Isuzu NPR rear axle tech - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-10-2003, 11:09 AM   #1 (permalink)
technical expert
Independent4x's Avatar
Member # 8755
Send a message via AIM to Independent4x Send a message via MSN to Independent4x Send a message via Yahoo to Independent4x Send a message via Skype™ to Independent4x
ok let's gather tech on the NPR rear axle. this is the BIG Full FLoat reat 3rd membered axle isuzu uses in the box truck.
the interesting thing here is that the stock ratios are 4.10 and 5.38
YES....5.38.......
so you could pair one of these bad boys with a front 60 w/ 5.38's
here are some specs:
Rear Axle:
-Capacity 11,020 lbs.
-Ratio 4.10/5.375 (STD/AT)
Please add more.
Matt, Owner: Independent4x
www.independent4x.com
804-550-0480: 9am-6pm EST
UFWDA Life Member - http://www.ufwda.org/
Full Service Fabrication Shop & Retail Store located in Richmond, Va. for all your OffRoad needs: featuring Sway-A-Way, WARN, ARB/OME, AEV, Advance Adapters, TeraFlex, Trailready, Currie, QA1, Beard Seats, Interco Tire, D.O.M. Tube to length, etc. - call or PM
Independent4x is offline   Reply With Quote
Old 09-10-2003, 03:21 PM   #2 (permalink)
Member # 6863
They are big(hang up on rocks big), use a wierd six? lug pattern(also huge-MUCH bigger than a standard 6 or 8 lug 1 ton pattern and the hubs appear to be much to big to turn down in dia. to allow for a more normal sized wheel to fit) and are generally much too heavy for use on something of a DD/trail truck.
I have enough projects for the next decade. Need two?
cruiserbrett is offline   Reply With Quote
Old 03-30-2008, 08:18 PM   #3 (permalink)
Member # 111735
Do you know a source for these axle gears ?
I am in Australia and trying to improve highway cruising for my NPR light truck which i think has a 5.57??????.
fiestaxr4 is offline   Reply With Quote
Old 03-30-2008, 08:25 PM   #4 (permalink)
Member # 66354
i have no clue but
wow! 5 years old thread!
1999 'Zu Rodeo - 8" lift, 4.77, Aussie locker, 33" Trxus, 8K winch, dents and scratches
rodeored is offline   Reply With Quote
Old 03-30-2008, 08:51 PM   #5 (permalink)
Member # 111735
Finding this sort of information is really hard - I'll give anything a try!
Old 03-31-2008, 05:51 AM   #6 (permalink)
Member # 66354
i remembered this thread from a while back - try joining this board, and pm the guy who was working on this truck he may know something
http://bb.tennesseeoffroad.com/cgi-b...4;t=000156;p=1
