Brake and Gas pedal assembly - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-08-2001, 01:35 PM   #1 (permalink)
Member # 4214
Post Brake and Gas pedal assembly
Anyone have any good pics of a scoutll with an auto. I need a pic of the brake pedal and gas pedal assembly. A good pic if possible.
" You may be a cunning linguist but i'm a master debator "
Brawler is offline   Reply With Quote
Old 10-08-2001, 01:44 PM   #2 (permalink)
Member # 4306
Post
Originally posted by Brawler:
<STRONG>Anyone have any good pics of a scoutll with an auto. I need a pic of the brake pedal and gas pedal assembly. A good pic if possible.</STRONG>
You want a pic of the floorboard area, or the engine bay?
Don't worry. It'll fit.
http://www.ihssii.org
HooperSSII is offline   Reply With Quote
Old 10-08-2001, 03:28 PM   #3 (permalink)
Member # 4214
Post
Originally posted by Hooper:
<STRONG>You want a pic of the floorboard area, or the engine bay?</STRONG>
Floorboard area,sorry.
Old 10-08-2001, 03:55 PM   #4 (permalink)
Member # 4306
Post
<STRONG>
[qb]You want a pic of the floorboard area, or the engine bay?</STRONG>
Floorboard area,sorry.[/QB]
Don't have one right now. Someone with a digital will be able to snap one for you though.
Old 10-08-2001, 04:17 PM   #5 (permalink)
Member # 5982
Post
It is the same as the manual setup minus the clutch pedal, and a wider brake pedal, best I can tell, I have one of each. Also no hole for the clutch rod, but that is more or less a knock out. What are you looking for specifically, I can compare my two assemblies and let you know where the difference is. All you would see if I took a pic would be two pedals, gas and brake <IMG SRC="smilies/biggrin.gif" border="0">
Joe <IMG SRC="smilies/smokin.gif" border="0">
Was that a comment meant to hurt?
RU Dysfuncational http://thisdysfunctional.org/forum
jdjanda is offline   Reply With Quote
Old 10-08-2001, 04:47 PM   #6 (permalink)
Member # 4214
Post
Originally posted by jdjanda:
<STRONG>It is the same as the manual setup minus the clutch pedal, and a wider brake pedal, best I can tell, I have one of each. Also no hole for the clutch rod, but that is more or less a knock out. What are you looking for specifically, I can compare my two assemblies and let you know where the difference is. All you would see if I took a pic would be two pedals, gas and brake <IMG SRC="smilies/biggrin.gif" border="0">
Joe <IMG SRC="smilies/smokin.gif" border="0"></STRONG>
I need to get a set-up for mine and was wondering if i wanted to use stock or not. I thought the pedals came in some sort of case that bolts to the floorboard.
Old 10-08-2001, 08:03 PM   #7 (permalink)
Member # 2145
Post
How does the knock out come out? Do you take a chisel or air hammer to it, or hammer it from underneath to get it out? Sorry for the stupid question by the way. <IMG SRC="smilies/rolleyes.gif" border="0">
Thanks,
Mark
'79 Scout II 345 w/ Projection, 3.73,Lockright in rear, 4" Triangle springs, 32x11.50 BFG M/T's.
'99 Chevy Z71 5.3
mkeown is offline   Reply With Quote
