I need help for 2.8 disel - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-10-2010, 12:55 PM   #1 (permalink)
Member # 170850
hello guess ...my name is Pedja and I am from Serbia ,so I have an isuzu trooper 2.8 td and I have idea to put front differential from nisan patrol 2.8td or 3.3 td ...now I have problem because I don't know ratio of bevel ring gear and bevel pinion in my isuzu..do you know number of cog in my diferential ...thanks I sow hire more of ideas..
predragkostic is offline   Reply With Quote
Old 10-10-2010, 01:55 PM   #2 (permalink)
Member # 170898
is the diff still in the truck, the only way i would know would be to count teeth on gears, i assume a diesel would have a bit higher ratio than a gasoline engine. Perhaps look at the option plate on the fire wall/ bulkhead, the option codes may list gear ratios.
texastrooper84 is offline   Reply With Quote
Old 10-10-2010, 09:50 PM   #3 (permalink)
Member # 170850
its the same ratio like in 2.6 mpi ,I think ...
Old 10-11-2010, 02:53 PM   #4 (permalink)
Member # 170987
You should check this out. I think he will clarify a lot of stuff for you
http://forum.planetisuzoo.com/viewto...=210542#210542
Good luck!
theblob is offline   Reply With Quote
Old 10-13-2010, 09:52 PM   #5 (permalink)
Member # 170850
thanks guess I find donor for my isuzu ....how to upload some of pisc hire..
