toyota T-case in an Isuzu - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-26-2003, 04:24 PM   #1 (permalink)
Member # 7742
Hey guys, just doing a little research here. I put a Geo Tracker engine and automatic transmission in my Samurai. While researching this, I learned that the Isuzu 4L30E is based off of the Trackers 3L30 (3-speed) transmission. So I am thinking that I can use a 2.8 Isuzu engine and mate it to the Tracker transmission using an Isuzu bellhousing. How is this engine? Is it the same as a Chevy 2.8? Any other engines use the 4L30E transmission? Also, this may interest you guys. I am not sure what you guys have for options for T-case gears, but the transmissions also appear to share the same tail housing. If this is so, there is an adapter to mount a Toyota T-case to a Tracker transmission that could be used on this transmission. There is also an adapter to install a Toyota T-case to a Tracker T-case (which you could bolt to a Isuzu transmission) giving you a dual T-case set-up. Just something to think about.
samiguy is offline   Reply With Quote
Old 11-26-2003, 04:45 PM   #2 (permalink)
Member # 6359
Location: Placer County, CA Where the Green Grass Grows
The other Place
Try this over at the 4x4wire Isuzu.
Isuzu Tech
not surprized yer confused yer face was burried in the pillow pretty deep as gizim drunk as you were
Lil Uzi is online now   Reply With Quote
Old 11-26-2003, 10:24 PM   #3 (permalink)
maxwell417's Avatar
Member # 20491
Interesting .... Unless you already have a 2.8L 60* v6. I would suggest a 3.4L 60* v6, same bolt pattern and basic block, more power about same cost. Isuzu puts the starter on the left side vs GM rear drive on the right side.
Do you have link or more info about the adapter to mount a Toyota T-case to a Tracker 3L30 transmission and Toyota T-case to a Tracker T-case adapter?
OK .... OK I know I should click the search button
Troopers 89RS 33's & 90 3.4v6 SAS D44 5.38s ARB/12Bolt Hobart Revolution 3.07 4Low Cooper 35s
maxwell417 is offline   Reply With Quote
Old 11-27-2003, 04:34 AM   #4 (permalink)
Member # 7742
here is the link for the toyota to tracker case. It is shown with the 5 speed but also works with the auto. There is not much info in the tracker-to- toyota case adapter (click on 'kicker 4'), its a new item but you could call these guys. I bet they wont know anything about adapting it to an Isuzu, I dont think its been done before. If you do a search on the samurai board for 'kicker 2' you car hear what they have to say about it. On the stock set-up, there is an adapter, about 1" thick, between the transmission and the T-case, you would need this from the tracker auto, it should bolt to your Isuzu transmission, then that would allow you to use the tracker or toyota T-case. I forgot to mention in my last post that if you used a tracker T-case, the adapter these guys sell allows you to mount the toyota T-case to it. That price includes modifing the tracker case to get rid of the front output. I am sure it would work, the only question is if the output shaft of the transmissions are the same. If anyone has a 4L30 with the T-case removed and can get a spline count and length that it sticks out, I can do the same with my 3L30
Old 11-27-2003, 08:24 AM   #5 (permalink)
technical expert
Independent4x's Avatar
Member # 8755
Send a message via AIM to Independent4x Send a message via MSN to Independent4x Send a message via Yahoo to Independent4x Send a message via Skype™ to Independent4x
" I learned that the Isuzu 4L30E is based off of the Trackers 3L30 (3-speed) transmission"
the 4L30e is the auto that came in the Rodeo - 93-97 mated to a 3.2L SOHC or DOHC motor......this was never mated to a 2.8L w/ 60 degree bellhousing
the 4L30e is a GM trans...............since GM owns stake in Isuzu as well as Geo i would assume your trans is a GM as well.
the Isuzu 2.8L v-6's came w/ a MUA5 isuzu 5-speed or an Aisin Warner auto (shared w/ toyota in some applications)
the trans/case combos are integratedand share a gear
there are no removable bell housings on and isuzu trans to the best of my knowledge
still VERY VERY curious about all this so lets see some more facts on this........................ hope this info helps a bit
Matt, Owner: Independent4x
www.independent4x.com
804-550-0480: 9am-6pm EST
UFWDA Life Member - http://www.ufwda.org/
Full Service Fabrication Shop & Retail Store located in Richmond, Va. for all your OffRoad needs: featuring Sway-A-Way, WARN, ARB/OME, AEV, Advance Adapters, TeraFlex, Trailready, Currie, QA1, Beard Seats, Interco Tire, D.O.M. Tube to length, etc. - call or PM
Independent4x is offline   Reply With Quote
Old 11-27-2003, 05:21 PM   #6 (permalink)
Member # 7742
I saw somewhere that the 90-91 2.8 had the 4L30. Also, my 4L30 overhaul manual lists this transmission behind a 2.8. NAPA lists parts for that trans with a 2.8, but they could be wrong. Do all the engines have the same trans bolt pattern? If so, then its a moot point.
