93 rodeo build... maybe
my gf has a 93 rodeo with the 2.6 and its 2wd 5 speed. i was thinkin about it and i think it would be cool to make it into a wheeler. from what i saw the frame was boxed all the way down, which would make it easier to slap on some spring hangers up front and go solid axle. the 2.6 is small but it gets the thing goin, and with some gears it should be fine for 33s-35s max. i was thinking toy axles f&r. next problem is drivetrain.... did rodeos ever come with a 4cyl 4x4? is there a transfer case that will bolt right up? any1 know of any good isuzu links?
ps i already got her interested in a calmini cam and makin our own intake with a k&n cone |
Member # 25708
SAS is getting to be a much more common mod on Isuzus of all kinds these days, and there is alot of help out there (the internet) now from guys who have already gone through the trial and error phase doing this. I believe 93 & 94 were the only years the Rodeo came with a 4 cyl (4X4 at least) and the rear ends were GM 10 bolts. Matt at Independent 4X can supply alot of aftermarket, as well as SAS parts for your vehicle, should you decide to go this route. Toy axles up front are probably considered a good choice (among others), but Zu rear ends, properly geared, are also a pretty damn fine piece of machinery! Not sure what rear-end you have, but do some research-you might decide your rear axle will do the job just fine. Check out the links section at www.independent4x.com, or try 4X4 Wire.com (Isuzu Section) & Planet Isuzoo.com- Hope this helps. Good Luck
Toddzu/Hawaii
96 Rodeo 4X-3.2 SOHC 3.5" susp. lft. 1 pc. C/V driveline, K&N drop-in Pro Comp Shox, 33" Firestone Destination M/Ts, many othr modz Last edited by Toddzu; 02-12-2004 at 12:21 AM. |
pretty sure its a 10 bolt rear. its got the 2 tabs cast into the bottom of the housing. thanks for the link. ive searched around for some well-built rodeos and ive really only found 2 or 3 and they were either relatively stock or built beyond reckognition. i noticed there arent many threads in this forum.. do isuzu guys just not post here that often?
#4 (permalink) | |
Typical White Guy
Member # 9769
Toy axles f/r is one choice if you want to ditch the rear 10bolt. Another option is to put an Isuzu D44 from a newer Rodeo or second gen. Amigo in the rear and match it with a late-70's Jeep Wagoneer D44 up front.________ MARIJUANA REHAB DICUSSION Last edited by Indyguy; 04-26-2011 at 07:55 PM. |
ok so next i gotta figure out what tranny/ t case to use. it would be nice to keep the stock tranny but what can it be swapped out for? and is there a way to get a hydraulic clutch in there and get rid of that funky clutch linkage if i do decide to keep the stock tranny? would a toy t case bolt up to the 4 cyl 5 spd tranny? toy would be pass side drop for a toy or a waggy front
Member # 20695
You can go to the MUA5 isuzu tranny/transfr case... it was the unit that came stcok behind the 2.6l... Tera makes gears for it too.
Go toy axles, smurf 'em, add some 5:29's and run a set of 36" IROKs. Just an idea
89 Trooper Supercrew 283/SM465/np205 twinstick burning BBQ juice on 37"s |
#7 (permalink) | |
Typical White Guy
Member # 9769
________ Kitchen Measures Last edited by Indyguy; 04-26-2011 at 07:55 PM. |
