Member # 19557
This weekend I'm putting on a small 1" BL and some boulder bars and need to get some new hardware for the body mounts. Anyone know what bolt lengths I will need and for what locations? I was thinking that I could possibly swap some of the longer bolts fromt the rear cargo area and reuse them up front at some point, possible?
Also, what does everyone suggest for mounting the boulder bars, weld or bolt? I have a mount plate with holes for some 1/2" bolts, but the is plenty of meat on the mounting plate for welding. Now I am not going to run my DD on the Hammers or Pritchet, so they don't need to stronger than the frame. How about using self tap bolts for mounting also? Scott F. 95.5 Rodeo
The Lone ZuZoo. Well Almost |
technical expert
the front half of the body is monted w/ bolts that run "through" the frame....your original bolts are metric...but these front 6 (i think) can be replaced with standard grade 8's and nyloc nuts.
the rear 4 (i think) are metric and thread UP throught the frame into the bodu...these are usually the show stopper in terms of finding your own bolts. the obvious anser is that you need the bolts to be 1" longer than the stock ones you will need to find a local bolt house or industrial supplier (Grainger, etc) to source the bolts. Pull one of the rear most bolts and get your measurements......then go shopping. as far as the rocker bars............save yourself headache and just weld them on. you can always cut them off later. what are you using for the body puck on this 1" lift?
Matt, Owner: Independent4x www.independent4x.com 804-550-0480: 9am-6pm EST UFWDA Life Member - http://www.ufwda.org/ Full Service Fabrication Shop & Retail Store located in Richmond, Va. for all your OffRoad needs: featuring Sway-A-Way, WARN, ARB/OME, AEV, Advance Adapters, TeraFlex, Trailready, Currie, QA1, Beard Seats, Interco Tire, D.O.M. Tube to length, etc. - call or PM |
#3 (permalink) | |
Member # 6292
Easy way is to weld. With a little more work, you can do a nice bolt-on like this: |
