Member # 33510
XJ Build
Spec's:
'84 XJ 350 w/TBI (Cam, .060 over, Intake, HEI) Built TH350 Atlas2 D60s F/R Locked w/Spartans 42" PBR's Coil Springs 4-Linked F/R Full Hydro Exo-cage How I got it: Tear down: Motor back together: Building the tranny: Notching the frame for the sbc:
Northridge Fabrications Montrose, CO 970.626.6090 XJ, TBI SBC/TH350, Atlas2, 4-linked F/R, 60s, 42s Last edited by BryanDowdy; 05-03-2013 at 02:45 PM. |
Member # 33510
Starting the frame plating:
Got the motor mounted:
Northridge Fabrications Montrose, CO 970.626.6090 XJ, TBI SBC/TH350, Atlas2, 4-linked F/R, 60s, 42s |
Member # 33510
Beadlocks on and anti-conning rings:
Cleaning up the front 60 and plating the knuckles: Some clearance grinding: Trussing the axles:
Member # 33510
Upper link mounts and links:
Front links in: (Frame side lower mounts got lowered some & more triangulation after this) Fabbing the lower links:
Member # 33510
Flexing to get some measurements:
Member # 133157
Looks like lots of good progress, glad to see your thread updated. Those lower links are unique, I like em...question though, why did you do a fourth link in front, are you planning to not run a pan hard? I've heard and read that there's a potential for over constraining the axle with four links...maybe that's just with y link setups (?). Regardless, love the progress, keep it up. Your current state is where I hope to be in a year or so. What is your wheelbase at?
Adam and are those 42's? nevermind, saw it in your beadlock shot. Last edited by adamusmc2002; 04-25-2012 at 08:32 PM. |
#8 (permalink) | |
Member # 33510
Member # 133157
Cool, so they are triangulated enough to eliminate the pan hard, awesome. Guess I've never seen anybody be able to pull 4 link triangulated in the front, due to oil pan clearance and such.
Member # 33510
Yeah its not as common as a 3-link. Normally you do not run mechanical steering with a 4-link do to steering issue while cycling the suspension, but there are some on here who have. So I think that is the main reason most do not run a front 4-link.
#12 (permalink) | |
Member # 33510
Once both of our rigs are done we need to meet up. I grew up on the trails around Ouray but never been to the real ones in Montrose and toward you in GJ. Need someone to show me around.
#13 (permalink) |
Member # 33510
Found some time this evening and got the steering ram mounted.
#14 (permalink) |
Member # 33510
Picked up a 203 & 205. The 205 is just 10 spline. Going to machine a couple and just run the 10 spline. Will be upgrading to a atlas eventually, so I do not want to spend the money to convert it to a big bearing 32.
Also started on the cage
#17 (permalink) | |
Member # 33510
Thanks, it's my first cage. Plus I pick my work apart so I already am not happy with it. I have 3 other people wanting cages, so I'll get some more practice. That sounds like a blast! When are you aiming to finish your rig? I'm hoping for mid June, working on it every minute I'm not working for a living.
#19 (permalink) |
Member # 33510
I have a class later this month that will eat up 2 weekends, so that could slow things down. But still hopeful. I'm lowering my expectations to get it done, like coils instead of air shocks. I'm ready to just get the dame thing done and use it. I'll upgrade later.
#22 (permalink) | |
Member # 33510
Thanks
#23 (permalink) | |
Banned
Member # 178399
#24 (permalink) |
Member # 33510
Got a good bit done over the weekend.
Other side of the cage and roof. Still have X bracing and rear bumper to do. Will have 2 X brace going through the cab as well.
#25 (permalink) |
Member # 33510
Front bumper/winch mount. Also got the steering link shortened and installed.
