THE Definative Tech Thread on the 1998+ Isuzu rear Dana 44 axle - Page 4 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-18-2015, 03:35 PM   #76 (permalink)
Member # 110248
So again based on your findings in the interest of definitive tech:
Problem: I need to re-gear my PITA 98+ Isuzu rodeo rear axle and I need to know what kind of gear set to use.
Solution: Use a Non-Rubi JK D44 gearset, which is also the answer for wheel bearings, wheel seals, and lunchbox lockers.
Problem: But the pinion splines aren't the same!!!1!!11!
Solution: Use the JK pinion flange, which uses the same flange bolt circle as the Isuzu anyway
Did I capture this correctly?
djljeep is offline   Reply With Quote Quick reply to this message
Old 08-19-2015, 08:01 AM   #77 (permalink)
Bradzuzu's Avatar
Member # 250265
I'd like to have a part # and correct description for that flange but it does indeed fit the bill dimensionally .. Keep in mind these are out of 07 and later jeep Jk's , bearing kits could go either way between jeep and Isuzu ... Spicer has all this information about what crosses over between makes and models , they just don't give it out , it's like Area 51 information ..
When all else fails , start over !! Or walk away for the night...
Bradzuzu is offline   Reply With Quote Quick reply to this message
Old 08-31-2015, 04:41 PM   #78 (permalink)
Bradzuzu's Avatar
Member # 250265
I had a little trouble finding the correct pinion seal for the Isuzu Dana 44 as well , finally my parts guy pulled one off the shelf for a standard 44 and it's a perfect match !!
Bearing numbers for the pinion are as follows
Small pinion bearing # timken m88048
Race is part # m88010
Big bearing for pinion part #m802048
Big race part #m802011
The pinion seal part # 9316 also in timken brand ...
Old 10-21-2015, 03:51 PM   #79 (permalink)
Member # 151751
Soooooo, before I bust some cash on a used locker, I wanted to DBL check that a JK non Rubi 44 locker will work in the isuzu axle?
DustinK5 is offline   Reply With Quote Quick reply to this message
Old 05-07-2017, 06:33 PM   #80 (permalink)
Member # 4243
Anyone have a source for the ABS/VSS tone ring for the carrier? Or know the tooth count?
Dodge cobbler... junkyard style (1stgen cummins theme)
u2slow is offline   Reply With Quote Quick reply to this message
