#126 (permalink) |
Member # 135020
The wheel mounting surface to wheel mounting surface with spacers on my axle is 59.5".
And 800B I cut the frame in an L shape if you flip it backwards and clock it counter clockwise 90 degrees. I added 1/4" plate to where I cut then added in my spring hanger. then built 1/4" plate on the sides of the frame. then I added a crossmember in between the spring mounts for more strength then I added the brace on my mini boat side slider deal for a little more strength I'll try to add some more pictures tonight.
My name is Lance and I party. |
#127 (permalink) |
Member # 135020
Ok actually got a ton of work done between fri night and sat night and lots of beer drank
![]() Fri night I got the 2rz stand alone engine wiring harness finished up and ready to be installed in the scout ![]() By mudmainac3 at 2012-03-04 then saturday morning got it all loaded on the trailer picked up a buddy and his welder then took it out to another buddy's shop to get it into the shop well we started with welding the front suspension and steering stuff up and then a front stinger and shock hoops bent we may have combined them for a bit haha ![]() By mudmainac3 at 2012-03-04 got the guys lookin at it more than workin haha ![]() By mudmainac3 at 2012-03-04 then somehow we had a shop party start off ![]() By mudmainac3 at 2012-03-04 ![]() By mudmainac3 at 2012-03-04 Well somehow with all the beer being consumed we had my buddy weld everything in for suspension and what not and a few of us started on the roll cage ![]() By mudmainac3 at 2012-03-04 ![]() By mudmainac3 at 2012-03-04 ![]() By mudmainac3 at 2012-03-04 ![]() By mudmainac3 at 2012-03-04
#129 (permalink) |
Member # 135020
Yes the top does fit with cage in but I'm gonna have to notch the top in a few area's.
Well the party started happenin I sobered up and took the ol gal home and I guess when I left my buddy took his 4runner out into the mudhole in the back feild and blew his motor or somethin ha. well here is some of what we got welded the hitch is all in now ![]() By mudmainac3 at 2012-03-04 got rear shock mounts, diff armor, bumpstops all welded in and also got the rear shocks installed ![]() By mudmainac3 at 2012-03-04 also got the mini boat sides in ![]() By mudmainac3 at 2012-03-04 and got the frenched in rear spring mounts all welded in plated in and crossmember tied in and ready to go ![]() By MUDmainac3 at 2012-03-04 I'm still blown away at how much work we got done and how well everything turned out with as much alcohol was consumed all I know is I hate hangovers >
#131 (permalink) |
Member # 135020
ha I know I had the factory front driveline out of the girl friends 4runner and the splines touch but its to short and i left it for mock up purposes. probably gonna make one this week got some schedule 40 out of my old truck super thick and worked great
#132 (permalink) |
Member # 135020
ok did a little tinkering around jacked the truck up on the high lift just messing
![]() By mudmainac3 at 2012-03-08 ![]() By mudmainac3 at 2012-03-08 ![]() By mudmainac3 at 2012-03-08 The front fenders may require some trimming ![]() By mudmainac3 at 2012-03-08 rear tires tuck perfectly ![]() By mudmainac3 at 2012-03-08 I fixed my steering column and installed it just need to add an extra brace to it under the hood ![]() By mudmainac3 at 2012-03-08 then I installed all my shifters ![]() By mudmainac3 at 2012-03-08 Then I painted the cases and trans chrome for some bling haha ![]() By mudmainac3 at 2012-03-08 I just love the old school look ![]() By mudmainac3 at 2012-03-08
#133 (permalink) |
Member # 135020
well didn't get much done this week or weekend. Had a tooth pulled wednesday so left me pretty under the weather. but cleaned around the house and alot in the shop. also picked up a sweet roof rack
![]() By mudmainac3 at 2012-03-11 ![]() By mudmainac3 at 2012-03-11 also went to the 4x4 swap meet up in puyallup and picked up some new stickers didn't really find anything i needed ![]() By mudmainac3 at 2012-03-11 ![]() By mudmainac3 at 2012-03-11
#134 (permalink) |
Member # 135020
ok well I got a little bit of stuff done.
mainly I got my cluch kit in the mail today ![]() By mudmainac3 at 2012-03-21 Ok well I've been skinning my tunnel and remodeling it. ![]() By mudmainac3 at 2012-03-21 don't know if I posted this but I had to cut the glove box to be able to open it around the cage. The sucky part was I put all my safety glasses in my glove box prior to puttin the cage in ha lame. ![]() By mudmainac3 at 2012-03-21 Hopefully getting more work done this weekend
My name is Lance and I party. Last edited by MUDmaniac3; 03-21-2012 at 09:09 PM. |
#136 (permalink) |
Member # 16680
nice sliders.
