Daily Topic - Winch mounting - 11/01 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-01-2001, 12:08 AM   #1 (permalink)
Member # 5982
Post Daily Topic - Winch mounting - 11/01
Well? How'd you do it.
Personally here's the pic
<IMG width=289 height=289 SRC="http://www.pirate4x4.com/ubb/uploads/JD-Winch.jpg">
The winch is mounted to 3/8" plate. From the side two C's are formed from 2x.250 and 2.5x.250 angle Holes are drilled in the top with a Grade 8 thought the holes and frame, just like the factory setup. 1 additional forward facing hole per C on the lower portion, plus a centered lower bracket with two forward holes allow 4 bolts through the front on the frame, back with a 1/4" plate. Let's just say you can fly my Scout out of a canyon by the front bumper.
Had I to do it over, I would have moved the plat up on top of the frame rails, and moved the winch back. Also I would have built a better mount for the roller fairlead.
BTW I have the plans in Auto CAD, I need to convert to image. Let me know if you want a copy.
Joe
Was that a comment meant to hurt?
RU Dysfuncational http://thisdysfunctional.org/forum
jdjanda is offline   Reply With Quote
Old 11-01-2001, 05:51 AM   #2 (permalink)
Member # 6181
Post
I bought one of those generic multi-mount style mounts... for my 8000 lb Warn. I then cut a 2" hole in the dead center of the front crossmember of the frame, and took a piece of 2" square tubing and welded it in REALLY good, and Whalla! You have a front receiver hitch. As soon as I get the bobbing and stuff done on my Scout I plan on doing the same by adding another rear crossmember and getting some power quick disconnects from NAPA and I'll have the ability to go from front or back.
ScoutsHonor is offline   Reply With Quote
Old 11-01-2001, 06:32 AM   #3 (permalink)
Member # 4758
Post
I went the multi-mount route. I've got a receiver hitch welded and gusseted on top of the front bumper. The bumper is C shaped around the front crossmember out of overlaping pieces of 3"x1/4" angle.
I made the winch plate out of 1/4" plate (don't know what kind of steel it is, but it's WAY harder to drill through than normal stuff, some kind of hardened stuff anyway) and built a mount for the roller farelead.
For wiring, I mounted the remote solenoid box in the cab and ran welding cable to each end with welding quick connects for the plugs.
Zane Znamenacek is offline   Reply With Quote
Old 11-01-2001, 06:56 AM   #4 (permalink)
Member # 4001
Post
I haven't mounted mine yet...I wasn't even planning on getting one yet (I was already to buy my 35spline axles) and my buddy asked if I wanted to buy his winch (he doesn't wheel his J-Truck) It is a Warn 8000 with controller, fairlead, mounting plate, and leather (Pleather?) cover all for $300.
Now back to why it isn't mounted yet...I currently have a Ford 2wd P/S box the mounts inside the frame to the stock mount. I picked up a YJ mount and box (4-bolt,76 casting) that I am going to mount up instead of the Ford thing. Once I get the box mounted, then with what ever room is left over, I will tuck the winch up there. This is behind the grill, but before the radiator. For those who are not familiar with the 4 cyl 80s, they have a large gap between the two. Here is a pic:
<IMG width=640 height=480 SRC="http://www.pirate4x4.com/ubb/uploads/Winch location.jpg">
Dysfunctional Rockcrawlers
Scout Dude is online now   Reply With Quote
Old 11-01-2001, 08:02 AM   #5 (permalink)
Member # 6690
Post
Originally posted by jdjanda:
<STRONG>BTW I have the plans in Auto CAD, I need to convert to image. Let me know if you want a copy.
Joe</STRONG>
Joe,
I would like to get a copy of that design. Since I will be fabrication my bumpers and other parts like Nerfs and skid plates where needed, I like anything I can use as a basis.
I want a sort of prerunner/heavy-duty close to the grill kind of mount. Something that is small, light and strong.
Ritch
Fire Good
nwmud is offline   Reply With Quote
Old 11-01-2001, 08:52 AM   #6 (permalink)
somedumbkid's Avatar
Member # 3108
Send a message via AIM to somedumbkid Send a message via Yahoo to somedumbkid
Post
i welded some 2x3 angle to the frame and a 1/2 plate to the angle mounted my xd9000i to that it has out lasted everey thing else on the truck and did a lot of damage to a mercadies benz
1993 YJ under going a change
somedumbkid is offline   Reply With Quote
Old 11-01-2001, 11:22 AM   #7 (permalink)
Member # 4306
Post
Need to do a better job of fastening it all to the cross member, but it has held up to some really heavy pulls without coming off, so I think it is on there pretty good.
