Chevy 1 tons, 40s, blah blah blah - Page 4 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-10-2011, 04:22 PM   #76 (permalink)
bbrancheau's Avatar
Member # 175896
Originally Posted by jkl View Post
That's eye to eye. Too short?
no i dont think so.. Did you strech the front at all? i didnt read back to see. also depends where you placed your link mounts. mine are on the crossmember you look like it is just ahead of member. i think you would be just fine.. Any one else thoughts?
my build
http://www.greatlakes4x4.com/showthread.php?t=165256
bbrancheau is offline   Reply With Quote
Old 12-10-2011, 04:41 PM   #77 (permalink)
jkl
Member # 142189
Yea, front will be stretched a few and inches and the mounts sit right in front of the crossmember.
[SIZE="3"][URL="http://www.pirate4x4.com/forum/showthread.php?t=1008667"]XJ on Chevy 1 tons and 40s[/URL]
LJ on 35s[/SIZE]
jkl is offline   Reply With Quote
Old 12-10-2011, 04:44 PM   #78 (permalink)
bbrancheau's Avatar
Member # 175896
Yeah see that should make it the same as mine. Hope it works lol. Should have my links back by Monday.
Old 12-10-2011, 09:35 PM   #79 (permalink)
Member # 122916
I hope not, because my upper CA is only 32" and 30" lowers, eye to eye.
xj9140 is offline   Reply With Quote
Old 12-11-2011, 04:55 AM   #80 (permalink)
Member # 103442
Send a message via AIM to GreatWhiteXJ
Have you checked tire clearance at full lock? Looks to me like yout tires will rub your lower links prolly 3/4 of the way threw your steering cycle.
And your link length is fine.
XJ on 42's
GreatWhiteXJ is offline   Reply With Quote
Old 12-11-2011, 07:41 AM   #81 (permalink)
jkl
Member # 142189
Originally Posted by GreatWhiteXJ View Post
Have you checked tire clearance at full lock? Looks to me like yout tires will rub your lower links prolly 3/4 of the way threw your steering cylce.
Here is a pic. It's just shy of the steering stops touching. Running a waggy pitman arm but would like to gain that extra bit.
LJ on 35s[/SIZE]
Old 12-12-2011, 02:22 PM   #82 (permalink)
jkl
Member # 142189
Got the pass side frame stiffener and link mount on today. Plan on picking up 2" tubing on Wednesday to make the control arms.
LJ on 35s[/SIZE]
Old 12-18-2011, 06:21 PM   #83 (permalink)
jkl
Member # 142189
Got the lower links together today. Decided to use Johnny Joints on both ends so I also placed an order for 2 more joints, nuts and tube inserts for the upper link. Lowers ended up at 36.75" and the wheelbase is at 106.5"
LJ on 35s[/SIZE]
Old 12-31-2011, 07:43 AM   #84 (permalink)
jkl
Member # 142189
More progress.....
LJ on 35s[/SIZE]
Old 12-31-2011, 08:49 AM   #85 (permalink)
Member # 191251
Looking good, keep it up
RCP Fab is offline   Reply With Quote
Old 01-04-2012, 04:32 AM   #86 (permalink)
token Canadian
andrewmacc's Avatar
Member # 160053
Are you still intending to use the Ruff Stuff panhard bracket, as pictured:
I have the same kit, but ditched both brackets it came with.. The axleside was too short to work with my high steer, and the frameside, well, as you may have noticed there's not a lot of material to weld on because of the contour of the frame.
'98 Cherokee, 2-dr, HP60/14B 5.13:1, 37"s, Dana 300 4:1, 14" FOA coilovers, 5.9L V8 on its way in.. oink oink.
andrewmacc is offline   Reply With Quote
Old 01-04-2012, 05:28 AM   #87 (permalink)
moparmaniaccuda's Avatar
Member # 121563
Any reason you can't push the axleside trackbar mount out in front of the coil? Or at least further over?
Can't tell from the pics.
moparmaniaccuda is offline   Reply With Quote
Old 01-04-2012, 04:48 PM   #88 (permalink)
jkl
Member # 142189
Thanks
LJ on 35s[/SIZE]
Old 01-04-2012, 04:52 PM   #89 (permalink)
jkl
Member # 142189
Originally Posted by andrewmacc View Post
Are you still intending to use the Ruff Stuff panhard bracket...... and the frameside, well, as you may have noticed there's not a lot of material to weld on because of the contour of the frame.
