Member # 6704
Ok, that's right... a newbie. <IMG SRC="smilies/thefinger.gif" border="0"> Bring it on!!!!!!!!
Just bought T-19 wide to replace my T-19 close. The doner for the wide box was an early '70s 3/4 ton IH 4x4. I didn't think to ask whether is was a divorce t-case or not. <IMG SRC="smilies/pissed.gif" border="0"> Now it looks like I have some "guts" transplanting to do to get the wide ratios in my Scout II w/ the D300. <IMG SRC="smilies/mad.gif" border="0"> <IMG SRC="smilies/crybaby2.gif" border="0"> Oh well, at least I didn't get burned on the price.
It's IHeavy aka TORC KC0UIC -.- -.-. ----- ..- .. -.-. Nothing is foolproof to a sufficiently talented fool. |
#2 (permalink) | |
Member # 5982
Prior to swapping anything, confirm the tranny you bought is a wide. Two ways to do it, shift it in first and turn, mark the rear shaft, you should have to turn the input shaft 6 and 1/3 times for the output to turn once. Second, better method, take the cover off, the input gear (front most gear), should be smaller than the syncro next to it. Once you have confirmed that you have a wide, you need to swap the 4wd mainshaft with the 2wd mainshaft. Search the IH board on how to do this, not trying to be an ass I just don't want to retype it. Joe
Was that a comment meant to hurt? RU Dysfuncational http://thisdysfunctional.org/forum |
#3 (permalink) | |
Member # 6704
Already confirmed that its a wide. It takes 6+ turns of the input shaft to get one turn of the output shaft while in first gear. I knew not to get the 2wd T-19 from reading other posts and specifically asked it was in a 4wd truck. It was, but what I didn't know was that 3/4 ton IH's (or at least this one) had divorce mount np205 t-case. <IMG SRC="smilies/mad.gif" border="0"> Just when I thought I had my bases covered, I get bit in the arse...... <IMG SRC="smilies/nuke.gif" border="0">
#4 (permalink) | |
Member # 5982
Joe
#5 (permalink) | |
Member # 6704
Member # 6704
Ok, this might be a dumb question, but after reading some other post on this board, it seems that IH also used T-98 with a divorced np-205. How can I tell if what I have is a T-19 or a T-98?
I can't find the article about swapping the mainshafts but I do have the Scout service manual to fall back on. Now is the mainshaft the only one I need to swap? Are the other two shafts set up the same in a wide vs. close box?
Member # 5982
It's got a reverse light, it should be a T19, the, if you pull the cover and take a pic I can tell you for sure.
Joe
#9 (permalink) | |
Member # 6704
Member # 7581
The easiest way to tell a T-19 from a T-98 or T-18 is the position of reverse. Reverse on a T-19 is left(?) and down, T-98 and T-18 is right(?) and up.
If the 300 is originally out of a scout it is the texas pattern, while the heep 300 has the round 6 bolt pattern. With it being behind a manual, I would almost garantee it is the texas bolt pattern. There is only 1 company to my knowledge that ever made an adapter for the heep 300 to go behind an IH manual tranny. [ 10-26-2001: Message edited by: makkat ] |
#11 (permalink) | |
Member # 6704
It clearly says T19 [ 10-26-2001: Message edited by: TORC ]
#12 (permalink) |
Member # 3563
I'm in the exact same boat. I have a 4x4 close T19 and a wide T19 from a 75 IH 3/4 ton 4x4. I don't do gear stuff so I gave the trannies to a buddy for a rebuild. From my research I'd recomend you put the guts into the 4x4 case to save you from having to tap the 3/4 ton case for the 4x4 adapter. Good luck
Travis
Amatuer driver on open course, try this at home. |
#13 (permalink) | |
Everyday is Tuesday.
Member # 47
And for anyone really interested, I've got a line on a Scout 300 as well... traded it to a buddy who'd part with it for a reasonable amount. |
#14 (permalink) | |
Member # 5982
JOe
#15 (permalink) | |
Member # 6704
Since my Scout is a 1980, I was lucky enough to have the D300 from the factory.
#16 (permalink) |
Member # 47
I was thinking 300 as is for the tranny -- disassembled. But make me an offer... it's been in my buddy's garage for close to a year and I could use some cash...
The 300 isn't mine, but I'll see if I can get a price. I'd guess it will be around 500, but not sure. And I know they're kinda rare... but not nearly as rare as the bellhousing to mate it up to an AMC engine... I've got one for the early I6 as well as the later one. <IMG SRC="smilies/rolleyes.gif" border="0"> I'd let those go too. I'm building a Jeep, and was gonna go AMC 360, IH T19, IH Dana 300 with a 44 front. But I got a hella deal on a ford RC 60 front, and didn't want to deal with swapping the front over to a passenger side drop. So, I scrapped the IH route. [ 10-28-2001: Message edited by: Mo ] |
#17 (permalink) |
Member # 6704
Anybody know where to get a tranny bearing puller to yank the output and input shaft bearings on a T-19? Found one here but it only has a reach of 9.25". The IH T-19 input shaft has a stick-out of 10.5". Can't find one with enough reach.
#18 (permalink) | |
Anyone actually want to pay $500 for a wide T19? MARRIED style? Got one sittin' right here, just taking up space... <IMG SRC="smilies/biggrin.gif" border="0"> :P Naturally, I scored that after I paid $400 at the junkyard for the one in my grey '77 (OK, so for $400 I took the entire Scout it was in..)
-Tom KE7VUX |
#19 (permalink) |
Member # 5982
Here try this puller
<IMG width=212 height=220 SRC="http://www.pirate4x4.com/ubb/uploads/hydraulic_puller.jpg"> I figure any puller that needs it own cart ought to get the job done.
