Chevy 1 tons, 40s, blah blah blah - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-27-2011, 02:28 PM   #51 (permalink)
Stump Humper
Chaps's Avatar
Member # 137046
Originally Posted by jkl View Post
Just slides over it. The plan is to make a retainer clip like on the factory axle.
I got ya , that makes sence.
Another POS unibody
Chaps XJ build
Check out my You Tube
Chaps is online now   Reply With Quote
Old 10-28-2011, 08:41 AM   #52 (permalink)
jkl
Member # 142189
Pass side
[SIZE="3"][URL="http://www.pirate4x4.com/forum/showthread.php?t=1008667"]XJ on Chevy 1 tons and 40s[/URL]
LJ on 35s[/SIZE]
jkl is offline   Reply With Quote
Old 10-28-2011, 03:47 PM   #53 (permalink)
jkl
Member # 142189
Started cleaning up the frame to plate it and making a duct tape template
LJ on 35s[/SIZE]
Old 10-30-2011, 12:08 PM   #54 (permalink)
jkl
Member # 142189
Laid the front frame plate template out on some 1/8" steel
Still need to trim them up a bit to fit better and drill rosette holes.
LJ on 35s[/SIZE]
Old 11-20-2011, 05:41 PM   #55 (permalink)
jkl
Member # 142189
Just got done placing these orders:
Barnes 4WD - 2 DOM sleeves w/bushings, adj. upper link mount, axle link tower and frame link mounts
Liquid Iron Ind. - 2 Johnny Joints and DIY front bumper brackets
Clayton Offroad - 4 square tube inserts, 4 jam nuts and 6 bolts, washers, nuts
Also got the front axle back under the Jeep today. Shooting for front axle placement somewhere around here.
LJ on 35s[/SIZE]
Old 11-21-2011, 05:37 AM   #56 (permalink)
Member # 176679
Pass side
Just wondering what your plan was for a axle end trac bar bracket. I'm in the same boat as you are on this one, and was looking at the possibility of using a stand off bracket on the section of axle tube and have it come up and angle out. It looks as though it could be done without interference from the tie rod and drag link, but of course I don't have it right in front of me either.
99 TJ 6.0/4L80E/205/Chevy60/14/40's
XJsavage is offline   Reply With Quote
Old 11-21-2011, 07:25 AM   #57 (permalink)
Member # 189683
Never seen the duct tape template. How do you get it off the frame?
Byron XSPower Batteries
4xspower.com 888.497.7693 Ext. 1213
Byron@XSPower is offline   Reply With Quote
Old 11-21-2011, 08:35 AM   #58 (permalink)
Member # 146965
Why are you using 1/8" up front instead 3/16" to plate the uni ?? Is it because of the light wheeling you do, or are you trying to save weight? I see alot of rigs with the 1/8" on the back uni, But also alot are using 3/16" up front. Now I'm sure either will do a great job making the unibody stronger. Btw, it's looking good man!
mcg311TJ is offline   Reply With Quote
Old 11-21-2011, 01:50 PM   #59 (permalink)
jkl
Member # 142189
Going to try and mount it next to the coil spring first, second option is to use a angle mount like from Ruff Stuff in front of the coil mount and third option would be mount it on the diff cover like Timmay did. Once I get the axle its location I'll see what works the best.
LJ on 35s[/SIZE]
Old 11-21-2011, 01:52 PM   #60 (permalink)
jkl
Member # 142189
Basically just laid 2 layers of duct tape to the frame, trimmed it and then started at one corner and pulled it off.
LJ on 35s[/SIZE]
Old 11-21-2011, 01:58 PM   #61 (permalink)
jkl
Member # 142189
Because I already had enough 1/8" plate to make them and not enough 3/16"
My light wheeling is more hardcore than your web wheeling
Yes
I've quite a few guys use 1/8" on the front also and they don't seem to have any issues
Thanks Biotch, I'll let you ride in the back when its done
LJ on 35s[/SIZE]
Old 11-21-2011, 02:14 PM   #62 (permalink)
Member # 176679
Gotcha. On my 44 front I ended up doing the option "1", built on top of a truss. In heinsight I wish I had gone with the option "2" simply for reasons of clearance between the frame and trackbar at full bump. At full bump it get pretty damn close to the oil pan also. Option "2" would have required me to trim off the front of the coil bucket and use a stand off bracket like offered by Barnes4WD. Mine is around 4" of stretch and 4" lift with the 44 and option "2" would work fine, and I could see it being close to the same with a 60 front.
