Re: Police AMIGO build - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-18-2009, 11:41 PM   #51 (permalink)
Member # 135862
Originally Posted by johnny010 View Post
finished.
what kind of paint you used? is this rubberized paint used on the underchassis?
what axle did you use?
JJCarEnthusiast is offline   Reply With Quote
Old 05-19-2009, 11:01 AM   #52 (permalink)
Member # 56704
We are using black metal enamel paint. Can be bought at most paint stores. Pretty hard stuff but will still scuff if u hit objects. Thought about a liner product but too much maintenance and eventually sun fade issues
Axles are Toyota 8" out of a 79-85 Toyota Hilux (Tacoma). Shafts are Longfields.
johnny010 is offline   Reply With Quote
Old 05-25-2009, 02:14 PM   #53 (permalink)
Member # 56704
So the axle gusset kit from Marlin came in. I'm going to use it, even though after further review, it looks like the Trail Gear gussets would be better since they use a double gusset up top....
Old 05-26-2009, 11:28 AM   #54 (permalink)
Ford4x4Chik27's Avatar
Member # 23189
Send a message via AIM to Ford4x4Chik27 Send a message via Yahoo to Ford4x4Chik27
Lookin good! I can't wait to see how this project turns out!
'93 Isuzu Amigo, yota axles, 35's, blah blah blah
Ford4x4Chik27 is offline   Reply With Quote
Old 05-27-2009, 05:02 AM   #55 (permalink)
Member # 64281
I'm running the box for rocks from D&D machine. I have the 231/300 set up, and love it. You will only have 3.84:1 with the 203/205. I have 7.12:1 with the 231/300, and several choices of gears. Here's a link to a good deal on a 231 crawl box for sale.http://www.nc4x4.com/forums/showthread.php?t=65386. $500.00 is a good deal.
jlshermanjr is offline   Reply With Quote
Old 05-29-2009, 07:43 AM   #56 (permalink)
Member # 135862
wait wait.. sorry for sounding stupid, but you used your old sidekick chassis under the amigo body? \
and also, did you use 1/4" steel on those bumpers? lookin' good but it's too huge
Old 05-29-2009, 11:56 PM   #57 (permalink)
Member # 56704
no the chassis is from the Amigo....all i reused so to speak from the sidekick were the parts derived from other vehicles. the 4.3L, turbo 350, np205, toyota axles etc....
anyway, let me get this thing on the ground and get some photos.
the gussets were all ground down (marlin brand) and tacked on tonight. a plate had to be cut to fit on the passenger side so the ubolts can fit around the angle created by lack of space to the center chunk.
got the diff back as well, and it is rebuilt with the 5.29 gears and ready to drop in.....making progress....slowly but surely.
Old 05-30-2009, 03:36 PM   #58 (permalink)
Member # 110178
[QUOTE You will only have 3.84:1 with the 203/205. [/QUOTE]
It's actually 3.94:1 with the 203/205 as the 203 has a 2.01:1 low range and the 205 has a 1.96:1 low range. I'm not trying to be a dick either, Just trying to keep as much accurate information available.
Zukiford87 is offline   Reply With Quote
Old 05-30-2009, 11:54 PM   #59 (permalink)
Member # 135862
ok, thanks for clarifying.. hehe
nice amigo! but why did you put on the zuk emblem?
Old 06-02-2009, 07:26 AM   #60 (permalink)
Member # 5716
Very few people know either the Isuzu Emblem or the Suzuki emblem anyway, so putting the suzuki one on there only fawks with about 50 people in the entire world
Jeff M.
Spaceman is offline   Reply With Quote
Old 06-02-2009, 09:52 AM   #61 (permalink)
Member # 56704
for those of you still interested and not turned off by the suzuki emblem...
got the marlin knuckle gussets ground down (lots of work - thanks Scooter) - and tacked them....clearance was good
Old 06-02-2009, 09:56 AM   #62 (permalink)
Member # 56704
here's the part that may make some of you cringe....in order to compensate for the offset of the center chunk, a plate had to be cut and welded to the spring perch to attach the ubolt...no big deal; however, there isn't much room so we welded a nut as a mounting location for one of the bolts. we've beat on it with a hammer and torqued it down -- doesn't seem to be moving at all. we are thinking of taking metal tubing and using that to absorb some of the compression that may be experienced so the bolt won't break off...any one have an opinion (here we go)
Old 06-02-2009, 09:58 AM   #63 (permalink)
Member # 56704
here's work on the other side...had to get a better bracket to mount the hydraulic ram to. prior, the ram was extending and hitting the center chunk....moved it over, and should fix the problems...
Old 06-02-2009, 09:59 AM   #64 (permalink)
Member # 56704
here we are in the paint shop with the front axle
was going to put it together but had to stop and buy a knuckle rebuild kit from inch worm - will be here friday ....great customer service btw...
Old 06-02-2009, 05:11 PM   #65 (permalink)
Member # 56704
Anyone know where I can get stronger steering stops since I'm running hydo steering? The ones in the Marlin kit aren't strong enough.
Old 06-04-2009, 11:06 AM   #66 (permalink)
Heywood's Avatar
Member # 6380
ARe you putting full hydro, or hyrdo asst?
Either way, the ram shoud be set up to stop at the right spots, at the same time as the the steering box/ pitman arm trhow. If your relying on a stop to fight against the ram and steering, you gonna probably gonna stress and break stuff.
The only reason Ive had "steering stops" is for rollovers and situations where the tire gets smacked hard.
Heywood is offline   Reply With Quote
Old 06-04-2009, 10:06 PM   #67 (permalink)
Member # 56704
Full hydro
Will be back at it tomorrow night.
Old 06-13-2009, 07:11 PM   #68 (permalink)
Member # 56704
front suspension pics
almost done with front suspension
set the knuckle shims at 12lbs on both sides. oh, here's a few friends out heading out to a bon-fire....
Old 06-13-2009, 07:15 PM   #69 (permalink)
Member # 56704
took a break...gotta love the houston area...
anyway, back to the build - mounted the tires....I REALLY HOPE THE RANCHO SPRINGS SAG A LOT? I'm going to reinstall the over-load leaves on the Ford springs to level it out a bit....
Old 06-13-2009, 07:17 PM   #70 (permalink)
Member # 56704
dont' have the steering re-attached yet...but the knuckles were rotated properly (thanks Scooter).
Here's a pic of the FRONT drivers side rear hanger with the full weight of the vehicle and no floor jack help...
Old 06-17-2009, 04:27 PM   #71 (permalink)
Member # 137408
So when does the "police" theme come in to play? Lightbar? Intercom?Shotgun mount on passenger side?
Sammi75 is offline   Reply With Quote
Old 06-17-2009, 05:59 PM   #72 (permalink)
Member # 93797
I'm gunna take a stab at it and say he got the amigo at a police auction....
Blue_blooded is offline   Reply With Quote
Old 06-18-2009, 11:49 AM   #73 (permalink)
Member # 56704
no quite OJ - actually, I have lights that mount on a dodge ram diesel that I disassembeled, and wired in red/white/blue led lights. The body will be painted black and white like a State Trooper car (one's here in Texas). Probably put a decal on the side that says 'Recovery' or something along those lines.
It's hard getting enough time to work on it consistently, but it's coming along.
Old 06-18-2009, 02:54 PM   #74 (permalink)
Member # 93797
ah, going for the DPS look.....
Old 06-18-2009, 05:32 PM   #75 (permalink)
ridenby's Avatar
Member # 136902
Buddy,that is pretty cool build,like the ingenuity.
ridenby is offline   Reply With Quote