the trans/case combos are integrated and share a gear
I know the trans/case are married but they will seperate. I ordered a rebuild kit for my and I believe the 4L30 kit had the same part number. I wanted a manual for the 3L30 but there isnt one, the guy told me to use the 4L30 manual so I got one of those. I read the manual although it does not cover the T-case. The tail housing gasket is the same between the 2 transmissions, meaning that the tracker/toyota Tcase will physically bolt up, I just dont know if the output of the trans will mate up with the input of the T-case. If all Isuzus use the same T-case then the tracker/toyota T-case should work
the 4L30 definatly does, that is the only thing I am 100% sure of
any info helps. I am going to look into this further. If I can get my hands on a 4L30 I can answer these questions quickly. Or, if anybody have one laying around that can take a few measurements, we can get to the bottom of this .
Old 11-27-2003, 10:06 PM   #7 (permalink)
maxwell417's Avatar
Member # 20491
samiguy, you are right. My v6 a/t 90 Trooper has a GN 4L30E in it.
Old 11-27-2003, 10:35 PM   #8 (permalink)
Member # 161
How can i find out what tranny is in my 90 a/t v6 trooper? I am very interested in this. I've had this beauty of a Trooper sitting in my driveway for a year now. If I could get it to go really slow without changing the entire drivetrain I would know why I kept it for so long.
1967 FJ45LV-1972 FJ40-1986 FJ60
Rev. Parsley is offline   Reply With Quote
Old 11-28-2003, 04:48 AM   #9 (permalink)
Member # 7742
cool, now I know I if the bell housing fits I can easly install a V6 in my sami
Look at the transmission pans, if it has 2 pans its a 4L30E.
Old 11-28-2003, 07:41 AM   #10 (permalink)
Member # 7742
ok, I confirmed it, I just went to a bone yard and found a '91 Trooper with a 2.8 and a 4L30E. The engine was gone but the sticker said the engine was a 2.8. The transmission was $300 and they wouldnt let me take just the bell housing. Man, that T-case is huge! The investigation goes on...
Old 11-28-2003, 09:29 AM   #11 (permalink)
technical expert
Member # 8755
well shit...................ok i guess i was off....interesteing, so there are isuzu bolt patern 4L30e's for the 3.2L and GM 60* bolt pattern 4L30e's for the 2.8L
the 2.8L auto ................should have a standard 60* bolt pattern just as the manual mua5's do.
the Aisins....were the auto for the 2.6L 4cyl.
cool tech...........keep this updated as you proceed.
Old 11-28-2003, 09:52 AM   #12 (permalink)
Member # 7742
I believe some Cadilliac V8s also share the GM60* pattern. Hmmm... On one listing I saw that the 3L30 and 4L30 tail housing gasket had different part numbers (they were off by 1 number) but they looked the same in my 4L30 overhaul manual. I have to look into that more.
Old 11-28-2003, 12:11 PM   #13 (permalink)
houlster's Avatar
Member # 6292
Nope, all 4L30e's used the GM 60 deg pattern. The 3.2 has a dual pattern block. One pattern for the manuals and a 2nd GM 60 deg pattern for the 4L30e.
--Dan
SC Amigo
houlster is offline   Reply With Quote
Old 11-28-2003, 01:10 PM   #14 (permalink)
Member # 16384
Send a message via AIM to paulevans76
that explains the dual bolt pattern. mystery solved
Anyone got numbers to compare the aisin auto and the 4l30e (as in gear ratios, hp/tq they can handle)? good tech!
