1994 Release Bearing noise problem... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-29-2003, 07:52 PM   #1 (permalink)
Member # 25662
Hey, I have a 1994 Trooper LS, we just replaced the clutch it keeps squeeling like the release bearing is spinning, the clutch is also slightly engaged when pressed(like when its in 1st and i let the brake off, it moves, like an auto, but its a manual...) Can anyone help with this problem, we replaced the master cyl., the clutch and bearings, but not the slave cyl. Could the slave cyl. be the problem?
bigbronco2 is offline   Reply With Quote
Old 01-02-2004, 06:27 PM   #2 (permalink)
Member # 21000
Send a message via AIM to CPOM
The slave is going to help you disengage the clutch. If you dont have a problem with that, sounds like you don't, then its not going to help with the squealing.
[COLOR="DarkSlateGray"]Chris
92 Isuzu Pup, 3800>r150f>dual toy cases
toy 8", isuzu 12bolt, not done yet[/COLOR]
CPOM is offline   Reply With Quote
