Largest engine swappable into a 2ndgen Amigo?
I am positive that at least a chevy v8 can be put in... what's the upper limit, without say, cutting backwards into the console to make room. Cutting up through the hood would be doable, a little bit.
I think that a v10 could fit with some very careful fabrication and a slightly raised hood section, and with moving some of the parts out of the way- if the truck were lifted say 4" total some of the parts could be dropped just a tad to make more room. Suggestions? Flames? No worries- I've got my titanium underwear on. ![]() [Edit: I still have no clue about the moderators here, and even though everyone is using the little flipoff avvy, I decided not to use it at the end. It's immature and silly anyway.
fred and the snowman wrote: nazis dont kill muslims u mother f*ck idiot an0iance wrote: thats too bad. theyd be a whole lot cooler if they did. Last edited by an0iance; 08-30-2003 at 12:54 AM. |
technical expert
i haver a 350 in my trooper and it is pretty tight...............length is the real issue.
i don't see you getting a big block in there.....and if you did you would certianly need a remote mounted radiator...to keep it cool
Matt, Owner: Independent4x www.independent4x.com 804-550-0480: 9am-6pm EST UFWDA Life Member - http://www.ufwda.org/ Full Service Fabrication Shop & Retail Store located in Richmond, Va. for all your OffRoad needs: featuring Sway-A-Way, WARN, ARB/OME, AEV, Advance Adapters, TeraFlex, Trailready, Currie, QA1, Beard Seats, Interco Tire, D.O.M. Tube to length, etc. - call or PM |
technical expert
so were you just blowing smoke or are you really trying to swap a motor?
lets here more about this "big Block" you were talking about
Member # 11425
there's a guy putting a 350 in a Sportage as we speak (not me, i wish), but if THAT can be done........................
[I][SIZE="1"][COLOR="Silver"]"do what thou wilt shall be the whole of the law"[/COLOR][/SIZE][/I] |
Member # 3692
I did some measuring one day. Figured the 2nd gen compartment was about 4 inches short of the standard GM/Chevy compartment. So yes you could fit a big block in, without getting into the firewall but cooling could become an issue.
Moab Video = http://www.youtube.com/watch?v=VePPmRCIgKY |
Member # 15939
well i know getting a 350 to fit in a luv is a delicate act. Everything will fit but it takes work and you have to run the short watter pump.
1999 Stock poser TJ, DD 1973 Wagoneer, mall crawler project... |
