rodeo 44 gears to waggy Q - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-29-2004, 07:02 PM   #1 (permalink)
Member # 8713
sorry fellas x-post from gen 4x4.
My roomate has recently aquired an isuzu (r) and a waggy (f) set of 44s.
He wants to match the 4.30s in the suzu in the front. They run a thick gear on a low numeric carrier.
he searched here, but could not find the answer to:
Will thick isuzu 44 gears fit another 44?
He's looking for a cheap way into decent gears by buying another isuzu 44 for gears, spare shafts/brakes.
Worried 'cause the shafts are big, necked down to 30spl.
It's $300+ for just gears and he can get into the gears and spares for ~$250.
Will they do it for him?
just gears wanted too if they work for him...
thanks fellas.
FiWi
preach is offline   Reply With Quote
Old 01-29-2004, 07:57 PM   #2 (permalink)
Typical White Guy
Member # 9769
If he gets a carrier (be it open, LSD, or locker) for the Waggy axle that would usually go with numerically low gears, he should be able to run the Isuzu 4.30's on that. The only difference in Zu gears is that they have a numerically higher ratio, but the thickness of a numerically lower D44 gearset. I'm no D44 expert by any means, but I believe the cut-off point is 3.73's
________
LovelyWendie99
Indyguy is offline   Reply With Quote
Old 01-29-2004, 08:04 PM   #3 (permalink)
Typical White Guy
Member # 9769
Oh, and JMHO...... but I would encourage him to check into the cost of replacement gears. Never done a price comparison myself, but I would imagine the Zu gears are pretty spendy compared to regular D44 stuff. Since he's probably looking at buying a new carrier anyway (locker), it may be a better investment to just stick with standard D44 stuff.
________
FIX PS3
Old 01-30-2004, 06:03 AM   #4 (permalink)
technical expert
Independent4x's Avatar
Member # 8755
Send a message via AIM to Independent4x Send a message via MSN to Independent4x Send a message via Yahoo to Independent4x Send a message via Skype™ to Independent4x
you already have the correct open carrier in that waggy 44 since they come w/ 3.07's or 3.42's
all he needs to do is drop the ing and pinion in there. Only snag i see is that there coold be some minimal differences in the pinion bearings....but as long as the axle is say ------ '93-96 he should be fine.
you could then drop a Lockright or similar lunchbox locker in..........and Indyguy is correct, on the same line of thinking.............if you want a full carier locker.......you will just need to get the low ratio one even though you have a 4.10
Matt, Owner: Independent4x
www.independent4x.com
804-550-0480: 9am-6pm EST
UFWDA Life Member - http://www.ufwda.org/
Full Service Fabrication Shop & Retail Store located in Richmond, Va. for all your OffRoad needs: featuring Sway-A-Way, WARN, ARB/OME, AEV, Advance Adapters, TeraFlex, Trailready, Currie, QA1, Beard Seats, Interco Tire, D.O.M. Tube to length, etc. - call or PM
Independent4x is offline   Reply With Quote
Old 01-30-2004, 02:38 PM   #5 (permalink)
Member # 8713
thanks.
FiWi
Old 01-31-2004, 08:16 AM   #6 (permalink)
Member # 21888
Yes they work, I just did it a couple months ago. There is a difference in pinion bearings but thats not an issue just use the waggy bearings
psychobilly is offline   Reply With Quote
Old 01-31-2004, 11:00 AM   #7 (permalink)
Member # 19786
Thanks for the info. It's actually my rig they are going in.
newton is offline   Reply With Quote
Old 01-31-2004, 08:59 PM   #8 (permalink)
Member # 23566
Send a message via AIM to SirMrManGuy
Any of you guys know aproximatly how much a set of 5.13s for the zuzu Dana rear cost? Links to where I can find a set?
SirMrManGuy is offline   Reply With Quote
Old 02-01-2004, 03:34 AM   #9 (permalink)
Typical White Guy
Member # 9769
You will just have to get regular D44 5.13's and the standard higher-ratio carrier to put them on. Isuzu never offered 5.13's, but this combination can be used together in the Zu D44.
________
Small Dick
Old 02-01-2004, 08:52 PM   #10 (permalink)
Member # 23566
Cool, thanks for clearing that up for me, I thought there might be something odd with isuzu modle.
Old 02-02-2004, 10:37 AM   #11 (permalink)
Member # 21888
There are thick gears that will work on the suzu carrier
Old 02-07-2004, 12:44 PM   #12 (permalink)
Member # 19786
Thanks everyone. Now does anyone have any zu 4.3:1 gears kicking around?
Old 02-07-2004, 02:23 PM   #13 (permalink)
Member # 1005
I assume you are looking for gears for the Isuzu D44, but just to make sure, what axle are you inquiring about?
Michael
mlclark is offline   Reply With Quote
Old 02-07-2004, 04:46 PM   #14 (permalink)
Member # 19786
Michael
Yup, 4.3:1 for the Isuzu D44
