Chevy 1 tons, 40s, blah blah blah - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-20-2011, 02:50 PM   #1 (permalink)
jkl
Member # 142189
Got a build thread going on another forum but figured I'd post it up here for more opinions. Got some copy and pasting to do to get it up to date.
The plan:
The motor runs good and tranny shifts good so I think I'll leave em
Dana 300 (231/300 doubler later down the road)
Front Chevy Dana 60 with 5.13s (from the scrambler)
Rear 14 bolt with 5.13s and a Detroit Locker (from the scrambler)
40" Iroks and H1 wheels (from the scrambler)
3 Link the front, maybe airshocks
Think I'll keep the leaves in the rear for now and 4 link it later
Cut the fenders to keep it low
Maybe a slight front and rear stretch
Frame Stiffeners
Bedline the interior
Cage of some sort
Body Armor
Build Bumpers
[SIZE="3"][URL="http://www.pirate4x4.com/forum/showthread.php?t=1008667"]XJ on Chevy 1 tons and 40s[/URL]
LJ on 35s[/SIZE]
jkl is offline   Reply With Quote
Old 09-20-2011, 02:53 PM   #2 (permalink)
jkl
Member # 142189
I picked up this XJ to replace my current project scrambler. Thanks to my dad, my son has been wanting to go muddin after watching videos on youtube with him. I know, I know..mud sucks...but what makes my wheelin partner happy makes me happy, so I'm going to build a new crawler that will be able to get dirty. Originally I was going to just buy a full top and keep the scrambler, but a new top for it was a little over a grand. Started looking on craigslist and found this Cherokee that runs, drives and even the A/C works and picked it up for $675.
Specs:
1993 4 door Cherokee Country, 4.0L , AW4 auto tranny, 309,790 miles.
The inside is dirty and stained, smells like a cigarette, headliner missing and a dent in the driver door, but it has speakers everywhere! :laugh:
They lost the key, so they pulled the lock cylinder and now uses a "master key" aka needle nose pliers.
LJ on 35s[/SIZE]
Old 09-20-2011, 02:55 PM   #3 (permalink)
jkl
Member # 142189
First mods were taking off the ugly honeycomb style wheels and putting on the factory tire/wheels from my LJ. Definately improved the looks. Then washed it, cleaned it out and a buddy who works for Stanley Steamer deodorized it for me. Drove it around like this for a while till the tear down began.
LJ on 35s[/SIZE]
Old 09-20-2011, 02:57 PM   #4 (permalink)
jkl
Member # 142189
Here's a recap on the axles:
Picked up a 14 bolt with 5.13s and a detroit in it for $300
And then swapped to disc brakes
LJ on 35s[/SIZE]
Old 09-20-2011, 02:59 PM   #5 (permalink)
jkl
Member # 142189
Then gave it a trim, I forget the exact measurement of have much I cut off.
LJ on 35s[/SIZE]
Old 09-20-2011, 03:02 PM   #6 (permalink)
jkl
Member # 142189
Then picked up a DRW front Dana 60
Went through it, replaced some parts, added high steer arms and regeared it to 5.13
LJ on 35s[/SIZE]
Old 09-20-2011, 03:05 PM   #7 (permalink)
jkl
Member # 142189
And the 39.5" Iroks on H1 wheels
Replacing this scrambler with the XJ.
LJ on 35s[/SIZE]
Old 09-20-2011, 03:08 PM   #8 (permalink)
jkl
Member # 142189
Pulled the rest of the headliner out.
Got the axles pulled from my scrambler saturday, now the fun can begin!
Just for schitzandgiggles
LJ on 35s[/SIZE]
Old 09-20-2011, 03:12 PM   #9 (permalink)
jkl
Member # 142189
Trimmed the front fenders, when its all said and done going to cover the edge with door trim.
Ruff Stuff pearches
Got an email from Ballistic Fab today saying my brackets were backordered (imagine that ) Called them up, talked to 2 different people and changed brackets so hopefully I'll see those soon. Changed from the 3" diameter to 3.25" The Dana 60 housing is like 3 1/8" so I don't think it should be a big deal
LJ on 35s[/SIZE]
Old 09-20-2011, 03:13 PM   #10 (permalink)
jkl
Member # 142189
Out with the old
In with the new!
33's and no lift, better not hit any bumps
Just put a tack weld on the perches to keep them from moving until I figure out the exact pinion angle.
LJ on 35s[/SIZE]
Old 09-20-2011, 03:18 PM   #11 (permalink)
jkl
Member # 142189
The Ballistic Fab coil/lca brackets
I had to change my orignal plan of attack as some of my orginal measurements were off. After some remeasuring I got it figured out, I think lol. I'll get some better pics and show what I'm going to do later.
Orignal Chevy brackets cut off
No more Dana Turdy
Ballistic brackets tacked on
Sittin on factory springs and 33s all the way around. And yes I know that the driver side is sticking waaay out. It was hot, I was tired and after all my hard work of centering the axle I set it down on it's on weight, forgot I had no trac bar and the body shifted to the pass side
LJ on 35s[/SIZE]
Old 09-20-2011, 03:19 PM   #12 (permalink)
jkl
Member # 142189
Picked up some front springs and shackles today. The coils were suppose to be Rusty's 4.5" but they ended up being 3" HDs. My fault for not checking them when I bought them, but in the end I think the stance is just about right. Might end up adding a .75" spacer once it gets a winch and bumpers.
