Member # 15939
Well 23 years and 230,000 miles latter the stock front end on my luv is in need of a rebuild. Has anyone doen a rebuild on an 8bolt ifs, i have the parts (ball joints bearing seals and tie rods) but would just like to know if there is anything to look out for. And yes i have thought about an SAS but as this is my daily driver i need minimum down time. Thanks.
1999 Stock poser TJ, DD 1973 Wagoneer, mall crawler project... |
Member # 9222
just put the yota front in,spring over the rear and adapt a yota front shaft to your case. i did mine for less than $200 and one week of down time. one saturday in the rain torching junk off and five eve's after work glueing junk on. the toughest part was building the frame extension for the front spring mounts.
you are at about the same mileage as when my ifs ring and pinion departed the housing and a tie rod end ripped itself out of the sleave.IMHO i wouldn't put a penny into the ifs front end,but if you do it's pretty basic auto repair type stuff .
Member # 15939
yeah well i already placed the order for the parts. Good thing it was only $250. I kinda whanted to do an SAS but whith this many miles and tha fact that its primarilly used on the road led me to just rebuilding the front end to retain some better on road manners, and it has been proven to be reliable(especially whith whoping 28" tires). That and also i ruteinly tow a 3,000lbs trailer so much more lift than the 2" i have on it would get kinda scary
1999 Stock poser TJ, DD 1973 Wagoneer, mall crawler project... Last edited by mepr; 10-18-2003 at 10:21 PM. |
#4 (permalink) | |
Member # 9222
Member # 15939
actually the 1.8L in it only has 12k on it, i rebuilt it last summer to make shure that stuff didnt leave me stranded and whith out a rig. So all of that stuff is brand new, and i rebuilt the radiator to make shure it runs nice and cool (180* all the time)
The only part that wasnt reliable was the old point type distributor, but i got an elctronic one from an 82 luv and solved that problem in an afternoon.
1999 Stock poser TJ, DD 1973 Wagoneer, mall crawler project... Last edited by mepr; 10-18-2003 at 11:17 PM. |
