2.3 v 2.6 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-28-2003, 10:29 AM   #1 (permalink)
chadburgin's Avatar
Member # 18196
2.3 v 2.6
i know one is fuel injected but i want to know which one is more dependable and will last the highest miles.
chadburgin is offline   Reply With Quote
Old 06-28-2003, 12:21 PM   #2 (permalink)
Member # 12056
Re: 2.3 v 2.6
BOTH
Why wouldn't you go with fuel injected 2.6 (smooth power and no fuel slop problems on the trail) ?
Head stamps *might* be one thing to consider, tho.
Some cylinder heads were good, some weren't.
Head stamps range from 1 to 5, 4 & 5 being the best IIRC.
The bottom ends of these engines are VERY STOUT !
As long as you adjust the valves regularly, you should have minimal repairs.
What year/model are we talking about ?
GonZu is offline   Reply With Quote
Old 06-28-2003, 01:02 PM   #3 (permalink)
chadburgin's Avatar
Member # 18196
its an 88. they want $2500 and it has 188k but is in great shape inside and out and runs out very good. i have an 87 that i have been working on for a while now and its got an LT-1,700R4. toyo t-case, and have 1 tons to be put in. it was a 2.3 when it started life. i also have a yj that i wheel with. i just want something for a DD.
Old 06-28-2003, 02:23 PM   #4 (permalink)
Member # 12056
So the '88 for purchase- is a Trooper, 2.6, auto ?
Are there any leaks underneath ?
Give up some more info.
Is it a TII ?
The 411 from KBB
1988 Isuzu Trooper II S Sport Utility 4D
Engine: 4-Cyl. 2.6 Liter
Trans: Automatic
Drive: 4 Wheel Drive
Mileage: 188,000
Private Party Value $1,365
Trans: Automatic
Mileage: 188,000
Retail Value $2,500
I'd buy it for $2k... but that's just me
It sounds like it would be a good DD.
Screw that, let's see pics of the '87 LT-1 - 700R4, ya bastid
Old 06-28-2003, 04:27 PM   #5 (permalink)
chadburgin's Avatar
Member # 18196
its a 5spd, LS model. wouldnt it have 4.77 gears? i would give pics of my 87 beast but i have no scanner. i will try to find someone who does.
Old 06-30-2003, 12:11 PM   #6 (permalink)
Member # 12056
Quite possibly.
That or the 4.56.
I'm not a Trooper expert
Look under the hood and there might be a code plate that tells you which one you have OR you can jump over to 4x4wire.com and search the Zu forum.
Old 06-30-2003, 12:27 PM   #7 (permalink)
Member # 347
... you can jump over to 4x4wire.com and search the Zu forum.
Good answer.
There you would find that both engines were delivered with fuel injection, depending on the year, and that other significant changes were made resulting in better power and drivability in later models.
You'd also find that higher numbers are generally better for cylinder heads, but that date of production makes even more difference, and that there are some recent '3' aftermarket castings that are better than Isuzu's early 90's 4 castings.
These are stout engines, and are HIGHLY similar, since they are based on the same block family. If well-serviced and -maintained, either would be a good choice. The 2.6 has a bit more power, but we're talking pretty small amounts, and the real decider for most folks ends up being availability and maintenance history. If the previous owner can show a regular maintenance history (pay special attention to coolant changes and valve lash maintenance), pick THAT truck, regardless of 2.3/2.6.
Randii
Pack it *ALL* out... you pick up after your dog, so clean up after YOU, too.
- VIRTUAL RALLY for the HAMMER TRAILS in JOHNSON VALLEY Post 1349
- VIRTUAL RALLY for TELLICO Post 716 and Post 924
- KOH Pledge Drive: for 4405 KOH Pledge #4
randii is offline   Reply With Quote
Old 07-09-2003, 06:15 AM   #8 (permalink)
Member # 5587
Let's not forget that with a 2.3 L you can put an Impulse Turbo on it with fewer issues and get a great Daily Driver. You can turbo the 2.6 but the Impulse Turbo will not have the blow you need to keep you happy. Ask Houlster, He knows whow to fix that problem. And you can Fuel Inject the 2.3 L too! IF it isn't already. A little modifying on the Impulse Intercooler and you've got a cool runner. I've got some pictures of one around here somewhere. Or maybe, I'll take some new ones.
Go with the 2.6 l for better parts availability. There's a bunch of them.
SSSRodeo
SSSRodeo is offline   Reply With Quote
