#427 (permalink) |
Member # 185323
havent done much else to it besides fix some small bugs, and started working on the rear drawer system/bed. first time out:
1988 Ramcharger: 5.2, 4x4, 4spd. 1992 Trooper: DOHC 3.2, 4x4, auto. |
#429 (permalink) | ||
Member # 5587
For you 1st Gen guys let me kick start your brains. Don’t blame me if you don’t get any sleep tonight. So you want a Snorkel? Here’s what I came up with on an old body I had laying around. I tried it here before I mess up a working truck, since it was a rather evasive idea. And yea, I've done this to several Troopers but none are her to show you the finished product. Use your imagination! This system uses the stock 2.3 L air cleaner but reroutes the air intake. Here’s the stock one. ![]() ![]() Not real hard to do. See the hose piece on the left. Go to the junk yard and grab another one. IIRC this one is off a 3.2 L V 6, but even the 2.3L breather tube will work, off a 2.3L engine. You just have to cut the oval air cleaner part off. See the hole where it comes out? I used some door trim to protect it from cuts from the sheet metal. The only thing you'll have to do if you have airconditioning is move the plumbing down for clearance. ![]() I used a 3 inch hole saw to make these holes. Bore your firewall just left of the hood hinge and into the washer arm cover plate. You will need to make an “L” bracket, sorry I don’t have a picture of it, to screw to the bottom of the air box hole to act as a limiter to keep the hose from interfering with wiper arm arc. You’ll figure it out, it’s not rocket science. The breather hose is very flexible so it’s not going to bother it to have the bend in it. I used a piece of angle iron about 1 inch wide to make the “L” bracket. ![]() The breather hose does not interfere with the hinge so don’t worry about that. But it will interfere with the wiper arm, so be sure and use the “L” bracket. You can screw it down with a metal screw by accessing through the big top hole you drilled in the body top. You’ll have to figure out where to put the “L” bracket so you have clearance. ![]() Then you can use a piece of exhaust tubing up the windshield frame and top it off with what ever floats your boat. Let me give you an idea for the top hat that is easy and cheap. Get a stainless Dog bowl and make some bracket to attach it with some screen to keep the birds out of it. In case you’re wondering, with this set up you will be using the stock air cleaner. Just rerouting the intake to the firewall and out to the snorkel. Just thought I’d throw this out in case some of you want a snorkel, but don’t have $500 lying around. On mine I made my HAT removable so I could take the tall tube out and put the hat on low in front of the wndshielld like on the H1 Hummers. (So don't go crazy with the dog bowl size if you're going to use this idea!) Then the taller tube stored under the seat for high water fording. Pop some nut serts on the windshield post for quick removal. Plug them with the bolts to keep water out of your post. Clear as MUD?
The upside of a fresh scar: it gives you something to talk about at wedding receptions. |
#432 (permalink) |
Member # 23507
I guess it's time I post a few pics....I never have.
Here is my '97 Rodeo. ![]() ![]() ![]() I've been wheeling that for the past 10 years or so...modifying along the "standard" lines...3" sl, then 3" bl, 33's, etc. I've only ever broken a stock tie rod. I recently bought this for a steal. It needs some work, but overall, for the price, it's awesome. 96' Rodeo ![]() ![]()
#434 (permalink) |
Member # 124902
some updated Passport pics, working on finding an axle to slap under the front
99 Vehicross and 97 Rodeo: built but gone :( 1995 Honda Passport:lifted, locked, 34's and more |
#435 (permalink) | |
Member # 162148
#436 (permalink) |
Member # 124902
I live in Panama City, FL but I'm looking for a passenger side drop axle
#437 (permalink) | |
Member # 129234
#438 (permalink) |
Member # 124902
You have my HD Bars in your truck
and I know about the passenger drop Waggy diff, that's what I want to find. I did come across a set of 1 tons near by but I don't know if I want to go that route
#440 (permalink) |
Member # 124902
I've been considering it, but I really don't plan on going much bigger than a 37" tire, and 1 tons will soak up alot of clearance, probably be about as much as I have now with 34's. Honestly my IFS has gotten me through everything I've wanted (when it's all working lol) and I keep debating with myself if I should just leave it. It's not my DD, it's just a cheap playtoy. I have maybe $1500 in the whole thing including purchase so I've tried to keep the mindset that it's just a fun toy. My other ones were in great shape and I was less likely to do stuff that risked body damage lol.
#443 (permalink) | |
Member # 5587
Care to elaborate on the back glass? Like where did you source it? I'm about to start my stretch my 4 door 89 project by splicing in a 2 door rear bed section to make a honest to God Crew Cab Trooper Pickup. It will be 29 inches longer when I'm don and all 4 doors will open. I have a Zu Pickup slider rear window but it is going to need to be shortened a few inches. Yours looks clean! I like how the front axle fits in there too. I've SAS'ed my Rodeo but it's tall. Got a Build Thread?
#446 (permalink) |
Member # 124902
Thanks alot, she's been my cheap playtoy. Looking back at those pics I debate if I should have cut the top like I did lol
His is still IFS
#447 (permalink) |
Member # 161731
I know that but most of the SAS swaps Ive seen, and this is personal opinion, look like garbage. The Trooper looks goofy as hell with a huge amount. If 35s fit like that with 3" of lift, I think if I could figure out about 4" with a SAS keeping it the same height, I would be very happy.
#448 (permalink) | |
Member # 124902
![]() I'm with you on the SAS swaps that have a ton of lift and running 35's. If it's going to have a huge amount of lift then match the tires. I think alot of people do it that way because if your going to stay low and on 35" or smaller tires, the IFS will get you by pretty good with slightly better front clearance. But the SAS will get you more flex/stability on most obstacles. I'm going to be keeping mine fairly low as well.
#449 (permalink) |
Member # 129234
Personally if the troop ever gets to that point of a SAS. I would just cut to fit to keep it low. My trooper has trimmed front fenders and the rear is going to cut to. I also don't like 35's on SA rigs, go with 4d's or go to the mall!
#450 (permalink) | |
Member # 79551
no build thread the rear cap is the stock tropper roof cut and modded to fit the rear window is from a toyota p.u. i made the panel to hold it at work. I like the sounds of your crew cab build that would be a great time with all your buddies in it. chopped about a foot of the back of the truck heres what she looked like this weekend.