94 Mall Rated Bronco-R.I.P. 1961 Scout 80 stretched and linked wt4x4.com PM me for CPR/First Aid Instruction for you club |
#137 (permalink) |
Member # 135020
thank you I stole the slider idea and yeah i knew I was gonna have to cut it but didn't really think about all my safety glasses being in the glove box. but ohwell. got some work done this weekend
ok well I picked up a radiator from leadfoot last weekend so I got around to test fitting and mocking it up this weekend. ![]() By mudmainac3 at 2012-03-25 ![]() By mudmainac3 at 2012-03-25 ![]() By mudmainac3 at 2012-03-25 Just an FYI when you weld something remember the said part is still very hot. and will burn you causing you to squeal like a girl and may even spit out a profanity or two. just an FYI > ![]() ![]() By mudmainac3 at 2012-03-25 oh and the best part about burns is that they keep hurting for quite awhile after you hurt yourself. :o well got a little more done on the tunnel is basically done now just gotta add some paint ![]() By mudmainac3 at 2012-03-25 I also built rear drivelines for the scout actually made 2 out of my old one out of my old toyota. its 3" schedule 40 fits perfect ![]() By mudmainac3 at 2012-03-25 its pretty thick stuff ![]() By mudmainac3 at 2012-03-25 here are the 2 drivelines all done and welded up ![]() By mudmainac3 at 2012-03-25 well decided to dive into some wiring today and got my tach put in ![]() By mudmainac3 at 2012-03-25
#139 (permalink) |
Member # 135020
ok well I took my flywheel in to get resurfaced today and got it back this evening all done
![]() By mudmainac3 at 2012-03-26 I also mounted up some reverse lights where the stock shocks would have mounted up. they fit pretty good. probably get messed up in deep snow or mud but we will see. not a very good cell phone pic but if you look close you can see them on the inside of the shocks ![]() By mudmainac3 at 2012-03-26
#140 (permalink) |
Member # 135020
ok did a little work after we went to browns camp I am remotivated.
So got a better picture of my reverse lights ![]() By mudmainac3 at 2012-04-03 Then I installed my fairlead next just gotta do the winch ![]() By mudmainac3 at 2012-04-03 Then I started to install my clutch and flywheel ![]() By mudmainac3 at 2012-04-03 then fought the trans and cases back in which is a pain as a unit by urself ![]() By mudmainac3 at 2012-04-03 I also installed my rear third and axle shafts. I had a broken one in for a roller and since I broke the third in the gf 4runner didn't want her to talk me into putting it into her truck so I put it in mine haha. ![]() By mudmainac3 at 2012-04-03 Then I tossed the rear driveine in ![]() By mudmainac3 at 2012-04-03 ![]() By mudmainac3 at 2012-04-03 Oh then the girl friend got me a sticker ![]() By mudmainac3 at 2012-04-03
#141 (permalink) |
Member # 135020
Well did a little work tonight almost have the tunnel all done just to drill the holes and bolt it down and add my shift boots to them
![]() By mudmainac3 at 2012-04-04 ![]() By mudmainac3 at 2012-04-04
#142 (permalink) |
Member # 135020
ok well did some work today. got the tunnel all done sealed and painted.
