Simple question I dont have the answer to. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-25-2010, 06:40 PM   #1 (permalink)
StinkyFab Racing
StinkBug's Avatar
Member # 4946
How much oil does an isuzu 12 bolt rear axle normally hold. I know, fill to the bottom of the fill hole, but I moved my fill hole to the top of the housing, so that would be WAY too much oil now. Anyone know an actual capacity in quarts?
Dallas Ashley
StinkyFab Racing (SFR) - Custom Fabrication
Your Source for: CNC Cutting & Engraving, Cages, Custom Suspension, Complete Vehicle Builds, and more!
Overall Winner, 2012 KOH EMC. Gettin it done in a stocker!
Co-Dog #4432-KOH 2011 #88-KOH 2010, Crew Chief - KOH 2009, 2008
StinkBug is offline   Reply With Quote
Old 06-25-2010, 08:48 PM   #2 (permalink)
Member # 84584
I want to say it was 2 quarts... you know, and I just did it too. But seriously though, I believe it is 2 quarts.
JAKE88FREESTYLE is offline   Reply With Quote
Old 06-26-2010, 02:09 AM   #3 (permalink)
StinkyFab Racing
StinkBug's Avatar
Member # 4946
That just doesn't seem like enough. My front D44 took 2, and it has seals on either side of the diff so you dont have to fill the tubes. All the Spider 9's take around 4. I've got about 3 in my 12bolt right now and it's nowhere close to my new higher fill hole.
Dallas Ashley
Old 06-26-2010, 07:39 AM   #4 (permalink)
Member # 84584
Huh, I don't know what to say... I run the syncro 75-90w bottles GM sells (cause that is where I use to work and it was cheaper for me), and I only had 4-5 left and it looks like I only used 2 - 2 1/2? Like I said though, I refilled the diff a month ago when I put the Aussie in, and just can't be 100% sure.
Old 06-26-2010, 02:25 PM   #5 (permalink)
Triathlete's Avatar
Member # 27094
The VX 12 bolt rear calls for 3.2 Qts. in the manual.
B.Oliver
'99 Zu Vehicross
3"lift 31"MTR's Skids OBA...
Triathlete is offline   Reply With Quote
Old 06-26-2010, 05:22 PM   #6 (permalink)
Member # 20612
I just filled mine this morning and it took a little over 1/2 gallon. Don
88 trooper dana 44 sas 35 in tires 4.56 gears 4.3 chevy th350
dvtrooper is online now   Reply With Quote
Old 06-27-2010, 01:03 AM   #7 (permalink)
StinkyFab Racing
StinkBug's Avatar
Member # 4946
Hmm, seems most are voting around 2 quarts, with the VX book saying 3.2. I guess the 3 that I poured in are probably enough then. Just seems like so little when you're used to a 9" rear that'll suck up 6 or more for a rear axle with seals out at the ends.
Dallas Ashley
Old 06-27-2010, 10:21 AM   #8 (permalink)
* The Printer *
lttlbddy's Avatar
Member # 6532
Send a message via AIM to lttlbddy Send a message via Yahoo to lttlbddy
My manual says: 1.8 liters.
(It's the official 2" thick service manual)
lttlbddy is online now   Reply With Quote
Old 06-27-2010, 03:21 PM   #9 (permalink)
Member # 20752
Checked my 94 Trooper service manual, says 1.9 quarts.
Steve Carlson
95 Trooper LS - 35s, ARBs & 5.38s
BigSwede is offline   Reply With Quote
Old 06-28-2010, 11:42 PM   #10 (permalink)
oma
oma's Avatar
Member # 163196
Correct.
oma is offline   Reply With Quote
Old 06-29-2010, 12:32 AM   #11 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
fuckit, synthe is $15-22 dollars a bottle, filler up.
Old 06-29-2010, 11:50 PM   #12 (permalink)
* The Printer *
lttlbddy's Avatar
Member # 6532
Originally Posted by oma View Post
Correct.
I'm so glad you agree with the service manual.
Old 06-30-2010, 07:14 AM   #13 (permalink)
Member # 25557
A.K.A. Turtle Mechanic
ECORS #12 Pink Demon
Bansil is offline   Reply With Quote
