Cookie Cutter XJ - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-10-2012, 12:01 PM   #26 (permalink)
Member # 172638
Haha, yea I gotta say I stole the fender bar idea from your build.
93 XJuggy, 4.0HO/ax15/231/300/hp60/14ff/38"tsl/beadlocks
theDMAXman is online now   Reply With Quote
Old 05-14-2012, 08:28 PM   #27 (permalink)
Member # 172638
more...
working on front shocks/bumps right now
full bump
for upper shock mounts i chopped up some ford shock towers, not real satisfied with them but its the only way i could mount the 14" travel fox resi's i had
Old 05-14-2012, 10:22 PM   #28 (permalink)
Member # 184176
lovin it man.
One of my favorite builds on here for sure.
[SIZE="4"][COLOR="Red"]Id rather go fishing for a day than to have crabs for a life.[/COLOR][/SIZE]
frankensteinxj is offline   Reply With Quote
Old 05-19-2012, 12:52 AM   #29 (permalink)
DRICH394's Avatar
Member # 140225
Super clean!!, but i would be useing JJ instead of heims with that shock mounted to it, unless they are 1.25" heims.
1 Ton Roll-bucket; MGO
DRICH394 is offline   Reply With Quote
Old 05-19-2012, 05:51 PM   #30 (permalink)
Member # 172638
thanks man, 1.25" ruff stuff heims on uppers and lowers
Old 05-20-2012, 05:18 AM   #31 (permalink)
Member # 206767
Great build, very clean. like the cage
sallys xj is offline   Reply With Quote
Old 05-22-2012, 08:06 AM   #32 (permalink)
Member # 151659
Good Idea with those ford shock mounts, those are brian's old shocks?...
96 XJ 4.0/aw4/231, hp30/44(4.56's) locked, ready for the mall..
clean4drxj is offline   Reply With Quote
Old 05-22-2012, 12:55 PM   #33 (permalink)
Member # 172638
Yes they are, 14" travel is a bit to long with how low it is without shock hoops but I didint want to get into more work making room for hoops, that will come when I chop the inner fenders out and dove it with coilovers
Old 09-18-2012, 05:46 PM   #34 (permalink)
ct67_72's Avatar
Member # 184680
So whats going on with this thing. I love this build. The rear frame is where mine will head at some point.
Id like to see an update if anything has been done. Not very many bad ass Ct rigs!
Oh and any more info on your tank setup using the factory pickup?
2000 XJ, BJ 60 front, welded, 5.13's, 3 link, hydro assist, ruffstuff heims. D70 rear, detroit, 5.13's, discs. stretched. trail ready beadlocks. Fo-dee" iroks.
Build. http://www.pirate4x4.com/forum/jeep-...ild-cheap.html
ct67_72 is online now   Reply With Quote
Old 09-18-2012, 07:07 PM   #35 (permalink)
Member # 172638
thanks man, i am at a point where its stupid stuff like driveshafts, plumb breaks, hydro assist, install traction bar finish weld perches now that the tcase is installed, build shifters, etc.
Problem is im seriously considering ditching the drivetrain in favor of a 5.3/sm465/i think my dana 300 with the 32 spline output should hold up. i can sell the 4.0/ax15 swap and front half of the doubler to help fund the v8 swap.
Untill i figure out where im going with this project i dont want to waste any time finishing the details, however i am very close to running it as is, i could probably have this thing running with a month of steady work, and that may just be the route i go. I am deff up to suggestions tho.
as far as the stock pump in the cell, i made my own ring from the old tank, and cut the tubes on the sending unit and made the unit drop strait down (stock they come out the front of the tank)
Old 09-19-2012, 03:21 AM   #36 (permalink)
ct67_72's Avatar
Member # 184680
Well I don't know how you plan to use this thing but ill give you my .02$
When I thought making engine mods, or swapping it out I always came back to the same conclusion. For where and how I wheel, I will never need more power than the 4.0. I don't have to worry about cooling it if I keep it stock, and its incredibly reliable.
For me there's just no way to justify it. That's probably the only thing that will never get touched.
Old 09-19-2012, 04:14 AM   #37 (permalink)
Member # 184176
I completely agree.
d300 would be cool though
Any details on your hydro assist setup?
Old 09-19-2012, 12:58 PM   #38 (permalink)
Member # 228153
That thing is bad ass, awesome work.
36Uptown is offline   Reply With Quote
Old 09-19-2012, 01:21 PM   #39 (permalink)
Member # 136471
Awesome build, love the cage.
boardbysled is offline   Reply With Quote
Old 09-19-2012, 03:29 PM   #40 (permalink)
Member # 151659
I would enjoy it as a 4l first and workout your suspenion bugs and then swap a 5.3 in, it's not all that bad from what I've read and seen. However with the way you have yours setup it should be good as long as you regeared your axles.
Old 09-19-2012, 05:56 PM   #41 (permalink)
Member # 172638
not sure what you mean? this aint a street rig...
as far as hydo assist im using a yj box with surplus center ram and a big cooler with its own fan, i will see if a stock pump will work, possibly try and mount the pump lower on the motor and i have a big external reservoir
not sure if an accessory setup is different off a tj or zj, have not looked into it at all
Old 09-19-2012, 06:05 PM   #42 (permalink)
Member # 172638
i also recently aquired the 5.3 motor/harness/computer
Old 09-19-2012, 07:26 PM   #43 (permalink)
ct67_72's Avatar
Member # 184680
That's tough when its sitting there looking at you. But unless your gonna race it and require going fast, just seems the 4.0 should be plenty, and no extra work! Lol. Especially with a doubler.
Old 09-24-2012, 11:00 PM   #44 (permalink)
Member # 97975
I have a question how do you like the rear leaf slider's? are you getting enough flex? awesome build by the way
91 xj 2dr 4x4 8"lift 34x9.5x15 swampers
1 grumpy is offline   Reply With Quote
Old 09-25-2012, 05:03 PM   #45 (permalink)
Member # 172638
i havent had it out yet, i know timmy ran them in comps for years with good success, that was a good enough excuse for me to try them, they keep the rig real stable
Old 09-25-2012, 06:00 PM   #46 (permalink)
Member # 97975
I picked up lowrider from Mark and am in the prosses of putting the 231/300 combo under it.Went with chevy60 frt hd70 in rear.so it's kinda nice seeing how the 2dr xj is going to look on 38's.
Old 10-14-2012, 04:43 PM   #47 (permalink)
Newbie
Member # 16403
Cool truck love the cage
Buy it, Wheel it, Part it, Repeat.........
AirZuk is offline   Reply With Quote
Old 10-15-2012, 05:31 PM   #48 (permalink)
Member # 172638
thanks!
Old 10-15-2012, 06:19 PM   #49 (permalink)
ct67_72's Avatar
Member # 184680
Is it done yet?
Old 10-15-2012, 06:51 PM   #50 (permalink)
Member # 172638
nope, but i did get out to mabell on saturday and it was a great day, lots of carnage, heres a few pics
