Project SBC - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-31-2004, 11:33 PM   #1 (permalink)
Member # 20695
Project SBC *new pics*
Well the swap has started. The motor and tranny are out, as are the front CV's/diff. I left the a-arms and outers on so I can keep the front wheels on til I get everything done except the front axle. First order of business next weekend is fitting the 283/465/205 combo... The 283 will be running on propane, so I also have to find and fit a tank somewhere... I have everthing else, just need a newish tank now. I've also decided to stick with leafs for the SAS just to keep the down-time of my rig to a minimum. I'll be using the stock rear trooper springs up front, and a set of 2003 F150 spring in the rear(56" long) This will move the rear axle back ~2 1/2 " and I'll also be moving the front axle forward. Once the motor etc is in and the springs are in up front and rear, I'm going to see if I can do the front SUA without major steering link/ oilpan clearance probs then match with SOA in the rear... I want to keep as low as possible and will trimm as much as needed to fit the 37"s I'll be getting this month. After the driveline is done and it runs/drives, the next step is chopping off the rear roof area and bringing it to Camrock for the exo... I have way too much shit to do now... I gotta get some help I think!!!!
Anyone want to come to Canada to help???
89 Trooper Supercrew
283/SM465/np205 twinstick burning BBQ juice
on 37"s
Grampa is offline   Reply With Quote
Old 02-01-2004, 12:02 AM   #2 (permalink)
Ship Driver
Member # 20378
If only I was closer, man... I'd be there...
Anyway, I'm glad to hear you're making progress. You know what I'm waiting for...
Kuranosuke is offline   Reply With Quote
Old 02-01-2004, 09:22 AM   #3 (permalink)
Member # 26090
Re: Project SBC
damn...i just went back to work after fawkin' off for 6 months. spent almost a month up near your neck of the woods on San Juan Island.
sacramentophil is offline   Reply With Quote
Old 02-01-2004, 06:26 PM   #4 (permalink)
Member # 20695
Shit! I'm only 40 min. from Vancouver and 2 min. from the Can/US border... San Juan is fawking beautiful...
on 37"s
Old 02-01-2004, 08:55 PM   #5 (permalink)
Member # 25484
Shit I'm about to go postal here in NJ with all these cosmo fvcktards - you got a heater in your garage?! Hell I'll sleep in my truck, as long as I can get an occasional day off to get my boardin' fix in at Whistler then I'm down.
Hyunduzu is offline   Reply With Quote
Old 02-01-2004, 09:11 PM   #6 (permalink)
Member # 20695
I just got back from a foot of fresh pow at Hemlock resort just near me, and yup my garage is heated... 12ft doors, 44ft long by 42 ft wide. full air tools, wood working tools, 180 mig, chopsaw, grinders, torches and on and on
I own an RV repair shop so I gotta have room for the big bling A class busses
on 37"s
Old 02-01-2004, 10:46 PM   #7 (permalink)
Member # 20834
Re: Project SBC
If only i had the money to get there
rubo
rubo is offline   Reply With Quote
Old 02-02-2004, 08:22 PM   #8 (permalink)
Member # 20695
Kuranosuke, the diff is out. Give me a call or I'll call you... mmmmmmmmmm... lockers
on 37"s
Old 02-02-2004, 08:47 PM   #9 (permalink)
Ship Driver
Member # 20378
Ok, I sent you a PM on the wire. I think I gave you the wrong number, so I'll call you tomorrow...
Old 02-07-2004, 09:05 PM   #10 (permalink)
Member # 20695
Just a quick update... Motor is in, mounts are made and welded up, and tranny is bolted up. I had to chop the shifter hole farther forward 4", and cut off the bottom of the heater box, but it all went in slick. I ended up using the stock trooper engine mounts. Raised them up 1 14", then made a plate that bolts to the chev block in the stock chev mount holes, and extends back to the stock troop mounts. I forgot my digi at home, but I'll be pulling everything out again for clean-up and paint, so I'll get some pics then. Ive got lots of room for the HEI dist. but room for the rad is at a premium. I'll be mounting it right behind the grill like Matt did, and run hood pins.
Matt, if I for get to call you, give me a ring at the shop... 604 855-9666
on 37"s
Old 02-09-2004, 06:34 AM   #11 (permalink)
technical expert
Independent4x's Avatar
Member # 8755
Send a message via AIM to Independent4x Send a message via MSN to Independent4x Send a message via Yahoo to Independent4x Send a message via Skype™ to Independent4x
uh.....pics
you're killing us
Matt, Owner: Independent4x
www.independent4x.com
804-550-0480: 9am-6pm EST
UFWDA Life Member - http://www.ufwda.org/
Full Service Fabrication Shop & Retail Store located in Richmond, Va. for all your OffRoad needs: featuring Sway-A-Way, WARN, ARB/OME, AEV, Advance Adapters, TeraFlex, Trailready, Currie, QA1, Beard Seats, Interco Tire, D.O.M. Tube to length, etc. - call or PM
Independent4x is offline   Reply With Quote
Old 02-09-2004, 05:41 PM   #12 (permalink)
Member # 12056
Originally posted by TrooperRS
you're killing us
You are too dude
I need pics of this forward mounted radiator, brackets, and hood pins
HowTF are you guys protecting the aluminum radiator ?
chickenwire ?