Yes, going to use that bracket. The plan is to make some gussets to extend the lower part of the bracket. Since it came with the kit I figured it would be easier to modify it than make a whole new one.
LJ on 35s[/SIZE]
Old 01-04-2012, 04:54 PM   #90 (permalink)
jkl
Member # 142189
I could have put the mount in front of the coil but I would not be able to use my high steer with it there.
LJ on 35s[/SIZE]
Old 01-11-2012, 03:20 PM   #91 (permalink)
jkl
Member # 142189
Picked up 2 XJ front driveshafts and a new yoke today. Hopefully I won't destroy the 1310 joints.
Made a list of what needs to be done to get a test drive in:
Finish trans crossmember
Flex suspension one more time to make sure everything clears
Weld up all the suspension components
Weld rear spring perches
Weld front frame stiffeners
Bleed brake lines
Replace freeze plugs
Modify driveshafts
Plus all the little things pop up
What needs to be done to wheel it:
Shocks
Bump stops
Axle vent hoses
Exhaust
Transfer case shifters
Front bumper or at least make some recovery points for the front
CB
Finish cutting down the runflats for beadlock wheels
Plus whatever little things pop up
And future projects:
Rebuild rear fenders and front floor pan
Durango gear box w/ hydro assist
Front and rear bumpers
Traction bar
Roll cage
Boatsides
Winch
Raise gas tank
New drag link and tie rod
Some members from my club are planning a trip to Gray Rock, Choccolocco Mountain, or Coal Creek this June so hopefully I'll make it pretty far down the lists.
LJ on 35s[/SIZE]
Old 01-11-2012, 03:43 PM   #92 (permalink)
littledeviltj's Avatar
Member # 134898
is that 3x3 angle you used to plate the frame? did you plate the inner part of the frame? if so do you have pics?
littledeviltj is offline   Reply With Quote
Old 01-12-2012, 07:40 AM   #93 (permalink)
jkl
Member # 142189
3x3x3/16 angle. The only inner frame I plated is where the upper 3 link bracket is.
LJ on 35s[/SIZE]
Old 01-12-2012, 09:59 AM   #94 (permalink)
Member # 180792
Hey buddy i've been watchn your build on here and jeepforum, let me know if you need any help im over in n lakeland by lake gibson. Im building a 91 xj, its sittin on 4.5 and 33s right now.
weeder1 is offline   Reply With Quote
Old 01-12-2012, 10:16 AM   #95 (permalink)
ONEtonXJ's Avatar
Member # 145633
this looks familiar..
Here's what I did...
"Tater2" - '91 2 door XJ. 4.0, AW4, 231/300 doubler, GM 60/70HD, 6.17s, ARB's & 4Ds
ONEtonXJ is offline   Reply With Quote
Old 01-13-2012, 06:12 AM   #96 (permalink)
jkl
Member # 142189
Will do, and if you need any help with yours let me know.
Your Jeep is one of the ones I looked at when I was doing the brackets
LJ on 35s[/SIZE]
Old 01-13-2012, 07:15 PM   #97 (permalink)
Member # 180792
Sounds good buddy!
Old 01-23-2012, 09:58 AM   #98 (permalink)
jkl
Member # 142189
Pulled the front end this morning and working on getting everything welded up.
LJ on 35s[/SIZE]
Old 01-24-2012, 05:04 PM   #99 (permalink)
Member # 27040
Send a message via AIM to HickTrucksRus Send a message via MSN to HickTrucksRus
jkl, I love this build I plan on stealing more than one idea from you I have two questions, Why the DRW front end, just because you had it in the CJ8? Also are those stock height 52" springs? thanks alot
Again build is
lame 88 2door xj.
HickTrucksRus is offline   Reply With Quote
Old 01-25-2012, 10:47 AM   #100 (permalink)
jkl
Member # 142189
Yes, but orginally bought the axle cause it was cheaper than a SRW version and allowed me to run the H1 wheels w/o a lot of clearance issues.
They are suppose to be, bought them used so can't be 100% sure
Again build is
Thanks
LJ on 35s[/SIZE]
