technical expert
little inspiration for the SAS'ers and greetings from Chile
spoke to my friend from Chile today.......he's beebn slowly working on his 95 trooper, well really for the past year now.........i've been shipping parts down to him.................so, i thought i'd post up some of the progress pics for you guys to give you some winter inspiration.
Matt, Owner: Independent4x www.independent4x.com 804-550-0480: 9am-6pm EST UFWDA Life Member - http://www.ufwda.org/ Full Service Fabrication Shop & Retail Store located in Richmond, Va. for all your OffRoad needs: featuring Sway-A-Way, WARN, ARB/OME, AEV, Advance Adapters, TeraFlex, Trailready, Currie, QA1, Beard Seats, Interco Tire, D.O.M. Tube to length, etc. - call or PM |
technical expert
he's been re-doing his 1'st version of the axle swap...................so out with the old coils/shocks/arms etc.................
in with the new stuff:
technical expert
i's not done, but deff looks like it is coming together now
here's some scale for what you are looking at:
technical expert
FJ axle up front, isuzu 12 bolt rear, the suspension is a compilation of skyjacker parts for TJ and Ford Ranger........Eddlebrock shocks and a bunch o' fab work.
technical expert
here is a little history on the rig.............95 RS, stock with a IFS lift
technical expert
chopped the top
technical expert
also.............motor is out...getting a drivetrain swap with a built Chevy 350 (was carbed, now converted to FI w/ an Edllbrock kit) flat top pistons, cam, rollers, yada yada....pushin 400hp +/-
new trans and case installed...................you gett he point anybody jealous yet.
technical expert
the US got this body style trooper for 1 model year....1993.
is South America.....they are not marketed as Isuzu at all.........they are Chevrolet Troopers
Member # 20612
That trooper is awesome and
hot. I want one. Hey Matt now that my 88 trooper is pretty much done maybe i talk the wife into doing something like that on my 93 troop. I will have to show her the pictures and see what she thinks, crossing fingers she likes. Don
88 trooper dana 44 sas 35 in tires 4.56 gears 4.3 chevy th350 |
#12 (permalink) | |
Member # 12056
![]() Don't tell me Chileans are 4ft tall ![]() ![]() Excellent build ![]() I have ideas for the Amigo... they resemble this. ps. the Mrs won't let me cut the Trooper yet |
#15 (permalink) | |
Typical White Guy
Member # 9769
So am I to understand that the radius arms and brackets are just a simple combination of mass-produced aftermarket parts......... and they fit the Trooper that perfectly? Because it wouldn't be too hard to get some measurements and make copies for a much lower cost ![]() When the time comes to SAS the Amigo, I wanted coils but had pretty much settled on leaves for lack of experience building a link set-up. But copying a radius arm design...... I could probably pull that off with some research and practice ![]() ________ spanish girl Cams Last edited by Indyguy; 04-26-2011 at 09:29 PM. |
#17 (permalink) | |
technical expert
i'd have to go back and look at my notes, but basically those are TJ coils up front like 4" or 6" lift maybe and the radius arm kit is for a ford ranger. the mounts and brackets are fabbed. I mean you could certianly "copy" but really this stuff is not all that expensive, and looks like it works pretty well together. it would probably end up cleaner to just buy the junk and have a good springboard to work from, at least that way you have some of the peramiters set. you just have to think of your fab skills...........the time and cost of materials makes the "off the shelf" stuff pretty attractive for the 1st timer. just some food for thought.
#18 (permalink) | |||
Typical White Guy
Member # 9769
![]() ________ MARIJUANA INDICA Last edited by Indyguy; 04-26-2011 at 09:30 PM. |
#19 (permalink) |
technical expert
yeah........wasn't saying you don't personally have the skill. Just saying generally that "you" meaning guys in general, need to pick their battles. here is a close up of the arm that he sent me:
#20 (permalink) |
technical expert
the 350 in the truck:
#21 (permalink) |
technical expert
close up of the top chop and sheet metal jub.....looks good to me. they grafted the tail gate from a South American LUV pickup.............
pick up is a similar year.
#24 (permalink) |
Member # 33945
Ya, looking good!!!
[QUOTE=Mazda4x4][COLOR="Red"]She told me to give her eight inches and make it hurt so I fucked her four times and hit her in the head with a brick.[/COLOR] [/QUOTE] |
#25 (permalink) |
Member # 25557
I luv that Trooper have whatched it grow over the last yr or two,Thanks Matt
A question though that may show my stupiddity (see) Does the tierod go "thru" the panhardbar mount?I can see where it mounts on the frame but the pics make it look like it's attached to the tierod.Any closeup pics? Thanks and keep up the good job down south Bansil |
