Coil Packs - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-01-2004, 11:31 AM   #1 (permalink)
Member # 25650
Coil Packs
I am just curious if anyone has ever had problems with their coil packs going bad? I can understand if one goes bad but within about a year and a half we replaced four out of six! What causes them to go bad? and is it common to go through them that fast? Its a 1997 Rodeo two wheel drive.
Thanks,
Dave
mad mudster is offline   Reply With Quote
Old 01-15-2004, 11:11 AM   #2 (permalink)
Member # 25200
this is definately not normal, have you had any other work done to your rodeo where someone may have disconnected the ground wire on the engine block. and then didn't reconect it?
If not, then maybe you could investigate to see if it has gotten damaged somehow. It wouldn't hurt to check.
I personally don't like the coil-over design of the later model v-6 engines. I have an 89 pickup with one coil.
ISUZU's are the best, especially with .040 over pistons! :) But I am partial to Ford's as well.
isuzufool is offline   Reply With Quote
