#26 (permalink) |
Member # 107575
those are 39 1/2's
![]() and when you are that far can you get a bunch of pics of your front axle and brackets....gonna be doing a chevy front 60 build soon and rounding up ideas... |
#27 (permalink) | |
Member # 170389
1995 XJ 60s 3 link and 36s 1997 F-250 Powerstroke Tow Rig |
#28 (permalink) | |
Member # 142189
Yeah Yeah
![]() Quote:
I already bent and straightened the factory tie rod a couple times when it was under the other jeep.
[SIZE="3"][URL="http://www.pirate4x4.com/forum/showthread.php?t=1008667"]XJ on Chevy 1 tons and 40s[/URL] LJ on 35s[/SIZE] |
#29 (permalink) |
Member # 142189
Trans/transfercase adapter showed up today. Looks like I'll be busy tomorrow!
#30 (permalink) |
Member # 142189
Got some work done today, but not as much as I wanted too. Woke up this morning to a backed up septic system and had to deal with that
![]() The adapter ring didn't quite fit right, but after sone grinding and enlarging the holes a hair it finally bolted up. Hopefully I'll get it mounted to the tran later this week. ![]() And the big hole I cut for clearance. Found some rust in that side of the floor pan so I just hacked at it since I'm going to have to replace it.
#31 (permalink) |
Member # 142189
Got the transfercase installed today. The only issue is now it wont start with the key (started when I jumped the starter). I have not checked the nuetral safety switch yet, but is there anything this swap could have done to cause this?
[SIZE="3"][URL="http://www.pirate4x4.com/forum/showthread.php?t=1008667"]XJ on Chevy 1 tons and 40s[/URL] LJ on 35s[/SIZE] Last edited by jkl; 10-07-2011 at 12:40 PM. |
#32 (permalink) |
Member # 134546
could be your solenoid on your starter went bad........this happened to my trail beater and i just wired in a push button switch to jump the solenoid instead of replacing it.....it cost me like $6 but is redneck as hell
'91 XJ Laredo (Trail Beater) '91 XJ Briarwood (Chop-Top Project) '79 J10 (Truggy Project) |
#33 (permalink) |
Member # 106782
Yes it could be the nss, i believe it is a normally closed switch (failsafe), so if its gone it aint gonna work, connect the wires and you should be a go.
"moderately hellacious" Keep Tons Under Tow Rigs 2006 ccsb lbz Chevrolet 4wd 1981 foretravel 35' pusher 3208 cat/Allison 2000 xj 4.0/aw4/231/300 404's 43"s f/r full hydro, caged, stretched, cut, plated. Build thread [url]http://www.pirate4x4.com/forum/jeep-cherokee/991739-project-bolt-bruiser.html[/url] |
#34 (permalink) |
Member # 142189
Got the frame stiffeners cut and fitted today. Now the fun part of preping the frame and drilling all the rosette holes begins.
#35 (permalink) |
Member # 142189
Messed with the suspension brackets a little today. Cut and trimmed a piece of 2" x 1/4" angle
![]() Then I'll tie it into some 1/4" plate that will sit on top of the ballistic brackets. I'll then weld the round coil base to that. ![]() On the drivers side basically going to build a third leg and then tie them all together with plate like the other side ![]() Also used a spot weld cutter and seperated the rear fenders. Hopefully I'll get them cut out tomorrow. ![]() A friend is moving out of his storage shed and needed a place to keep his welder so I quickly volunteered my house!
#38 (permalink) | |
Member # 142189
#40 (permalink) | |
Member # 142189
#44 (permalink) |
Member # 142189
Yep, otherwise you have to cut the shaft or modify the bearing retainer or somethin, I can't remember
#45 (permalink) |
Member # 142189
Thanks. Hopefully this afternoon I'll get the front axlxe pulled so I can start welding up all the suspension brackets.
#46 (permalink) |
Member # 142189
Got the front axle pulled and fired up the welder today. Only got the driver side finished. At the FD tomorrow, so hopefully I will get done mowing early Thurs. and can finish the pass side. Looked at the leaking freeze plugs and they are worse than I thought. Since the axle it out I'm going to go ahead and replace them all. Have a deal pending on my SBC and TH350. Suppose to be picked up on Sunday and should give me enough cash to get this rolling under its own power again.
![]() Made a third "leg" so I can offset the coil seats. Traced the ballistic bracket onto a 4" x 1/4" piece os steel and then cut it out. ![]() ![]() And then went to town... ![]() ![]() ![]() ![]() ![]()
#47 (permalink) |
Stump Humper
Member # 137046
Do you have some plan for the coil capture plate? Usually a .5" bolt should go through a plate that should come with your ballistic bracket and that hole in the center of the spring perch. The bottom of your coil would be captured between these to plates like this, there is a .5" nut welded under the spring perch.
#50 (permalink) |
Member # 142189
Just slides over it. The plan is to make a retainer clip like on the factory axle.
