SAS Torque Specs - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-31-2003, 04:53 PM   #1 (permalink)
Member # 20564
SAS Torque Specs
OK<
I need torque specs for a Dana 44 out of a cherokee 1977. ball joing nut (upper and lower)
High steer arm 3 nuts on top of split cones.
ball joint adjustment sleeve for Pre load. does anyone have or remember this adjustment?
thanx in advance.
86 Topless Turbo Diesel Trooper SAS SOA Custom Alum Dash, Cage, Dana 44 front, Detroit ezlocker, Zoo 12 bolt rear Lincoln Locker, cherokee springs, Alum radiator, 36" Super swampers, Stack & Snorkle, VDO gauges
2001 Dodge Ram 2500 4x4 Cummins Superchips, K&N, TST j-hook, transgo VDO gauges
AirTrooper is offline   Reply With Quote
Old 11-02-2003, 07:52 PM   #2 (permalink)
Member # 20564
what I found
Well...
I used 65 ft. lbs for the cone nuts on steering arm.
I torqued the Knuckes as follows:
1. bottom ball joint 80 ft. lbs
2. pre-load adjusting sleeve upper 40 ft. lbs
3. Upper ball joint nut 80 ft lbs. (this should be 100?)
got this info from the Jeep guys.
