IFS strength? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-07-2003, 11:04 PM   #1 (permalink)
Member # 21821
IFS strength?
If I'm only looking to do trails, how strong is IFS in say holding up to 33-36" tires?
Anyway to get lift out of em besides cranking Tbars? i sthere a kit?
C:\Dos
C:\Dos Run
Run\Dos\Run
"Don't democrats cause cancer?" --Homer Simpson
TxsizeK5 is offline   Reply With Quote
Old 08-07-2003, 11:13 PM   #2 (permalink)
Member # 20695
I'm running 33" tires, locked front & rear, and beat the shit out of my rig daily and it stands up fine. Never broken a CV, but ripped a few boots on my CV's from the crappy angles. Go to Matt's website and you'll learn tons, and I'd also suggest giving him a call. I'd be cautious going up to 35" tires on the IFS... 33"s seem to be the safe max for reliability.
89 Trooper Supercrew
283/SM465/np205 twinstick burning BBQ juice
on 37"s
Grampa is offline   Reply With Quote
Old 08-08-2003, 04:52 PM   #3 (permalink)
Member # 20564
I have 32" super swamper tsl sx's and it ripped out the birfields first time off road.
lifted IFS SUCKS is a total waste of money, and messes up the suspension geometry something aweful.
I would put max at 31x10.50s Street only. or an occasional cow pasture.
86 Topless Turbo Diesel Trooper SAS SOA Custom Alum Dash, Cage, Dana 44 front, Detroit ezlocker, Zoo 12 bolt rear Lincoln Locker, cherokee springs, Alum radiator, 36" Super swampers, Stack & Snorkle, VDO gauges
2001 Dodge Ram 2500 4x4 Cummins Superchips, K&N, TST j-hook, transgo VDO gauges
AirTrooper is offline   Reply With Quote
Old 08-08-2003, 08:55 PM   #4 (permalink)
james west's Avatar
Member # 7224
IFS doesnt use birfields....i ran 33s on mine and took it through tellico with no problem....and drove it 8 hours home
moderately lift the frontif you must...2-2.5"....matt sells kits, and provides great tech support....but you can learn everything on the internet without making phonecalls...lift is achieved with cranking t-bars, and gaining some "droop" with balljoint relocation and spacer, and lo-pro bumpstops
if your not rock crawling, ifs works great, when you start changing the geometry, some maitainence issues typically arise in older trucks (bushings, balljoints, etc.)
i say go with it until your ready to commit to something solid
i got nothing
james west is offline   Reply With Quote
Old 08-09-2003, 01:35 AM   #5 (permalink)
Member # 16384
Send a message via AIM to paulevans76
Yeah but remember you're sportin the 8 bolt front which is weaker than the 10 bolt. I'd say the 10bolt is good for 33's, and even 35's if you drop the diff a couple o inches
79 cj5 on tons
paulevans76 is offline   Reply With Quote
Old 08-09-2003, 05:45 AM   #6 (permalink)
Member # 6359
Location: Placer County, CA Where the Green Grass Grows
IFS and 33"s
4runner with ARBs f/r and stock IFS went through the Rubicon fine last year (Jeff the Marmot). He's been runnin that way for a while. They tell me backing up, bound up kills em'. Rolling backwards and dropping the clutch is kool, also. Wedging your tire against an imovable object, with the wheel turned and the throttle floored works also. I say drive with forethought and purpose, and run em till you know you need something stronger. I gather that the Isuzu IFS is comparable to the Toy. My shop-built front Toy SAS cost more than my rig did Enjoy the IFS and drive easy, watch the "built rigs" with un-built drivers break all their shiazzz
not surprized yer confused yer face was burried in the pillow pretty deep as gizim drunk as you were
Lil Uzi is offline   Reply With Quote
Old 08-09-2003, 11:11 AM   #7 (permalink)
Member # 10124
Maybe he swapped in a yota IFS solid axle???? LOLLLLLL
I crashed that piece of shit...and then stepped away.......
