Member # 184176
Lets see your driveshafts.
The title says it.
Lets see em. Material used, yokes, lengths. What broke, what didnt. Square, round. Homemade, bought Will post mine when done. Still trying to find good material.
[SIZE="4"][COLOR="Red"]Id rather go fishing for a day than to have crabs for a life.[/COLOR][/SIZE] |
Member # 144152
2.5 inch schedule 40 poop tube with 1310 joints at both ends. About as strong as my front as my square shaft but a little better. Never been driven over 40mph and works great.
Member # 140225
Front: - too long to measure- 2" .250 wall square with inner squre slip- 1330 yoke on axle end and double carden on the tcase( this is to a doubler)
Rear is 2.5" from a ford thunderbird - dounble carden at tacase with a flange and a 1330 from ford aswell on axle with a 1350 crossjoint to the 14 bolt.
1 Ton Roll-bucket; MGO Last edited by DRICH394; 04-28-2012 at 10:53 PM. |
Tough Line Toys
Member # 113892
I believe its just a socket left on the head of the shocks bolt. The other one's hanging down so he's probably either installing or removing them.
ToughLineToys.com VectranŽ Winch Rope Toyota E-Locker to Air Locker Conversion Kits. Upcoming Products: 1.45:1/3.06:1 Gear Reduction Drive Shafts! Will be available for all makes & models.![]() Water Jetting: 12x6 table, cuts anything up to 8" thick. CAD work too, we can cut anything you can draw!
Member # 122916
Na, you are both wrong. Its a 1/2" lug nut screwed to a shock stud. It'll probably, eventually be swapped out with a fine thread nylon lock nut . The hose clamps are holding the brake hoses to the shock bodies.
red-gt'r, will you PM me a quote for a drive shaft? 1310 CV. Also interested in possibly a 1350 CV. Thanks. Last edited by xj9140; 05-03-2012 at 02:58 PM. |
#9 (permalink) | |
Tough Line Toys
Member # 113892
#12 (permalink) |
Member # 121563
1350s all around, including the CV.
2 x .120 DOM. Somewhere in the 40" range (can't remember). 2.5" slip/stub. Haven't tested it out yet. Hopefully it holds up decent. Rear will be the same thing. ![]() ![]()
#13 (permalink) |
Member # 122916
When engineering your drive shafts, only fabricated them as strong the inputs/outputs on your gear box and housings, as a failure in either of those departments would put you out.
#14 (permalink) | |
Member # 121563
Driveshafts shouldn't be fuses/weak links IMO. If having the correctly sized driveshaft means your tcase will be a weaklink, that's a sign to upgrade your tcase. |
#15 (permalink) | |
Member # 122916
IMO. But I have no real world experience and might be completely wrong. Any body run that setup?
#16 (permalink) | |
Launch it
'93 F-250 tow pig/dd- RIP ended up extra crispy '94 XJ- yardsaled... |
#18 (permalink) |
Member # 97798
I have a super budget, and "custom" drive shaft.
It starts at the axle with a $22 1410 yoke welded to a piece of 2" poop pipe. I then slid a stock YJ splined slip on the end and welded it together. The other end is the slip part of the YJ shaft with a 1310 yoke welded on to the end of that (the one on the YJ shaft was broken). 1310-1330 u-joint at the t-case. It's ghetto, but I think I have under $50 into this thing, and it's been working for a good while now. ![]() ![]() EDIT: the one above is the rear. The front shaft is off of a 1990ish Ford F350. 100% bolt in...absolutely 0 modifications to make it work for my application. It was also free.
88 MJ buggy - D60/14b, 3&4 link, air shocks, 203/205, 5.38s, full hydro newenglandjeepz.org Last edited by Twisty; 05-12-2012 at 10:10 AM. |
#20 (permalink) |
token Canadian
Member # 160053
Show me some front shafts, guys. I shortened a stocker, but with a D300 and not having cut and turned my front, my angle is brruuutal.
'98 Cherokee, 2-dr, HP60/14B 5.13:1, 37"s, Dana 300 4:1, 14" FOA coilovers, 5.9L V8 on its way in.. oink oink.
#21 (permalink) |
Banned
Member # 178399
Back to the top in need of advice. I'm going to run a D300 and have two front yokes from a 231 and some spare front shafts to modify for mock up. My question is what is everyone doing on the axle side? Is everyone just getting a u-joint that goes from the stock shaft to the D60 yoke? Or are you buying new yokes for the axles?
#22 (permalink) |
Member # 140225
I upped mine to 1330, but was running 1310/1330 cross joint without issues, but just desides to upgrade, u will be fine with a cross joint
FROM THE EMPTY BOTTLE!
1 Ton Roll-bucket; MGO |
#23 (permalink) |
Member # 105716
stock cherokee front slip shafts 1.25" don't take a lot of torque before they twist off.
![]() 1 3/8" slip with a forged yoke and no worries yet
00TJ 35sp60s 106wb Fabing & Wheeling is about having fun. If not: You're doing it wrong |
#24 (permalink) |
Banned
Member # 178399
Not the way I like to go about things but all this 1310-1330 has me lost. Talked to the local custom drive shaft place a town over. He said not to go 1330 because they have much less angle. He suggested 1310 or 1350. Mine will see 6 hour drives to go wheel so I'll post up what he makes me. God do I hate putting up the white flag but I hate braking more.
#25 (permalink) |
Member # 184176
I used the yoke that came with my sterling and d60 for my shafts.
1330s I believe. 1.75 hrew tube 1330 at axle 1310 at trans I hacked my old dana 60 slip shaft and stock front xj shaft for the front. Temporary until I get some square tube or get one made.
