Member # 15939
Alright while cruisin the car sales adds tonight i found one that cought my attention. 87 Trooper 2door 4x4 for $300. Do you think it would be worth it? It just says it runs, drives and stops. What motors did this yeah have?
1999 Stock poser TJ, DD 1973 Wagoneer, mall crawler project... |
technical expert
87 is a split year.
the early 87's are really 86's.......they have a drum break rear 10 bolt isuzu axle and an 8 bolt front. if it is a later 87.........with 12 bolt disk brake rear and 10 bolt front.....then it is a very good deal. they usually have the carborated 2.3L 4cyl........at leat the 87 i had did. Not as good as the Fuel injected 2.6L that started in 88. all in all $300...................if it runs........yeah it's a good deal and you could swap the stuff into your LUV
Matt, Owner: Independent4x www.independent4x.com 804-550-0480: 9am-6pm EST UFWDA Life Member - http://www.ufwda.org/ Full Service Fabrication Shop & Retail Store located in Richmond, Va. for all your OffRoad needs: featuring Sway-A-Way, WARN, ARB/OME, AEV, Advance Adapters, TeraFlex, Trailready, Currie, QA1, Beard Seats, Interco Tire, D.O.M. Tube to length, etc. - call or PM |
Member # 15939
no im looking for another little ZU for a daily driver whith more room. And besides i already have a spare running gear for my 80 luv out of my 78
Member # 15939
One more thing. Will the bell housing bolt patern be the same on this motor as it is for a 2.2L diesel? I was just wondering becouse i can get one of these realy easy and it would make more sense for a daily driver i think.
Member # 20564
good buy
A two door trooper with sound body is in my mind a good deal.
86 Topless Turbo Diesel Trooper SAS SOA Custom Alum Dash, Cage, Dana 44 front, Detroit ezlocker, Zoo 12 bolt rear Lincoln Locker, cherokee springs, Alum radiator, 36" Super swampers, Stack & Snorkle, VDO gauges -- 2001 Dodge Ram 2500 4x4 Cummins Superchips, K&N, TST j-hook, transgo VDO gauges |