Rip DeLips is offline   Reply With Quote
Old 08-09-2003, 06:54 PM   #8 (permalink)
Member # 16384
Ed put the beer down and back away from the computer...
79 cj5 on tons
Old 08-09-2003, 08:20 PM   #9 (permalink)
Member # 20564
On the trooper the outer is a CV the inner is a birfield. TAke a look
And it was not anything to do with the ring and pinion or carrier that failed. It has been axles.
The trooper front end is very weak when torsion bars are cranked and front axles are at extreme angles.
I had Matt's parts, flipped ball joints, ball joint spacers, short snubbers. They are all show and not serious off road hardware. Camber is horrible but some people want the inexpensive lifted look for blvd cruising.
The last two troopers Matt has run have SAS. I'm sure he will tell you a fully cranked trooper at 2 or 2.5 " has the axles at extreme angles, and won't last in serious off roading.
Old 08-09-2003, 10:24 PM   #10 (permalink)
Member # 16384
They'll do fine for most stuff. Extreme rockcrawling, no, but for doing the local bog or some trails it'll hold for a while. Matt's parts don't really make it stronger, just give you some travel back after cranking.
If you want to keep the ifs go with a 3" body, 2" crank and shackles and some 33's. You can get 2" drop diff plates to keep the cv's straight (from trooper4life) and some tie rod shields from joe darlington to keep those from blowing and you'll be ready for anything except competition. You'll have about 6-8" of travel in the front and good flex out back. Weld up the rear and tackle the trail.
I'm trying to keep my IFS and I'm trying to make a 4-5" drop diff with 2nd gen a-arms, cv's and spindles with some cross-linked air shocks and a spring over in the rear. It should end up working about as good as a low-lift SAS. CV's really aren't as hard to change as people think.
If you have some dough and skills and tools, by all means go ahead and tread the trodden SAS trail.
Paul
79 cj5 on tons
Old 08-10-2003, 08:10 AM   #11 (permalink)
Member # 20564
disagree about everything but extreme rock crawling.
Ours were destroyed in pretty mild climbing at Marshall Creek here north of fort worth.
If you have the talent to do drop plates and can weld, you can do SAS.
Old 08-10-2003, 08:28 PM   #12 (permalink)
james west's Avatar
Member # 7224
if your were breaking IFS in "mild" stuff, you were doing something wrong.....
the guy who started this thread said he wanted to do trails, not ARCA competition
i had mine airborn, and did some stoopid shit with it...never broke...and that was fully tweeked up front with all the shit to gain travel, including homemade 1/2" spacers
but i wouldnt try to drop the axle and shit, just SAS it, it WILL work better, and its easier...unless you walker evens or something
but dont do a bodylift, fucks up center of gravity and looks dumb...just cut the sheetmetal to make whatever tires you want fit.....thats my ultimate suggestion, forget all the lift on the IFS, keep it stock and reliable...just cut the metal
i got nothing
Old 08-11-2003, 06:01 AM   #13 (permalink)
Member # 10124
I broke TWO half shafts in under a year...with no lift and 30x9.50's. Roll it like ya stole it.
Old 08-11-2003, 09:55 AM   #14 (permalink)
Member # 1005
Close. The outer CV is a Birfield. (All Birfields are CVs, but not all CV's are Birfields ) The inner joint is a Double Offset Joint. The DOJ allows for angles and length changes as the suspension cycles.
More useless Isuzu trivia for ya.
