Member # 18160
help! 93 Isuzu truck runs like shittt!
I checked and snipped the ends on all the vac hoses and sprayed a can of starting fluid onto the intake and around hoses and carburetor and i cannot not figure out why it still idles like crap. But the temperature is extremely high on the exhaust side almost 525 degree f. I am pin pointing it to the carburetor and can i get this fixed my self or do i have to spend 270.00 dollars for a rebuilt one. What do i do? It sputters and lacks power on acceleration. Everything has been tuned and new head and valve job and resurface been done but still runs like crap. Should i buy a carb from the junk yard?
Thanks 93 Isuzu Pick up martin
yuiktkt |
technical expert
93 huh...i'm going to say you either have a fuel injected 2.6L 4cy.............OR..............you have a Throttle Body (TBI - also fuel injected) GM 3.1L V-6.
so no Carb there either way.............based on you saying you have a "carb" i'll guess it's a 3.1L V-6 and say it sounds like a clogged injector in the TBI. BUT only guessing with out more specific info as far as the temp issue......is the work you had done warr. by a shop? or are you on your own here?
Matt, Owner: Independent4x www.independent4x.com 804-550-0480: 9am-6pm EST UFWDA Life Member - http://www.ufwda.org/ Full Service Fabrication Shop & Retail Store located in Richmond, Va. for all your OffRoad needs: featuring Sway-A-Way, WARN, ARB/OME, AEV, Advance Adapters, TeraFlex, Trailready, Currie, QA1, Beard Seats, Interco Tire, D.O.M. Tube to length, etc. - call or PM |
#3 (permalink) | |
Member # 12056
The symptoms sound similar to what happened with my '87 (1.9L) before I rebuilt the carb. Is there any excessive smoke coming from the exhaust ? Have you inspected the plugs since the tuneup (fouling) ? |
#4 (permalink) | |
technical expert
really???? HUH.....new one on me. i did have the mis-fortune of owning a 2.3L 4 cyl when i had my 87 trooper......so i do have a little experience w/ that motor as well. would not have guessed that was in a '93?
Member # 18160
Yes it is a 1993 Isuzu 2.3 liter 4cyl
It has a 2 barrel carburetor on it and i just went to the junk yard and the owner told me that he has alot of isuzu's but evryone is looking for a carburator for thema nd they have trends to be bad and there are no rebuild parts for them. I was still wondering if my carb is bad and i do think it is because i think it is running real lean and it does not spue out smoke like it is running rich. I measured the tempurature at the exhaust manifold and it is reading like 525 degree f. It is hot and it will run hot if it runs lean am i right. All work done the the engine is correct because the heads were taken to the shop for mill, valve job, and cracked tested. I checked all possible vacuum leaks and seem to be un successful to find and leaks what so ever.
Does anyone have a carb for sale or can rebuild one that is significantly cheaper than 300.00 dollars? (autozone price) 1993 Isuzu Pickup Truck 2.3 liter 4 cyl engine carbureted Thanks Martin
yuiktkt |
#6 (permalink) | |
Member # 12056
Re: Yes it is a 1993 Isuzu 2.3 liter 4cyl
He's pretty good at diagnosing 'over da phone' too
technical expert
there is a guy in NC on ebay that sell the Webber Carb for that Motor...i "think" it is under $300 as well
search on "isuzu trooper" or webber hope that helps
Member # 15939
check timing amd mixture setting. If that dosent help, rebuild the carb or look for a webber 2bbl.
1999 Stock poser TJ, DD 1973 Wagoneer, mall crawler project... |
Member # 21185
From what I'm finding, this seems to be an all to common problem with the carb 2.3L. My 86 has plenty of power at wide open throttle, but stumbles low to mid throttle and refuses to idle at any particular speed. I can get it to sort of stay around 1200 RPM but it tends to surge and then nearly die off instead of picking a spot to idle at. Checking for vacuum leaks shows only that the primary throttle shaft bushing is pretty worn out, but no other real leaks.
Anyone have some instructions for setting the idle mix on these things? I have the Haynes book, but it cops out with the "this should only be adjusted by a trained mechanic" line on idle mix. I basically just need starting settings and final adjustments. |
Member # 15939
i cant realy explain carb tuning but my dad has kinda showed me, and he and i are able to do it be ear and feel. Just play whith the mixture and idle screws untill it levels off. hten run it and keep doing it till it runs well. I would still be inclined to check timing.
#12 (permalink) | |
Member # 12056
Coming from a new Holley owner ... make sure the timing is set to spec, adjust the mixture, adjust the timing. Adjust the idle, adjust the timing and the mixture. Adjust the timing. REPEAT ![]() Good Carb mechanics are worth their weight in Gold around here. |
#13 (permalink) |
Member # 21185
Can't do much with the timing without at least a stable idle. Even without vacuum advance the timing bounces around like silicone on Baywatch with an idle that varies from 400 to 1800RPM. I've tweaked the timing by ear some and made some improvements, but nothing there seems to help the surging.
I've gotten the idle to calm down a little by just tuning the carb by ear, but I'd like to know what the start point is for the idle screw so I can see how far off I am. If it has to be run rich or lean I can make some guesses about what is going on. I've seen some references to the Clymer shop manual actually having the idle mixture adjustment info in it, but I know the Haynes doesn't. I should have an 86 shop manual and supplement on its way to me, so perhaps that will help. |
#14 (permalink) |
Member # 19500
I have an 86’ Trooper that I am converting to SB350. It had a weber carb of some sort bolted to the old 4-cylinder engine (engine ran real good, but wanted to upgrade entire dirvetrain to 1 ton). The guy I bought the trooper off of said it was an aftermarket carb designed for off-camber and inclines for 4x4 use. It also had a foam secondary filter that helped to keep the mud and soot out of the paper filter when in muddy, dirty situations. I would be interested in selling it if your interested. I won’t be able to get the numbers off of it to find out exactly what model it is until this weekend though.
#15 (permalink) |
Member # 21185
OverThrottle: Sent you an email
I've got a factory shop manual heading my way soon for the 86 Trooper, and if that has the idle mix info in it, I will pass it along. I'm beginning to think this carb is just worn out and needs rebuilt or replaced. The trooper has almost 200k miles on it, and the carb doesn't look like much has been done to it. |
#16 (permalink) |
Member # 21185
Update
I found the source of my troubles. The mixture control valve (white round deal on the fender with a 3/8" hose hooking it right into the intake manifold) was leaking vacuum off badly. I unhooked it and plugged the port on the manifold. The idle smoothed out and it is running much better. Now to find a replacement part so it will run right and could pass emissions if I ever have to.
I'll add the specifics on the idle mixture adjustment later. The factory service manual has the details, but it is basically the standard deal if you've done this before. Start 3 turns out, turn to where it runs best, then set the idle. |