GonZu is offline   Reply With Quote
Old 02-09-2004, 07:21 PM   #13 (permalink)
Member # 20695
Ya Matt, your website project pics havent been updated in a while... None of those "I've been moving..." excuses or "I've been way to busy at the shop" please hehehe JK. I keep forgetting the Digi at home and I cant post pics of a greasy 283 and leaky 465, not to mention the shit-hole mess of left over wires and vaccuum hoses(WTF was Isuzu thinking? ) that I havent stripped from the engine comp.
once its all cleaned up and pic worthy, I'll be a post whore for a bit so dont worry... they will be along shortly
on 37"s
Old 02-09-2004, 07:26 PM   #14 (permalink)
Member # 20695
Here
How would you like to tow your rig in here?
I'm putting in full living quarters with shower/toilet, fridge, stove, hot water, satellite, plasma TV, overhead engine hoist,dual sleeping bunks on second level, outside BBQ and heater quick-connects, A/C, electric awning w/ built in lights,etc... inside measurements are 32 ft long, 10 ft high and 8 ft wide
on 37"s
Old 02-10-2004, 10:48 AM   #15 (permalink)
technical expert
Member # 8755
WHINERS..............
I HAD LIKE 300 PICS ON MY fawkin' CAMERS..THOUGHT I WAS "TRANSFERING THEM TO MY COMPUTER" BUT I ACTUALLY DELEATED THEM..............................UUUUUGGGGGHHHHHH H!!!!
that was like november or so..............pissed me off
anyway, here are a few that i still have:
Old 02-10-2004, 10:49 AM   #16 (permalink)
technical expert
Member # 8755
another
Old 02-10-2004, 10:50 AM   #17 (permalink)
technical expert
Member # 8755
another:
Old 02-10-2004, 05:11 PM   #18 (permalink)
Member # 12056
I'm serious about protection for the radiator.
I've had 1" rocks crack the windshield.
What would it do to an aluminum radiator ?
OhShit, I said that outloud
Gracias
Old 02-12-2004, 10:17 PM   #19 (permalink)
Member # 20695
new pics
Engine looks small in the hole
Mount design. It'll get trimmed and beautified when I remove everything to clean and paint
I modified the shift rail in my 205 for twin stick. Ultra easy mod
Tonite I got my trans crossmember mocked up... It'll hang down ~ 2" from the bottom of the frame in the center
on 37"s
Old 02-17-2004, 06:57 AM   #20 (permalink)
technical expert
Member # 8755
interesting motor mount design.
is that 5/8" plate (i hope)
what is all that IFS shite still doing in the way
Old 02-20-2004, 07:17 PM   #21 (permalink)
Member # 20695
Its 1/2" x 6" w x 8"L plate. The motor mount bolt is onlt 1 1/4" from where the plate mounts to the motor so I dont think it'll bend... besides, I'm "chaining" down the motor with 1/2" aircraft cable so there will be less pull on the plate. AF runs the same setup in his S10 with a 400 whp motor, but with 2.5" between mount points. He races it regularly at the track with no probs after 3 yrs.
That IFS "shit" is holding my wheels on so I can roll it in and out of the shop Seriously though, I got my front spring hangers fabbed and mounted today and tomorrow I do the rear shackle hangers. I should have it sitting on the new springs, axles and 37's by next saturday.
I'm only moving the axle 2" forward, and will deal with any rubbing issues with a BFH and/or torch and welder. my rear axle will be back 2" also for a 108" WB.
Does anyone have pics of how they did spring perches on the waggy diff housing?(pass side) My axle was SUA and I need to go SOA, but am a little iffy of just welding to the cast housing... I heard it aint so strong doing that.
I still havent found a propane tank to fit between the framerails where the gas tank used to be, but I'll figure something out there. I'm thinking maybe out of a Bronco or F150...
on 37"s
Old 02-20-2004, 09:25 PM   #22 (permalink)
ZU
Member # 2747
Send a message via ICQ to ZU
I might have to make a trip up to BC and take a look at that sometime. I'm working on the same swap with a TH350 and i'm having issues with gatting the rad mounted.
-Jesse AKA ZU
'89 Isuzu Trooper (wheelin rig), '42 Willys MB (extended work in progress), '94 Chev K2500 (tow rig), '72 Chev C10 (the hotrod)
ZU is offline   Reply With Quote
Old 02-23-2004, 11:50 AM   #23 (permalink)
technical expert
Member # 8755
ok...sounds like you got your bases covered on the motor mount......looks like a very simple solution....so i like that.
should hold up fine.
psyched to see some 37's on your rig
Old 02-23-2004, 05:15 PM   #24 (permalink)
Ship Driver
Member # 20378
I went and saw Joel's rig on Saturday, and it is going to be top notch! Yes, Joel, it was nice to meet you too...
Joel was also nice enough to let a little bad ass from his truck rub off on mine. Feel free to keep on changing yours so I can vulture all your stuff...
Oh yeah, you remember that little leak I told you about? The new 2 row replacement radiator will be here on Wednesday. 1000 miles in 3 days turned out to be a little more than she could handle...
Old 02-23-2004, 08:58 PM   #25 (permalink)
Member # 20695
Nice to meet you too Jon! Too bad about the rad, I had mine sitting in the corner Did they hassle you at the border?
Zu, any time you wanna come up feel free... let me know in advance and you can crash at my house. I havent got to the rad fitment yet, hopefully in a week or 2 but I'll let you know when I get to that point.
Just did a little looking today and my twin sticks will fit perfectly in the original xfercase shifter hole. One less thing to worry about. Also my chev front driveshaft works out perfectly for length according to my measurements, so I might not have to worry about lengthening it.
on 37"s
