckle, right? So that means that you have like a 15 degree angle between the center line of the knuckle and the center line of the pinion, right? </newbie-sounding-stuff> Matt (I could sure use a Marguerita or 3 right about now... <IMG SRC="smilies/blender.gif" border="0"> <IMG SRC="smilies/blender.gif" border="0"> <IMG SRC="smilies/blender.gif" border="0"> ) [ 10-04-2001: Message edited by: ManglerYROC Z ]
#15 (permalink) | |
Member # 3511
NAPA has them ? Any idea what the part number or application is? - Found em NAPA Camber / Caster Bushing NCP2641542 $ 19.49 4 Wheel Drive;1-1/4 Degree NAPA Camber / Caster Bushing NCP2641543 $ 19.49 4 Wheel Drive;1-1/2 Degree NAPA Camber / Caster Bushing NCP2641538 $ 21.49 4 Wheel Drive;1/4 Degree NAPA Camber / Caster Bushing NCP2641539 $ 21.49 4 Wheel Drive;1/2 Degree NAPA Camber / Caster Bushing NCP2641540 $ 21.49 4 Wheel Drive;3/4 Degree NAPA Camber / Caster Bushing NCP2641541 $ 21.49 4 Wheel Drive;1 Degree NAPA Camber / Caster Shim NCP2642402 $ 21.49 4 Wheel Drive Camber 1/4 Degree Shim NAPA Camber / Caster Shim NCP2642403 $ 21.49 4 Wheel Drive Camber 3/8 Degree Shim NAPA Camber / Caster Shim NCP2642404 $ 21.49 4 Wheel Drive Camber 1/2 Degree Shim NAPA Camber / Caster Shim NCP2642405 $ 21.49 4 Wheel Drive Camber 5/8 Degree Shim [ 10-04-2001: Message edited by: old jeep ]
Chuck P The clowns'? Oh, yeah, the clowns. We fight them too — entire armies, spilling out of Volkswagons. We do our best to fight them off, but they keep sending 'em in! www.oldjeep.com |
#16 (permalink) |
Member # 6690
Hey, I want to sound like a real novice newbie for a minute (or longer) ands ask a question I am sure someone will be knid enough to put in easy newbie language for me to understand. <IMG SRC="smilies/smile.gif" border="0">
What is positive and negative caster? How does negative caster happen? What should the caster be if you want to tow your rig with out a trailer? Thanks in advance. Ritch
Fire Good |
#17 (permalink) | |
Member # 3511
#18 (permalink) |
Member # 6690
Thanks for the information, but not enough pictures. <IMG SRC="smilies/biggrin.gif" border="0"> <IMG SRC="smilies/thefinger.gif" border="0"> <IMG SRC="smilies/biggrin.gif" border="0">
Perhaps I should define my objective - What is the ideal set up for a Scout II? I am doing a SOA and want to be able to tow the truck behind my wifes rig with a tow bar. Q - What would be ideal Camber & Caster? & yes we will turn the knuckles. I know it should be positive, but how much? <IMG SRC="smilies/tongue.gif" border="0"> Ritch
Fire Good |
#19 (permalink) |
Member # 4214
I went with a SOA and 2" skyjacker lift springs and used 9 pinion and 6 positive caster. I think it depends on your lift and if you have SOA.
#20 (permalink) | |
Member # 3511
My Willys tows just fine behind my truck with 0 degrees of caster. But I think 4-6 degrees is what folks normally say is good. More with power steering less with manual. (Because the more caster you have the harder it is to turn the wheels)
#21 (permalink) |
Member # 6690
Thanks for the extra newbie info. <IMG SRC="smilies/biggrin.gif" border="0">
From what I have learned - I believe just grind off the knuckles and do it right. Ritch
Fire Good |
#22 (permalink) | |
Member # 5982
