Zuzu D44 Question... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-16-2003, 01:09 PM   #1 (permalink)
That Mick's Avatar
Member # 7430
Are the 4.30 thick ring R&P sets compatable with the standard D44 pumpkin?
I ask, because I've got access to a set or two of the 4.30's and a 3.xx series Detroit.
Looking to put them in a mild Scout.
"Man, your playlist has Merl Haggard and Megadeth- You're like the Hillbilly From Hell!!"
That Mick is offline   Reply With Quote
Old 06-16-2003, 01:14 PM   #2 (permalink)
technical expert
Independent4x's Avatar
Member # 8755
Send a message via AIM to Independent4x Send a message via MSN to Independent4x Send a message via Yahoo to Independent4x Send a message via Skype™ to Independent4x
yeah, never thought of that, but that should work
huh....excellent crossover application
Matt, Owner: Independent4x
www.independent4x.com
804-550-0480: 9am-6pm EST
UFWDA Life Member - http://www.ufwda.org/
Full Service Fabrication Shop & Retail Store located in Richmond, Va. for all your OffRoad needs: featuring Sway-A-Way, WARN, ARB/OME, AEV, Advance Adapters, TeraFlex, Trailready, Currie, QA1, Beard Seats, Interco Tire, D.O.M. Tube to length, etc. - call or PM
Independent4x is offline   Reply With Quote
Old 06-16-2003, 01:32 PM   #3 (permalink)
Member # 14570
as long as you use the carrier that the gears came on.
Hickeyjones is offline   Reply With Quote
Old 06-16-2003, 01:43 PM   #4 (permalink)
That Mick's Avatar
Member # 7430
So the Zu 4.30's won't work with a normal 44 3 series detroit?
Old 06-16-2003, 02:22 PM   #5 (permalink)
Member # 8110
Send a message via ICQ to RodeoRob Send a message via AIM to RodeoRob
In theory, yes. but i don't know if anyone has actually tried this cross application yet. definitely report back if you give it a shot.
-Rob
RodeoRob is online now   Reply With Quote
Old 06-16-2003, 02:28 PM   #6 (permalink)
technical expert
Member # 8755
since the factory carrier is a low numericaly low carrier.....His question is will it work on another low ratio carrier.
i am saying Yes.......that theoretically he is thinking along the right lines.
it "should" work
Old 06-16-2003, 03:28 PM   #7 (permalink)
Member # 6980
Send a message via AIM to ZooMigo
I can guarantee the rings fit other carriers.
I have the ARB RD07 (3.73 and down) carrier in the rear of my Amigo with the Isuzu 4.30 gears on it.
Went in no problems at all.
Kevin
ZooMigo is offline   Reply With Quote
