stock alarm 2001 trooper - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-27-2003, 09:19 PM   #1 (permalink)
Member # 11392
The wifes 2001 Trooper with the factory alarm has gone off now 3 or 4 times with nothing around to set it off. Anyone else have any problems with theirs? The last time I checked the battery and it was over 12.5 volts so I don't think its a low battery problem.
70~K5 is offline   Reply With Quote
Old 07-28-2003, 07:08 AM   #2 (permalink)
Member # 20752
random alarm
Many times something like this is stray voltage due to a bad ground somewhere in the electrical system...the trick is finding it, could be anywhere. Not too helpful I know, but there it is
Steve Carlson
95 Trooper LS - 35s, ARBs & 5.38s
BigSwede is offline   Reply With Quote
Old 07-28-2003, 07:12 AM   #3 (permalink)
Member # 20386
Check the rear door switch. This was a known issue on the Rodeo/Amigo, and you might have the same problem on your Trooper. Try spacing the switch out from the body with a washer.
Nazrat is offline   Reply With Quote