![]() By mudmainac3 at 2012-04-07 I then removed the fuel tank got the stupid locking gas cap I don't have the key for removed drained the old fuel and drilled the holes for the gas tank to be mounted along with starting my rear crossmember braces ![]() By mudmainac3 at 2012-04-07 ![]() By mudmainac3 at 2012-04-07 ![]() By mudmainac3 at 2012-04-07 ![]() By mudmainac3 at 2012-04-07 ![]() By mudmainac3 at 2012-04-07
#143 (permalink) |
Member # 135020
ok and with the nice weather I figured I would get some time consuming work out of the way on the front and I finally finshed my frame tubes
![]() By mudmainac3 at 2012-04-07 ![]() By mudmainac3 at 2012-04-07 ![]() By mudmainac3 at 2012-04-07 ![]() By mudmainac3 at 2012-04-07 Well to get the suspension done I had to jack up the truck and some how my floor jack grew feet and walked away so Highlift jack to the rescue but the suspension is to soft and I couldn't find a strap at first ![]() By mudmainac3 at 2012-04-07 Then I had figured a way to make my shocks clear the frame just had to do a little notching on the frame ![]() By mudmainac3 at 2012-04-07 ![]() By mudmainac3 at 2012-04-07 ![]() By mudmainac3 at 2012-04-07 Shockingly they clear ![]() ![]() By mudmainac3 at 2012-04-07
#145 (permalink) |
Member # 135020
I saw that I don't know what I'm gonna do about it. probably just not worry about it and let it rub haha. May just have to pull the shim back out and deal with a not so great pinion angle but we will see. stock high steer for a toyota is smaller tube by about 3/4 of an inch but ohwell. I'll have to sleep on what I wanna do. probably end up with a smaller shim or none.
But here is more progress well I got more work done today. completely finished the transmission tunnel ![]() By mudmainac3 at 2012-04-08 I also remade my radiator mount even after I burn't myself ![]() By mudmainac3 at 2012-04-08 then I installed it ![]() By mudmainac3 at 2012-04-08 ![]() By mudmainac3 at 2012-04-08 I then I broke off the stock bulkhead connector for the wires into the body and I installed the engine wiring throught the hole worked perfect. ![]() By mudmainac3 at 2012-04-08 My buddy painted this peice of my door so I installed it haha ![]() By mudmainac3 at 2012-04-08 I then built my shock hoops for the front ![]() By mudmainac3 at 2012-04-08 then I installed them and my shocks ![]() By mudmainac3 at 2012-04-08 Now the suspension is completed ![]() By mudmainac3 at 2012-04-08
#146 (permalink) |
Registurd Abuser
Member # 34995
Looks good, getting closer
Have you thought about a spacer to raise the tie rod for more clearance? shouldn't take much. If so, will the drag link contact the tie rod?
#147 (permalink) |
Member # 135020
thats pretty much what i'm gonna do but will be a plate welded across the entire top of the high steer arm so it will space both evenly
#148 (permalink) |
Member # 135020
ok I'm set on getting this done so worked on it again after work tonight. I started to install the dash harness and discovered mounting the ECU will kinda be a pain in the butt but I think I figured it out just gotta make a mound for the ecu.
I also went and wired the tail lights forward past the rear shocks so I could remount my fuel tank for the final time. (I hope) ![]() By mudmainac3 at 2012-04-09 ![]() By mudmainac3 at 2012-04-09 Oh and I also topped off the gear oil in the front and rear end so I wouldn't forget. And people keep asking me why my scouts not done yet well its all the little projects that take forever like my winch. Yes I could have just installed it but thats not the way this rig works so I had to do something to it so I customized it. bet you've never seen one like this before ![]() By mudmainac3 at 2012-04-09 ![]() By mudmainac3 at 2012-04-09
#150 (permalink) |
Member # 135020
ok went and did a little work this week bought the a brake master cylinder for a 1978 grand marquis with drum brakes in the rear not disc. also went and bought the clutch master cylinder which is for a 1985 dodge d50 it pretty much bolts up and has the same stroke as stock but has metric lines so will bolt right up to the 3rz slave cylinder. I also bought some oil so I don't forget the motor does not have oil in it.
Then I went to the steel yard and got some receiver tubing to make my front driveline. and got it all built ready for paint and install ![]() By mudmainac3 at 2012-04-13 ![]() By mudmainac3 at 2012-04-13 pictures don't show it welded but it is as of tonight and it will just be temporary just to get it on the trail and then will be my spare. well its the weekend so will definately get some work done on this hog. oh and it definately is long there is 3 feet of square tube on each peice of the driveline. I will have to shorten it a little bit but not a whole lot. flange to flange is 46''
