Member # 17350
So after looking at a few of the Amigo's and seeing that wonderful fender well opening(thanx for slashing your tire Sean and changing so I could see how big they really are)I thought back to when I saw something a year or 2 ago about doing the change over from Rodeo stock fenders to Amigo stock fenders.I have a 95.5 Rodeo so would the 94-96 range of Amigo work for this?I tried a search on the wire but no joy.Anyone know off the top of their head.
Oh yeah...
I only support gay marriage if both chicks are hot! [url]http://www.MWIOR.com/[/url] |
technical expert
amigo fenders bolt right up to rodeos and pickups
and it looks really cool w/ the flared fenders
Matt, Owner: Independent4x www.independent4x.com 804-550-0480: 9am-6pm EST UFWDA Life Member - http://www.ufwda.org/ Full Service Fabrication Shop & Retail Store located in Richmond, Va. for all your OffRoad needs: featuring Sway-A-Way, WARN, ARB/OME, AEV, Advance Adapters, TeraFlex, Trailready, Currie, QA1, Beard Seats, Interco Tire, D.O.M. Tube to length, etc. - call or PM |
Member # 17350
cool
so is there a particular year I should keep my eye out for or is it one of those no brainers?
technical expert
any amigo 89-94 will work
Member # 347
A lot of incorrect info here... let me interject some of what I know.
There's more discussion of this over on the 'Wire:http://www.4x4wire.com/forums/showfl...c=1&PHPSESSID= ...I'll append pix to that thread this afternoon as examples. ![]() Fenders First-gen Amigo fenders will bolt on to first-gen Rodeos (and vice versa, as I have done for years) but the wheel well is the same size front-to-back. The chief difference between the fenders is the amount of 'bulge; to the top of the arch... coverage is the same at the fender bottoms. Amigo fenders are only available at the junkyard or at the dealer; Rodeo fenders are available also available in reproduction stampings for cheaper (why I run them). If you swap fenders from Amigo-to-Rodeo or vice versa, to do it right, you'll also need the plastic inner fenderwells. There are also some differences on the radio antenna hole, depending on year. Front Clips Some bumpers are radiused wider at their ends to match the Amigo flares, so your fenders may look goofy in relation to your bumper if they are mis-paired. The front clip sheet metal stampings vary quite a bit (but in small ways) through the first generation years... there are small mid-year tweaks with holes in different places. With larger variations, the first gens are split in terms of straight grills, curved-bottom grills, and aero-headlight grills, with corresponding variations in the grill, bumper, headlight/marker assemblies, and front bulkheads. In summary -- you *can* make parts work across the whole first-generation, but some custom work will be required, and sometimes, no matter how hard you try, it just won't look right. Randii
Pack it *ALL* out... you pick up after your dog, so clean up after YOU, too. - VIRTUAL RALLY for the HAMMER TRAILS in JOHNSON VALLEY Post 1349 - VIRTUAL RALLY for TELLICO Post 716 and Post 924 - KOH Pledge Drive: for 4405 KOH Pledge #4 |
#7 (permalink) | |
technical expert
not sure i would go that far.....there wasn't realy too much info here at all. thanks Randii.....informative and helpful as usual i hear ya on the inner liners, but not a fan of those.....don't personally run them...but, i can see the value of it if you are thinking on more of a stock-ish truck w/ stock bumpers.
#8 (permalink) | |
StinkyFab Racing
Member # 4946
Re: Swapping body parts
Dallas
Dallas Ashley StinkyFab Racing (SFR) - Custom Fabrication Your Source for: CNC Cutting & Engraving, Cages, Custom Suspension, Complete Vehicle Builds, and more! Overall Winner, 2012 KOH EMC. Gettin it done in a stocker! Co-Dog #4432-KOH 2011 #88-KOH 2010, Crew Chief - KOH 2009, 2008 |
#9 (permalink) | |
Member # 17350
Re: Re: Swapping body parts
Randii I always love when you interject and once again super info.You run Rodeo fenders on your Amigo???When I finally saw an Amigo with a tire off it looks like there is all kinds of room for craming a tire in there.Far more than in my Rodeo's fenders wells.Could be an optical dilusion but that's what I think I saw.So is there a fiberglass aftermarket or has Drew not finished those yet?
Member # 15939
im perty shure my statement said much of what yous did randii, except the whole bumpers being wider for the flared fenders on amigos
1999 Stock poser TJ, DD 1973 Wagoneer, mall crawler project... |