Good luck with it, I'll be looking forward to seeing what you come up with.
Old 11-21-2011, 04:33 PM   #63 (permalink)
Member # 146965
Backseat is the best
Old 11-29-2011, 04:49 PM   #64 (permalink)
jkl
Member # 142189
More parts arrived yesterday! Just waiting on the 2 Johnny Joints being drop shipped from Currie. Started welding on the driver side frame stiffener tonight, no pics though.
LJ on 35s[/SIZE]
Old 11-30-2011, 09:23 AM   #65 (permalink)
Member # 188425
That duct tape template thing was pretty cool.
Carry on.
EmptyPockets07 is offline   Reply With Quote
Old 11-30-2011, 06:43 PM   #66 (permalink)
Member # 182406
What are you using to cut that 1/8 plate?
Also for your frame stiffeners is that 3x3?
Lookin gooooooood
2doorxj is offline   Reply With Quote
Old 12-01-2011, 02:32 PM   #67 (permalink)
jkl
Member # 142189
Originally Posted by 2doorxj View Post
What are you using to cut that 1/8 plate? Circular saw and a angle grinder with a cut off wheel
Also for your frame stiffeners is that 3x3? Yes 3/16" thick
Lookin gooooooood Thanks!
LJ on 35s[/SIZE]
Old 12-01-2011, 10:00 PM   #68 (permalink)
Member # 184322
Nice work! Keep the updates coming!
tactical40cal is offline   Reply With Quote
Old 12-03-2011, 01:51 PM   #69 (permalink)
jkl
Member # 142189
My other 2 JJs arrived on Thurs! Today I finished welding up the drivers side frame stiffener. Heres a crappy cell pic.
LJ on 35s[/SIZE]
Old 12-04-2011, 07:21 AM   #70 (permalink)
bbrancheau's Avatar
Member # 175896
very nice..
i have same set up just used Dodge 60 and AX15.. keep up good work.
My build
http://www.greatlakes4x4.com/showthread.php?t=165256
bbrancheau is offline   Reply With Quote
Old 12-07-2011, 04:56 PM   #71 (permalink)
jkl
Member # 142189
Originally Posted by bbrancheau View Post
very nice..
My build
Thanks! Took a peek at yours, looks good.
LJ on 35s[/SIZE]
Old 12-09-2011, 12:34 PM   #72 (permalink)
jkl
Member # 142189
Over the last few days I've got to work on it here and there. Plated part of the inner frame with 1/8" plate the used a piece of 3 x 3/16" angle over that and butted it up to the frame stiffener. Plated a small section of the floor with 1/8" to tie the mount into the floor. Had to modify the Barnes upper link mount a bit cause it was a little to big. Just a little cut and bend and it fit better. Have about 4 1/2" vertical seperation on the frame end and about 8" on the axle end. Lower link is going to be roughly 36.5" long and upper about 36".
LJ on 35s[/SIZE]
Old 12-10-2011, 10:36 AM   #73 (permalink)
jkl
Member # 142189
Placed an order with Ruff Stuff last night for their track bar kit. Hopefully I can pick up a stick of 2x1/4" tubing soon and get this thing back together soon. After that it should be just driveshafts and tie up a few loose ends to take it for a test drive.
LJ on 35s[/SIZE]
Old 12-10-2011, 01:56 PM   #74 (permalink)
bbrancheau's Avatar
Member # 175896
" Lower link is going to be roughly 36.5" long and upper about 36"."
Is this eye to eye? or just link length? I just mesured mine to make them and link length was 36" and with the joint on each end its 38" over all.
my build
Old 12-10-2011, 02:08 PM   #75 (permalink)
jkl
Member # 142189
That's eye to eye. Too short?
LJ on 35s[/SIZE]
