Member # 15939
lright might be a dumb question but what wieght should i put in an MUA5? is it straight 30wieght motor oil like my luvs tranny/t-case?
1999 Stock poser TJ, DD 1973 Wagoneer, mall crawler project... Last edited by mepr; 11-24-2003 at 09:29 PM. |
Typical White Guy
Member # 9769
I use Mobil 1 5W30 just because that's also what I put in my t-case (Tera Lows). IIRC, the manual calls for 10W30. Check the fill plug, mine says it on there.
________ BODY SCIENCE Last edited by Indyguy; 04-26-2011 at 07:38 PM. |
technical expert
5W 30 motor oil ONLY.....................DO NOT use GEAR OIL
Matt, Owner: Independent4x www.independent4x.com 804-550-0480: 9am-6pm EST UFWDA Life Member - http://www.ufwda.org/ Full Service Fabrication Shop & Retail Store located in Richmond, Va. for all your OffRoad needs: featuring Sway-A-Way, WARN, ARB/OME, AEV, Advance Adapters, TeraFlex, Trailready, Currie, QA1, Beard Seats, Interco Tire, D.O.M. Tube to length, etc. - call or PM |
Member # 15939
alrighty that makes things simple, all the fluids are exactly the same as my luv
Oh and also, both t-case and tranny use the same fluid resivour corect?(my shop manual tells me theres one drain plug and 2 fill plugs)
1999 Stock poser TJ, DD 1973 Wagoneer, mall crawler project... Last edited by mepr; 11-25-2003 at 05:18 PM. |
technical expert
yep shared oil bath
#6 (permalink) | |
Member # 1005
There are 2 fills and 2 drains. Loosen the fills before pulling the drains. They have a habit of seizing. Refill both through the shifter holes. Much easier than trying to coax oil up into a 1/2" hole above your head. ![]() Michael |
#8 (permalink) | |
Typical White Guy
Member # 9769
T-case fill plug is on passenger's side (may have to remove skid plate to loosen it if it is really tight, drain plug is directly on bottom and accessed through the hole in the skid plate. ________ How to export replays starcraft 2 Last edited by Indyguy; 04-26-2011 at 07:38 PM. |
#9 (permalink) | |
Member # 1005
Michael |
#10 (permalink) | |
Member # 12056
Wimmen don't understand the smell The pump in the picture lists for ~$30. You can get a disposable version for less than $6 IIRC. It's better than removing my shifter boot don't ask Last edited by GonZu; 11-26-2003 at 12:39 PM. |
Member # 15939
alrighty thanks for the help. The filling through shifters thing will save me headache in the future. When i swaped out the tranny fluid in my luv i used a suction gun thing and still got oil everywhere. Shifter boots are easy enough to pull
Alright so the mua 5 has 2 drain and 2 fill, huh guess ill lo0ok at it closer then
1999 Stock poser TJ, DD 1973 Wagoneer, mall crawler project... |
#12 (permalink) |
Member # 14868
trooper auto
what about fluid changes in an automatic equipped 1999 trooper? Even the dealer has not been able to give a straight answer on when it needs to be done- only that they need $129 to do it because it upsets the computer. I love technology!
FOR SALE:85 SJ410 tintop,WARN HS9500i , 33"TSL, lincolnlocker, 4.3EFI, 2004R, howell harness, aluminum rad , details etc. 73 chevy cheyenne 12bolt,govlok,dana44,350 4bbl,th350,np205 |
#13 (permalink) |
Member # 15939
well my chilton manual says 15,000miles and or every 12months is the change increment, and it needs dextron II or III.
1999 Stock poser TJ, DD 1973 Wagoneer, mall crawler project... Last edited by mepr; 12-05-2003 at 11:20 PM. |