Michael
mlclark is offline   Reply With Quote
Old 08-11-2003, 10:00 AM   #15 (permalink)
Member # 11425
i wheel a Kia Sportage, which, i figure is built at LEAST a little weaker than a Trooper due to the difference in weight and projected buyers, anyway, my point is, i rockcrawl some pretty serious stuff as often as i can and have, to date, only blown one CV. granted, i don't have lockers front and rear but i do have a rear Eaton posi and i use my brakes to keep both axles turning the same speed and direction as often as i can. i have blown a couple hubs as well, but i would imagine since i built a lot more droop into my IFS and didn't drop the diff, and i crawl a lotta rocks and i'm running 32's, that i would have broken more stuff by now, but it just hasn't happened, could be that i don't normally throttle it much unless i have to, but who knows? i do know it takes a lot to blow a CV, i was fully flexed, right tire drooped all the way and turned left at full lock, then i jammed on the gas and the tire was spinning when it came down to the ground. as soon as it touched, the inner CV crown just walked out the back of the CV cup, spilling all the balls and sounding like a shotgun discharge.
[I][SIZE="1"][COLOR="Silver"]"do what thou wilt shall be the whole of the law"[/COLOR][/SIZE][/I]
fledgling666 is offline   Reply With Quote
Old 08-11-2003, 11:27 PM   #16 (permalink)
Member # 21650
Send a message via Yahoo to MountainGoat
You could do a 2"susp lift (Indy4x, DOR, or Calmini) and drop the diff 1.5-2" (Trooper4life) to straighten your axle back out. You could then do the ball joint flip (Indy4x, DOR, or Calmini) to fix what minimal camber issues you'd have...that can drop and stuff 32x11.50 with ease at max deviation, cut away a little to fit 33's. I put a 3"BL on mine, and it does fawk it up, i'm still trying to find the source of strange sounds. And it you leave the t-bars cranked without correcting the cv angle, you will rip cv boots...both my inner boots were ripped in 2 weeks. Also, get manual hubs, so that your cv shafts aren't spinning unless you're wheel'n, saves cv boots, ect.
MountainGoat is offline   Reply With Quote
Old 08-12-2003, 09:51 AM   #17 (permalink)
Member # 16384
When i was runnin skinny 33's w/ just t-bar crankage and long ass shackles, I used to beat the shit out of it and NEVER broke anything (besides the engine). I hooked up to a pole that my buddy wanted out of his yard. about 8" in diameter. I had it in 4 low, reverse, dumping the clutch at big rpms. no probs. couldn't get the pole out tho
Run it till ya break it and then go SAS.
oh yeah, don't for get the manual hubs up front. they will help keep the ifs alive longer.
79 cj5 on tons
Old 08-12-2003, 05:30 PM   #18 (permalink)
Member # 5716
You don't really say what rig you have with an IFS. Most people that have been responding have been talking about troopers.
I have a 1999 Amigo, with about 3 inches of 'crank' on the t-bars and corresponding lift in the rear and I am running 33s. There are a NUMBER of other people that have the same setup and at least a couple that run 35s, with NO significant front end damage to speak of (power steering seals not included). There are also a number of trooper owners that show up each year at Moabzu with tires that *seem* to be a lot bigger than stock (32s and 33s). They manage to wheel the snot out of their rigs on hard trails and don't break anything.
I don't know exactly why AirTrooper had problems with his trooper, but I would count that as a minority opinion, certainly not what I have seen over the last 4 or so years at Moabzu, Crawloween, ColoradoZu, etc.
Oh, and I don't exactly baby the Amigo either :
Jeff M.
Spaceman is offline   Reply With Quote
Old 08-12-2003, 11:05 PM   #19 (permalink)
Member # 20564
"if your were breaking IFS in "mild" stuff, you were doing something wrong..... "
so according to the original post, your telling this guy he can run 33 to 36" tires with cranked torsion bars and if anything breaks, he will also "be doing something wrong"
I'm outa here...
Old 08-13-2003, 12:15 AM   #20 (permalink)
StinkyFab Racing
StinkBug's Avatar
Member # 4946
Funny thing airtrooper, you seem to be the only one here complaining.
