trouble starting..... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-13-2003, 08:01 PM   #1 (permalink)
whitebrowithafro's Avatar
Member # 9761
Send a message via Yahoo to whitebrowithafro
A buddy next door was having problems with the Amigo starting and we checked out the spark (good), air flow (good), and thought then that it would be a fuel problem. He swapped in a new pump, and filter, and everything worked fine for a while (2 weeks approx. ) It stalled a few times...since then. And now, it won't start! It will turn over good, (so its not the battery/alternator) but we are at a loss.......any problems, or things to check/recommendations Thanks
DIRTBUILT INDUSTRIES - CNC plasma cutting, chassis plans, metal fabrication
'NO LIMIT CREW'
whitebrowithafro is offline   Reply With Quote
Old 08-13-2003, 08:16 PM   #2 (permalink)
Member # 19144
Cheak the fuel filter his tank may have some rust/trash/water in it. I have had that happen to me once or twice.hth
Later,
Daniel
trooper4life is offline   Reply With Quote
Old 08-13-2003, 08:33 PM   #3 (permalink)
Member # 9761
We replaced that also.....the little baggy filter that goes on the end of the filter
'NO LIMIT CREW'
Old 08-13-2003, 09:43 PM   #4 (permalink)
Member # 1005
What year?
If it is a first gen, then check the two wire fuel pump connector. They are prone to melting/degrading. Then check the ground wire coming out of that connector all the way until it attaches to the frame. Those are prone to corroding.
Good Luck
Michael
mlclark is offline   Reply With Quote
Old 08-14-2003, 08:59 AM   #5 (permalink)
Member # 9761
Its an early 90's one....and the wires looked (2 weeks ago) in good condition. Have not checked the ground though......will recommend that to him tonight......anything else guys?? And thanks
'NO LIMIT CREW'
Old 08-17-2003, 06:26 AM   #6 (permalink)
Member # 21888
put it on a scan tool and check the pulse to the injecters, they may not be fireing. It may also have a bad coolant senser that wont allow the ecm to richen the fuel mixture for starting or even a bad ecm. To determin if the problem is fuel related take the air intake off where it goes into the throtle body and while someone cranks it over spray starting fluid in (squirt stop-squirt stop not a steady stream but give it a good bit initally), if it runs on it then fuel delivery or settings is the problem, if it stays running after its started then the ecm isnt setting the richer mixture for starting (may have to try a few times to let it warm up a little) If it stops almost immediatly after you quit squirting in the starting fluid then the problem is in fuel pressure or injecters. Hope I helped and she gets goin again
psychobilly is offline   Reply With Quote
