E-brake cable - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-15-2003, 10:22 AM   #1 (permalink)
Member # 22530
Lightbulb E-brake cable
What have you done to the e-brake cable to make a D44 rear fit a gen 1 Amigo?
90amigo is offline   Reply With Quote
Old 09-25-2003, 04:59 PM   #2 (permalink)
technical expert
Independent4x's Avatar
Member # 8755
Send a message via AIM to Independent4x Send a message via MSN to Independent4x Send a message via Yahoo to Independent4x Send a message via Skype™ to Independent4x
is your amigo a console or a dash pull lever?
if it is in the console.......basically the same as the rodeo...just tthat the cables are really long.
if it is on the dash.same as the troopers.............the cables will hook right up...you just need to fab a couple hard mounted stops on the frame to slide the rodeo cables into....giving you something to "pull" against.
all in all both are very simple systems and easily "cross" adapted.
Matt, Owner: Independent4x
www.independent4x.com
804-550-0480: 9am-6pm EST
UFWDA Life Member - http://www.ufwda.org/
Full Service Fabrication Shop & Retail Store located in Richmond, Va. for all your OffRoad needs: featuring Sway-A-Way, WARN, ARB/OME, AEV, Advance Adapters, TeraFlex, Trailready, Currie, QA1, Beard Seats, Interco Tire, D.O.M. Tube to length, etc. - call or PM
Independent4x is offline   Reply With Quote
Old 09-25-2003, 05:58 PM   #3 (permalink)
Member # 22530
I was under the amigo last weekend and I'll use part of the cable where it T's off and use cable clamps to add to the OEM cable on the rear.Looks easy,I will see soon.I ordered my lift kit last night.
