Dana 44 clarifications - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-01-2003, 08:21 AM   #1 (permalink)
NothernAZxj's Avatar
Member # 8528
OK lets get this straight: to use the stock carrier in my rear 96 zoo 44 my only high gear options are 4.10, 4.30, 4.88 from RRRP
if I go to a new 3.92 carrier I can run all normal 3.92 to 5.28 44 gear sets
if I go to a new 3.73 carrier I cam run all 2.25 to 3.73 44 gear sets
the only real funky thing about the zoo 44 is teh thick ring gear right?
Brian Harmon
NothernAZxj is offline   Reply With Quote
Old 07-01-2003, 10:43 AM   #2 (permalink)
Member # 8301
You currently have a 3.73-down carrier with thick gears on it. All standard 3.73-down gears will fit it as well as thick gears.
If you wanted to run 3.92-up standard gear you would need a new carrier.
Check the Rubicon 4.88 thread in the Isuzu forum. It has a link with a picture that should make this more clear. If you tried to put standard 3.92-up gears on a 3.73-down carrier there would be a gap between the ring gear and the pinion gear.
-chris
rodeo_chris is offline   Reply With Quote
Old 07-01-2003, 11:37 AM   #3 (permalink)
Member # 20848
Arrow "Stock" Zu Gear Clarification
Actually "stock" Zu gears come in four flavors: 4.10, 4.30, 4.56 and 4.77, any one of which would use the 3.73 and down carrier as RC mentioned.
Cheers
Jim
Maxed IFS
jgalt is offline   Reply With Quote
Old 07-01-2003, 12:36 PM   #4 (permalink)
technical expert
Independent4x's Avatar
Member # 8755
Send a message via AIM to Independent4x Send a message via MSN to Independent4x Send a message via Yahoo to Independent4x Send a message via Skype™ to Independent4x
Re: Dana 44 clarifications
CORRECT!
EXAMPLE: get the axle..forget about what's in it......buy a 3.92+ full carrier locker and matching regular Dana 44 gear set and you are in business
or get the appropriate open Spicer carrier and matching ring gear and drop a Lockright into if if you are so inclined.
there are really a lot of ways you can approach these rear axles...that is one reason it gets confusing. Many more options than the standard D44 w/ drums.
Matt, Owner: Independent4x
www.independent4x.com
804-550-0480: 9am-6pm EST
UFWDA Life Member - http://www.ufwda.org/
Full Service Fabrication Shop & Retail Store located in Richmond, Va. for all your OffRoad needs: featuring Sway-A-Way, WARN, ARB/OME, AEV, Advance Adapters, TeraFlex, Trailready, Currie, QA1, Beard Seats, Interco Tire, D.O.M. Tube to length, etc. - call or PM
Independent4x is offline   Reply With Quote
Old 07-01-2003, 07:37 PM   #5 (permalink)
Member # 8528
SHEET MAN! Im not near as dumb as I look!
Brian Harmon
