Strange Sound - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-30-2003, 02:07 AM   #1 (permalink)
Member # 21591
Send a message via Yahoo to Sampdaddy
Question Strange Sound
I just put 1" Coil Spacers, Ball Joint Flip, 2" Suspension Lift, 3" Body Lift, and 33x12.50's on my 98 Trooper. Now i'm getting what sounds like a metal rod knocking when slightly turning (mostly left) at low speeds (15-35mph). I've gotten under and shook everything to find something loose...nothing. I tryed to visualize what might be knocking while slightly leaning right and slightly turning left...can't see it. If anyone has a clue as to what it might be, i'm all ears.
Sampdaddy is offline   Reply With Quote
Old 07-30-2003, 04:51 AM   #2 (permalink)
technical expert
Independent4x's Avatar
Member # 8755
Send a message via AIM to Independent4x Send a message via MSN to Independent4x Send a message via Yahoo to Independent4x Send a message via Skype™ to Independent4x
My guess would be that it pretty much sounds like worn ball joints.
probably an existing issue....just "brought to light" by your recent modifications.
start there.
Matt, Owner: Independent4x
www.independent4x.com
804-550-0480: 9am-6pm EST
UFWDA Life Member - http://www.ufwda.org/
Full Service Fabrication Shop & Retail Store located in Richmond, Va. for all your OffRoad needs: featuring Sway-A-Way, WARN, ARB/OME, AEV, Advance Adapters, TeraFlex, Trailready, Currie, QA1, Beard Seats, Interco Tire, D.O.M. Tube to length, etc. - call or PM
Independent4x is offline   Reply With Quote
Old 07-31-2003, 08:24 AM   #3 (permalink)
Member # 19500
start there.
I would check that and also check your CV shafts. They start to make a clicking noise, while turning, when they are wearing out. If there is a torn boot, this is almost a sure sign of a worn CV shaft, since they do not last long once they get water in them.
OverThrottle is offline   Reply With Quote
Old 08-02-2003, 12:55 PM   #4 (permalink)
Member # 21650
Send a message via Yahoo to MountainGoat
Sampdaddy says "Thanx", at least now he has somewhere to look.
MountainGoat is offline   Reply With Quote
Old 08-03-2003, 08:14 AM   #5 (permalink)
Member # 20564
The Trooper does not like having it's torsion bars cranked. < no vehicle would> This puts the front shafts at a terribly over extended angle and have probably damaged your CV or Birfield joints. They cannot and will not last if used.
Not to mention horrible A arm angles and camber extremely out of spec.
Only practical way to lift a trooper is to swap out that front axle. or body lift it.
86 Topless Turbo Diesel Trooper SAS SOA Custom Alum Dash, Cage, Dana 44 front, Detroit ezlocker, Zoo 12 bolt rear Lincoln Locker, cherokee springs, Alum radiator, 36" Super swampers, Stack & Snorkle, VDO gauges
2001 Dodge Ram 2500 4x4 Cummins Superchips, K&N, TST j-hook, transgo VDO gauges
AirTrooper is offline   Reply With Quote