And the rear jacked up to approximate ride height. I'm guessing the front is about 5.5-6" lift. It doesn't sit as tall as I thought it would, 71" to the drip rail, 29" bottom of the door and 23" to the bottom of the frame at the tranny crossmember.
LJ on 35s[/SIZE]
Old 09-20-2011, 03:20 PM   #13 (permalink)
jkl
Member # 142189
Today I trimmed some more on the front fenders and pulled most of the dent from the drivers door. Just a small area left at the lock that i'll have to work from inside the door panel.
The other day I got the drag link on. It's pretty close to the oil pan so it looks like it needs more lift, replace the waggy pitman arm with one with more drop or maybe both.
LJ on 35s[/SIZE]
Old 09-20-2011, 03:22 PM   #14 (permalink)
jkl
Member # 142189
Ripped out the rear carpet and pulled the rear bumper
Approximate rear axle location, more fender hacking Yeah!
Might build the inner fenders and raise the tank like this
Think I might be able to use the corner gaurds from the scrambler and modify them to fit on the cherokee. More to come on that later......
LJ on 35s[/SIZE]
Old 09-20-2011, 04:24 PM   #15 (permalink)
jkl
Member # 142189
Picked up the 52" Chevy springs this morning, so out with the old
And in with the new to me, going to remove the overload spring later
The exhaust tailpipe was interfering with the pass side shackle so off it came
I'll address the shackle angle later
Swaping out the 33's
A little cut and fold for just enough clearance
4Ds on all four corners
LJ on 35s[/SIZE]
Old 09-20-2011, 04:25 PM   #16 (permalink)
jkl
Member # 142189
Today's progress.....folded the rear lower quarter panel.
LJ on 35s[/SIZE]
Old 09-20-2011, 04:26 PM   #17 (permalink)
jkl
Member # 142189
Had a busy day today, this morning I picked up a bunch of free cabinets and workbench for my garage :thumbsup:
And then made the drive to pick up the Dana 300
LJ on 35s[/SIZE]
Old 09-20-2011, 04:28 PM   #18 (permalink)
jkl
Member # 142189
Pushed it outside so I can start cleaning up the garage. Also fired it up for the first time in a while and let in run a bit. Now were up to date.
LJ on 35s[/SIZE]
Old 09-20-2011, 06:50 PM   #19 (permalink)
Twisty's Avatar
Member # 97798
Cool build!
Just wondering, whats the clearance like between the driveshaft and the starter? My friend put a Chevy 60 in a TJ with a 4 cyl, and his shaft hits the starter (at close to full bump). Wondering it it's the same way with an XJ.
88 MJ buggy - D60/14b, 3&4 link, air shocks, 203/205, 5.38s, full hydro
newenglandjeepz.org
Twisty is offline   Reply With Quote
Old 09-20-2011, 07:35 PM   #20 (permalink)
token Canadian
andrewmacc's Avatar
Member # 160053
Been following this on jeepforum. Good to see it posted here.
I was going to ask the same question as Twisty - I forgot you were using Chevy axles and keeping the D300 unflipped.
'98 Cherokee, 2-dr, HP60/14B 5.13:1, 37"s, Dana 300 4:1, 14" FOA coilovers, 5.9L V8 on its way in.. oink oink.
andrewmacc is offline   Reply With Quote
Old 09-20-2011, 10:25 PM   #21 (permalink)
Member # 194899
hey man love the xj, sucks about the scrambler though...still lovin it though
86cherokeek20 is offline   Reply With Quote
Old 09-21-2011, 07:14 AM   #22 (permalink)
Moderator
ashmanjeepXJ's Avatar
Member # 10249
How wide is your front with the drw d60 and H1s? looks like 86in?
ashmanjeepXJ is offline   Reply With Quote
Old 09-21-2011, 08:25 AM   #23 (permalink)
WAD357's Avatar
Member # 170389
This things sweet but why not do away with the Hi steer arm so you can keep it a little lower?...
Im Right about 4" of lift 2" coil and the axle has to add about 2" over stock and Had no issues with the oil pan untill I lost a bump stop...
1995 XJ 60s 3 link and 36s
1997 F-250 Powerstroke Tow Rig
WAD357 is offline   Reply With Quote
Old 09-21-2011, 12:21 PM   #24 (permalink)
jkl
Member # 142189
Originally Posted by Twisty View Post
Cool build!
Did a quick mock up the other week and I THINK it should clear. I remember flatlander757 had issues in his TJ with the chevy axles but he was much lower than mine.
Thanks!
Close 85.75"
I have thought about your setup as a backup plan but would like to keep the hi steer so the tierods stay more out of harms way.
LJ on 35s[/SIZE]
Old 09-21-2011, 12:28 PM   #25 (permalink)
ky scrambled's Avatar
Member # 85771
Id imagine the Jeep being a little taller in the mud would only help.
Play stupid games, win stupid prizes
ky scrambled is offline   Reply With Quote
