Isuzu 3.1 D (4JG2) wiring diagram - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-21-2011, 04:24 PM   #1 (permalink)
Member # 186418
Hello.
I recently purchase an Isuzu 3.1 TD (4JG2) who sat in an Opel Campo 95th I plan to use the engine in another car but can not find a wiring diagram ....
Does anyone have or know where I can find on it?
Is it an ECU on them engines?
Thanks
Terho (Sweden)
Terho is offline   Reply With Quote Quick reply to this message
Old 03-22-2011, 02:02 AM   #2 (permalink)
Rural53's Avatar
Member # 106474
4JG2 came in two versions, earlier ones with a mechanical injector pump, the later ones with an electronic controlled injector pump and has an ecu. If the throttle cable goes to the injector pump then it is an older mechanical one. If the throttle cable goes to the top of the engine and has a throttle position sensor it is a later electronic one. The one I used to own was electronic.
Post up some picture of the Opal and which engine. Is it a manual or auto? PM me an email address and I'll send you the correct wiring diagrams.
Rural53 is offline   Reply With Quote Quick reply to this message
Old 03-22-2011, 06:00 AM   #3 (permalink)
Member # 186418
Then it is the older I have It is a manual.
Are there any other transmissions that fit the rules engines? Read the Opel Omega and BMW use the same automatic transmission. But bolt circle might not be correct?
Here are some pictures of it.
Sending my email at once!
Thanks!
Old 04-29-2011, 04:21 AM   #4 (permalink)
Member # 186418
I would like to have hold of an automatic transmission for my 3.1 TD and if I got this right, they are equal transmission of the Opel Omega. Would it be able to fit directly on or are there any other Alternative?
/Terho
Old 09-16-2011, 05:20 PM   #5 (permalink)
Member # 198957
4JG2 3.1TDI ECU wiring diagram
Hi, I have Isuzu bighorn 3.1TDI auto, engine 4JG2. ECU -Zexel P/N 407913-1102. looking for electrical diagram. my email: batorshih.ch@gmail.com. thanks
orshih is offline   Reply With Quote Quick reply to this message
Old 04-29-2015, 09:17 AM   #6 (permalink)
Member # 574866
Hi, i am looking for a wiring diagram pinouts for a 4JG2 and 4JX1 engines, here's my email g_inductivo@yahoo.com.. thank you
gingtrantan is offline   Reply With Quote Quick reply to this message