I do have a bit of approach angle issue, but that is not the winch, as much as it is the brush guard/push bar.
Don't worry. It'll fit.
http://www.ihssii.org
HooperSSII is offline   Reply With Quote
Old 11-01-2001, 11:34 AM   #8 (permalink)
Scoutillac's Avatar
Member # 1694
Post
Hey Patty!!!!! Fix your avitar!!!!!! C'mon <IMG SRC="smilies/thefinger.gif" border="0">
The hammer of the gods will drive our ships to new lands
Scoutillac is offline   Reply With Quote
Old 11-01-2001, 11:36 AM   #9 (permalink)
Member # 5729
Post
To mount the winch on one of my rigs I started with a Rhino grill guard. I fabed up to pieces of 1/4" 2x2 angle that bolt up to the frame in three places. Front bumper bolt, gusset bolt and one further back. For the first and last bolt I used the same method IH used to mount their step bumpers, ie putting the bolt through the frame with a pipe to keep from crushing the frame. The Rhino grill guard bottom plate is not deep enough to mount a winch so I made a new one that sticks out enough to mount the winch I had. Then I cut off the bottom mounting part of the grill guard and welded each side to the 2x2 angles I made.
Here's a link to a pic of it
http://scoutswest.com/images/bizarre...et_tow_gif.htm
[ 11-01-2001: Message edited by: ScoutZilla ]
SSII GTX
Got torque?
Scoutzilla is offline   Reply With Quote
Old 11-01-2001, 11:37 AM   #10 (permalink)
Scoutillac's Avatar
Member # 1694
Post
Here is mine on a factory warn bumper <IMG SRC="smilies/biggrin.gif" border="0"> And yes that is a <IMG SRC="smilies/beer.gif" border="0"> in my hand <IMG SRC="smilies/thefinger.gif" border="0">
Old 11-01-2001, 11:52 AM   #11 (permalink)
Member # 4306
Post
Originally posted by Scoutillac:
<STRONG>Hey Patty!!!!! Fix your avitar!!!!!! C'mon <IMG SRC="smilies/thefinger.gif" border="0"></STRONG>
I did. Board keeps changing the rules. It worked yesterday just fine.
Can't get a 100 x 100 image down to less than 5K. Still working on it, but I pulled the image for now.
Old 11-01-2001, 12:01 PM   #12 (permalink)
Member # 226
Post
Originally posted by Hooper:
<STRONG>
Can't get a 100 x 100 image down to less than 5K. Still working on it, but I pulled the image for now.</STRONG>
Make sure the resolution is 72 DPI, and bump the compression up a little bit. Or, post the pic and I'll do it for you.
Ben W is offline   Reply With Quote
Old 11-01-2001, 12:15 PM   #13 (permalink)
Member # 4306
Post
Originally posted by BenW:
<STRONG>Make sure the resolution is 72 DPI, and bump the compression up a little bit. Or, post the pic and I'll do it for you.</STRONG>
I can get it down to 8K, but can't get below that.
Old 11-01-2001, 12:36 PM   #14 (permalink)
Member # 226
Post
Here ya go. 3.96KB
<IMG width=100 height=100 SRC="http://www.pirate4x4.com/ubb/uploads/hoop.jpg">
Old 11-01-2001, 12:54 PM   #15 (permalink)
Member # 4306
Post
<STRONG>Here ya go. 3.96KB
<IMG width=100 height=100 SRC="http://www.pirate4x4.com/ubb/uploads/hoop.jpg"></STRONG>
Thanks Ben.
Old 11-01-2001, 01:18 PM   #16 (permalink)
Mechanos's Avatar
Member # 6704
Post
Joe</STRONG>
E-mail me a copy. Either send the .dwg or export it to a .dxf. I use Microstation, but I can read either format. Thanks.
It's
IHeavy
aka TORC
KC0UIC
Nothing is foolproof to a sufficiently talented fool.
Mechanos is offline   Reply With Quote
Old 11-01-2001, 01:32 PM   #17 (permalink)
Member # 4239
Post
Haven't mounted mine yet, haven't got stuck bad enuff yet. I have a brand new in the box XD9000i that my parents bought for me as a graduation gift 4 years ago and it's still sitting in my room. They keep getting on me about them spending the money for it and me not even mounting yet.
TERRA-IZER is offline   Reply With Quote
