gear ratio help - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-07-2005, 05:23 PM   #1 (permalink)
Member # 54924
gear ratio help
Can anyone please help me with info on what I may have for a ring and pinion ratio? The truck is a 1998 Amigo, 2.2L 4cyl, 5spd 4x4 with the G80 limited slip rear. I could just pull the cover off the rear end and count gear teeth, but I'm working so much overtime that I barely found a spare minute to type this. I also have a probem with the T-case popping out of 4-high, which I think may be caused by internal damage from having two different gear ratios, F/R. I suspect that the front diff had been replaced by Lithia, as they bought this vehicle at an auction, and it has evidence of being in a wreck. The T-case will stay in Low range if I put it there, but sounds really pissed off. I did check to make sure that both boxes have the correct type of oil.
Any help greatly appreciated, and thanks in advance....
Mike Barbarigos
Reno Nv
brokenarrow is offline   Reply With Quote
