1989 XJ - 1 Tons, Coil conversion, Chopped - Page 4 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-25-2012, 04:26 AM   #76 (permalink)
Member # 103442
Send a message via AIM to GreatWhiteXJ
Originally Posted by barillms View Post
You're redoing your rear fenders a 2nd time bc your tires rub? Why wouldn't you just bumpstop your suspension properly to keep them from rubbing?
Redoing them again makes no sense...
Makes perfect sense to me. They where ugly as sin.
Plus, he didnt state what kind of uptravel he was getting before contact. For all we know it could have been 1".
XJ on 42's
GreatWhiteXJ is offline   Reply With Quote
Old 03-26-2012, 01:15 PM   #77 (permalink)
adamusmc2002's Avatar
Member # 133157
Shoulda moved your cut up at least another inch for those sliders, but looks good. I just left the tiniest bit of lower rocker, where that plastic screwed into. I'll put pics up if I ever get em uploaded. You used the exact same material I did though, I love it...ended up working really well for keeping mud/water out when my doors are off, and can easily be stood on by numerous people who are trying to watch an event(bmr-Disney OK)
adamusmc2002 is offline   Reply With Quote
Old 03-26-2012, 03:25 PM   #78 (permalink)
Member # 20129
I didn't want to cut my half doors or my full doors anymore to make this fit so that's why I cut them where I did. Yea, 1/4" 2x8 rectangular tubing is gonna work sweet on these I'm sure. I would like to see your pics, so when you get a chance please send me a PM to them.
kpowning is offline   Reply With Quote
Old 03-26-2012, 07:58 PM   #79 (permalink)
Member # 133157
Yeah, sure. That makes sense on the bottoms of doors, cuz I did have to cut off about 1.5'' of door...no biggy for me though, already cut holes in them for exo to tie into my internal cage. only purpose they serve anymore is just keeping the weather out when the doors are actually on. I like to keep them off most of the summer. I'll put those pictures up too, most are on my phone.
Got the idea from ONEtonXJ, on his thread "Tater2 buildup". My pictures to come shortly.
Old 03-26-2012, 09:10 PM   #80 (permalink)
Member # 133157
Here's my cut
another
before paint
after
and here's what I meant about cutting out for the cage
oh, and i used 2"x6"x 3/16"wall, dug enough out of the points where it made contact so that I had 3" sticking out from the remaining rocker. Love it, one of my best mods yet, second to removable doors.
Old 03-28-2012, 03:55 PM   #81 (permalink)
Member # 20129
Yea - Nice work on the boatsides And thanks for posting
Old 04-10-2012, 12:02 PM   #82 (permalink)
Member # 133157
Originally Posted by kpowning View Post
Yea bought the ram, hoses and fittings www.surpluscenter.com and then made the tabs, drilled the valve in the steering pump and modded my steering box.
Did you drill and tap your own box, following the TOTM thread? I'm leaning toward a similar mod, cuz I don't think I'll ever be able to scrape up the dough for full hydro...
Thanks
Adam
Old 04-10-2012, 12:50 PM   #83 (permalink)
Member # 20129
Thanks
Adam
Yes - I followed those same instructions. Works great. Just time consuming and take notes and pictures as you disassemble makes it a lot easier to reassemble.
Old 04-12-2012, 03:58 PM   #84 (permalink)
Member # 133157
Ah, it requires disassembly huh? Good thing I have a spare box now, just put durango box in last week, took stock apart...You're right, lots of stuff goin on in there, esp the ball bearings in the worm gear I was leaning toward assist with tapped box, but then i remembered i already have high steer arms on my built 60, so might just wait it out til i can afford full hyd.
Anyway, thanks... back to your build thread.
Adam
Old 04-13-2012, 01:39 AM   #85 (permalink)
Member # 20129
Little more progress on the frame tonight.
Should have passenger side completed by tomorrow night.
Old 04-16-2012, 11:25 AM   #86 (permalink)
Member # 20129
OK Passenger side frame completed. Now tonight boatside..
