Isuzu NPR tech - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-10-2003, 10:43 AM   #1 (permalink)
technical expert
Independent4x's Avatar
Member # 8755
Send a message via AIM to Independent4x Send a message via MSN to Independent4x Send a message via Yahoo to Independent4x Send a message via Skype™ to Independent4x
Isuzu NPR tech
ok....so i was reading on the TLC board that the NPR deisel has a chevy bellhousing bolt pattern..............then i was looking on e-bay an noticed that NPR's came w/ 5.7L chevy gas motors as an option over the deisel................
so this leasd me to believe there is some unexplore possbilities here.
these trucks were non-computer controlled up until like 94 or 5 so.................let's put togehter some tech here.........
this could be a very interesting swap option
oh..this is an NPR:
Matt, Owner: Independent4x
www.independent4x.com
804-550-0480: 9am-6pm EST
UFWDA Life Member - http://www.ufwda.org/
Full Service Fabrication Shop & Retail Store located in Richmond, Va. for all your OffRoad needs: featuring Sway-A-Way, WARN, ARB/OME, AEV, Advance Adapters, TeraFlex, Trailready, Currie, QA1, Beard Seats, Interco Tire, D.O.M. Tube to length, etc. - call or PM
Independent4x is offline   Reply With Quote
Old 09-10-2003, 10:49 AM   #2 (permalink)
Member # 20576
Send a message via ICQ to Slim Teufel
Already drooling.
[i]insert intelligent text here[/i]
Slim Teufel is offline   Reply With Quote
Old 09-10-2003, 11:10 AM   #3 (permalink)
technical expert
Member # 8755
here's a good link to the Heavy Dutry Line.....with a bunch of spec pages.
http://sunautogroup.com/isuzu_commercial.htm
Old 09-10-2003, 11:16 AM   #4 (permalink)
technical expert
Member # 8755
good thread on NPR tech from the Land Cruiser Board.......worth a read:
http://www.pirate4x4.com/forum/showt...ight=isuzu+NPR
Old 09-10-2003, 03:15 PM   #5 (permalink)
Member # 6863
There is a ton of misinformation out there on the Isuzu NPR diesels. The 4bg series engines have a SAE #3 pattern, check the isuzu website...
The other peice of mis info, is that the SAE #3 bellhousing bolt pattern is a chevy v-8 pattern. This is simply BS being perpetuated by some folks over on the Landcruiser section of the PBB. The two patterns are NOT the same, the trannies that came behind the different engines are NOT the same...
There are ways to get something to bolt up to the isuzu bellhousing using SAE #3 bellhousings/adapters...
-Brett
I have enough projects for the next decade. Need two?
cruiserbrett is offline   Reply With Quote
Old 09-12-2003, 08:57 AM   #6 (permalink)
Member # 14887
The confusion is that there is a #3 SAE flywheel housing, and then you need an adatper to connect what ever trany you are trying to connect to.
The SAE flywheel housings are engine specific ie Cummins fits Cummins and Isuzu fits Isuzu only.
Check out Diesel Talk here:
http://atlas.binderbulletin.org/foru...yWheel+Housing
Here are some GM ones.
http://www.phxgrp.com/gmpowertrain.htm
Carey
Carey
ScoutIITD is offline   Reply With Quote
Old 09-12-2003, 08:54 PM   #7 (permalink)
Member # 12758
These two are both by me. The Isuzu 4BDs are a sae #3 pattern, it just has the holes in different locations, 15 degrees rotated counter clockwise. This is from an Isuzu tech. From what I've seen of the bellhousings, it would be pretty easily redrilled to mate a sae #3 bellhousing to an Izusu sae #3, but you will have to redrill. No mystery to it.
Secondly, the Chevy pattern = sae #3 was all caused for me, and for at least a year I believed they were the same pattern. This is all from one little misread about Cummins being able bolt to Chevy patterns that are sae #3. And I started it and possibly a million people believe it these days.
Anyways...
There is some useful info on it on my site though...
dieselcruiserhead is offline   Reply With Quote