paul
79 cj5 on tons
paulevans76 is offline   Reply With Quote
Old 11-28-2003, 01:16 PM   #15 (permalink)
Member # 7742
4L30 Gear Ratios:
1st: ( base)2.40
1st: (optional)2.86
2nd: (base)1.47
2nd: (optional)1.62
3rd: (base)1.0
3rd: (optional)1.0
4th: (base)0.72
4th: (optional)0.72
Rev: (base)2.0
Rev: (option)2.0
Maximum Engine Torque:
258 lb (350 Nm)
Maximum Gearbox Torque:
440 lb (600 Nm)
not sure about the Asian transmission
Old 12-19-2003, 07:12 PM   #16 (permalink)
Member # 161
Old 12-20-2003, 05:03 AM   #17 (permalink)
Member # 7742
still researching. I am at a dead end until I can get my hands on a transmission or someone here has one. I have a 3L30 tailhousing gasket I would like match to a 4L30 tailhousing to see if the tracker dual T-case will bolt onto the 4L30. I cant seem to get ahold of a 4L30 gasket unless I buy the whole kit. Nobody has a junk 4L30 laying around??
Old 12-20-2003, 04:00 PM   #18 (permalink)
technical expert
Member # 8755
PM highHonda.....................it's Doug Brown.....he has one, i 'll give him a call and tell him to keep an eye out for the message
Old 12-20-2003, 04:22 PM   #19 (permalink)
Member # 7742
I looked on the members list, there is no 'highhonda' listed, is it spelt different? I have the Tracker tail housing gasket I could send him to see if it matches the 4L30 trans, if it does, we are one step closer...
Old 12-21-2003, 05:43 PM   #20 (permalink)
Newbie
cdiamondc's Avatar
Member # 25457
2.8 v6
I have seen three 60 degree 2.8 v6s out of zuzu trups and rodeos and they all have GM on the block casting in the same place as my kids 2.8 blazer!!!
cdiamondc is offline   Reply With Quote
Old 12-21-2003, 09:18 PM   #21 (permalink)
Highonda's Avatar
Member # 8751
WELL, JUST TO UPDATE,
ME AND RANDY HAVE SPOKE OVER THE E-MAIL THING.
HE IS SENDING ME THE GASKET, I ACTUALLY HAVE 2 TRANNYS LAYING AROUND HERE.
I AM SENDING ONE OF THE BELL HOUSINGS TO HIM FOR DOUBLE CHECKING THE BOLT PATTERNS.
WILL UPDATE LATER IN THE WEEK AFTER I RECEIVE THE GASKET.
BTW, CHECK OUT MY YELLOW STAR!!!!
SEE ME FOR YOUR DANA 60 NEEDS.
THANKS DOUG
Douglas Brown
Extreme Axle Sales
[url]www.ExtremeAxleSales.com[/url]
CONTACT ME FOR YOUR FRONT DANA 60
COMPLETE AXLES & PARTS
[email]Highonda@optonline.net[/email]
[COLOR=DarkOrange]845-598-0545 cell[/COLOR]
Highonda is offline   Reply With Quote
Old 12-23-2003, 01:16 PM   #22 (permalink)
CtTrooper's Avatar
Member # 23953
Send a message via AIM to CtTrooper
hope this helps:
bolt patterns and v-8 info
Cadillac 4.9 V-8 swap into a Trooper
CtTrooper is offline   Reply With Quote
Old 12-23-2003, 02:35 PM   #23 (permalink)
Member # 7742
interesting info...
I sent the gasket out yesterday, Highonda should get it in a day or two.
Old 12-26-2003, 09:05 PM   #24 (permalink)
Highonda's Avatar
Member # 8751
tranny 4l30e
well,
after pulling the old 4l30e out of the shed tonight. and with the gasket randy (samiguy) send.
drum roll..........
it fits!!!!!!
except for one mounting holes is off, but looking at the gasket there must be something to tap into on the other side because the gasket material i still available there. (see pic)
in the pic, i bubbled the spot where the hole is on the 4l30e.
randy,
the output shaft is 27 spline and the shaft dia. is 1" 3/16th wide.
again see pic.
i am sending the bellhousing to you on monday, the gasket is in the top of the box.
do you want me to send you the backing plate to the 4l30e for comparision?
let me know.
ok start asking questions.
i am thinking as is randy right about now that this opens the box for options for the t-case options for us isuzu guys.
randy e-mail me at: highonda@optonline.net
thanks
doug
Douglas Brown
Extreme Axle Sales
Old 12-26-2003, 09:06 PM   #25 (permalink)
Highonda's Avatar
Member # 8751
second pic of the gasket.
Douglas Brown
Extreme Axle Sales