Old 08-18-2012, 10:52 PM   #87 (permalink)
Member # 20129
Lets see - I still need to get pictures of my boatsides that are completed, however I just received some things I figured I would post up tonight.
Welded...
Primed...
Oh yea and don't forget the 42x15x15 PitBull Tires
And yes this side has not been completed yet as far as the boatsides, frame re-enforcement and new rear fender chop.
Old 08-19-2012, 08:26 AM   #88 (permalink)
ONEtonXJ's Avatar
Member # 145633
quit calling your sliders boat sides
"Tater2" - '91 2 door XJ. 4.0, AW4, 231/300 doubler, GM 60/70HD, 6.17s, ARB's & 4Ds
ONEtonXJ is offline   Reply With Quote
Old 08-19-2012, 08:33 AM   #89 (permalink)
Member # 20129
YEA THATS IT... AGAIN read the post! I will post pictures of my BOATSIDES later. Obviously the picture doesn't show the new BOATSIDES... HMMMMMMMM.
Old 12-16-2012, 07:43 PM   #90 (permalink)
twigg's Avatar
Member # 108288
Any updates to this build, looks good.
twigg is offline   Reply With Quote
Old 12-16-2012, 10:27 PM   #91 (permalink)
Member # 20129
Yes... Here comes some updates. I will have more pics to show tomorrow.
New rear fenders and out hunting for the past two weeks. Also installed the new Rad Rail manual shifter and it it worth every dollar. Check them out at:
Rail
Old 12-17-2012, 04:58 AM   #92 (permalink)
cherokeejat's Avatar
Member # 180492
Those are still sliders, not boatsides... Still kind of confused on the rear quarter cut, but to
each his own.
Bobbed, doubled, ton'd, and boatsided MJ
cherokeejat is offline   Reply With Quote
Old 12-17-2012, 08:57 AM   #93 (permalink)
Member # 20129
each his own.
Actually maybe you should search, "Boatsides" and tell me again these are not boatsides. These are not sliders! Sorry you don't have a picture yet of the underside of them...
The rear quarter cut turned out exactly how I wanted it. Right now at full tuck I have 2 inches from hitting the top of my rear fenders I still need to integrate some bump stops and I'm looking at lowering the jeep some.
Old 04-06-2013, 10:33 PM   #94 (permalink)
Member # 20129
Done some more work finally. Decided to start building my bumpers before the exo-cage gets fabricated. I will get some better photos of the jeep rear bumper installed. Sorry these were taken off my phone.
Some 2" x 6" .250 Rectangular Tubing
Better pictures to come... And finished pics with lights, etc.
Old 04-15-2013, 07:32 PM   #95 (permalink)
Member # 135283
looking good! i hope you will put led lights in those spots you cut out
nickzj is offline   Reply With Quote
Old 04-20-2013, 12:45 PM   #96 (permalink)
Member # 81189
I'd just cut the rest of the body off and make a buggy. That rear half of the unibody isn't doing much except flexing.
Those tires look huge.
'88 Jeep MJ 1-ton buggy
barillms is offline   Reply With Quote
Old 04-27-2013, 08:15 PM   #97 (permalink)
Member # 213479
cool sliders
LongArmXJ is offline   Reply With Quote
Old 05-06-2013, 04:09 AM   #98 (permalink)
SnailMan's Avatar
Member # 79690
Cool rock rails and wheel wells and bolt on lift and Tons but yeah not boatsides. Boatsides have a nice angle to then going from frame at an angle up to the doors usually way into the doors negating the use of doors. Overall cool trail rig should be fun once you get that cage done. Currently your body is flexin like crazy and your gonna crack allot of sheet metal. I wouldn't play anymore till your cage is done so it can stiffen your "frame" because even with your plating its not enough.
SI VIS PACEM, PARA BELLVM.
"If you wish for peace, prepare for war"
SnailMan is offline   Reply With Quote