Anything you do to modify your rig can have effects on reliability, but IMHO the 10 bolt front end is pretty decent. I ran 32s on mine with the front end absolutely maxed out for about a year of almost constant abuse both off road, and on road delivering pizzas, and I never broke a CV and tore only 1 boot. The tie rods and CVs are definitely the weak points, and i've seen plenty of em break, but in general you should be ok. I'm a lot more worried about blowing up shafts in my front 44 with 37s than i was with the stock IFS and 32s. Also your comments about alignment dont make sense to me, I had my front end cranked over 3" and with the spacers I was still able to align it. sounds like someone is just bitter to me
Dallas
Dallas Ashley
StinkyFab Racing (SFR) - Custom Fabrication
Your Source for: CNC Cutting & Engraving, Cages, Custom Suspension, Complete Vehicle Builds, and more!
Overall Winner, 2012 KOH EMC. Gettin it done in a stocker!
Co-Dog #4432-KOH 2011 #88-KOH 2010, Crew Chief - KOH 2009, 2008
StinkBug is offline   Reply With Quote
Old 08-13-2003, 09:54 AM   #21 (permalink)
Member # 3337
Send a message via AIM to Locomigo Send a message via MSN to Locomigo Send a message via Yahoo to Locomigo
I'm outa here...
STFU NOOB!
I dont see what you are crying about man, I ,like Jeff, run 33s, run 4+ on a 5 scale and 9 on a 10 scale trails routinely, and have done well.
You should be able to run 33s without a problem on most anything IFS Isuzu. Some exceptions, but I wont go into those. The 10 bolt holds up well.
Keith
"Fuck em... they can eat a bowl of dicks for all I care!" - KE ______ "Bowl of dicks?" - MB
"Yep, bowl of dicks!" - KE ______ "Damn thats a regular cornucopia of cock!" - MB
Locomigo is offline   Reply With Quote
Old 08-13-2003, 03:32 PM   #22 (permalink)
Member # 17350
I have the Indy 4x 3" susp. lift on my Rodeo and wheeled all the time.Not doing extreme stuff but trail riding and having fun and it took me a whole lot of stupidity to break anything and it was the spider gears NOT the CV's.Both CV's were fine and I grenaded the diff.So I guess what I am saying is Yes 33's will be fine and AirTrooper is
So see ya
I only support gay marriage if both chicks are hot!
[url]http://www.MWIOR.com/[/url]
Urban_Assault is offline   Reply With Quote
Old 08-14-2003, 09:14 AM   #23 (permalink)
Member # 16384
air trooper chill out. you have an 8 bolt front it's a piece of shit, the 10 bolt is too, but to a lesser extent. it's ok to be wrong, man. besides, you don't have to worry about it, IIRC, you are going sas.
79 cj5 on tons
Old 08-14-2003, 06:49 PM   #24 (permalink)
maxwell417's Avatar
Member # 20491
At Co 'Zu this weekend, us lifted Troopers and Amigos running 33's, ran some very tough trails. Like Holy Cross, Chinaman Gulch, Wheeler lake. No breakage, no broken cv's or tie rods. Pictures here. and here
Troopers 89RS 33's & 90 3.4v6 SAS D44 5.38s ARB/12Bolt Hobart Revolution 3.07 4Low Cooper 35s
maxwell417 is offline   Reply With Quote
Old 08-15-2003, 08:48 AM   #25 (permalink)
Member # 8110
Send a message via ICQ to RodeoRob Send a message via AIM to RodeoRob
work as good? maybe depending on what your definition of that may be, but be close to as strong/reliable as a SAS (assuming we're talking about D44 or Toyota mini truck), never, not even close. I don't care how much drop axle you got, or what you do to the Isuzu 10bolt, for a given tire size, the SAS will be loads stronger.
My take on the situation? The isuzu 10bolt IFS is good for about 33's locked and 35's open. both situations would greatly benefit from a drop diff and some sort of tie rod beef. but no matter what you do, if you wheel it, time will catch up with you and you will break CVs. how soon and how often, depends on your driving style, but i promise you it will happen. I had have run both of those tire sizes on my Rodeo's IFS before going SAS.
-Rob
RodeoRob is offline   Reply With Quote
